pnca Posted May 14, 2014 Share #1 Posted May 14, 2014 Hi~ Recently, I installed Xpenology by GnoBoot but external usb devices(USB Memory, DAC, USB HDD, etc...) have problem to mount its on ASRock Q1900-ITX. The devices had been operated aswell on N40L. What's the problem? plz, help me thanks~ Link to comment Share on other sites More sharing options...
ZedEau Posted May 18, 2014 Share #2 Posted May 18, 2014 Hello I have the same motherboard and i can't use usb drives too :/ I'm using DSM 5.0-4482 Link to comment Share on other sites More sharing options...
tomcarmen Posted May 19, 2014 Share #3 Posted May 19, 2014 hello, I too would be interested in buying this motherboard because it is' the only j1900 with 4 sata port. have you tried with nanoboot? look your news to buy it Link to comment Share on other sites More sharing options...
ZedEau Posted May 20, 2014 Share #4 Posted May 20, 2014 I tried with nanoboot, same issue :/ Link to comment Share on other sites More sharing options...
tomcarmen Posted May 20, 2014 Share #5 Posted May 20, 2014 I'm sorry, but you can not install? 4 sata ports are seen by xpe? I can connect 4 hd? LAN is seen? the only problem would be the only usb? Link to comment Share on other sites More sharing options...
ZedEau Posted May 20, 2014 Share #6 Posted May 20, 2014 I can install but when I'm on xpenology, it can't see any connected drive I even tried to install OMV, I've got the same problem, this time I can't install via USB It seems like it's a linux's kernel issue, there is no usb driver because our hardware is recent, or maybe asrock should update the bios Link to comment Share on other sites More sharing options...
tomcarmen Posted May 20, 2014 Share #7 Posted May 20, 2014 so do not even see the disks attached to sata? xpe therefore not usable, right? sorry but I am a novice Link to comment Share on other sites More sharing options...
ZedEau Posted May 20, 2014 Share #8 Posted May 20, 2014 The sata works fine, the usb ports don't work We can use xpe Link to comment Share on other sites More sharing options...
tomcarmen Posted May 20, 2014 Share #9 Posted May 20, 2014 which ram you have installed? I have a so-dimm Nanya 2GB PC3-10600 1333MHz DDR3-1333 Laptop okay for this motherboard? you can 'put a m-sata ssd? thanks to the availability Link to comment Share on other sites More sharing options...
ZedEau Posted May 20, 2014 Share #10 Posted May 20, 2014 I've installed crucial DDR3L 1.35v And it's a mini pcie port, I don't know if the msata ssd will work on it Link to comment Share on other sites More sharing options...
tomcarmen Posted May 20, 2014 Share #11 Posted May 20, 2014 tanks for reply Link to comment Share on other sites More sharing options...
tomcarmen Posted May 21, 2014 Share #12 Posted May 21, 2014 Another question. What the performance of lan. Copy file 8/10 gb ? Inviato dal mio GT-I9300 con Tapatalk now Free Link to comment Share on other sites More sharing options...
ZedEau Posted May 21, 2014 Share #13 Posted May 21, 2014 I don't know Link to comment Share on other sites More sharing options...
tomcarmen Posted May 27, 2014 Share #14 Posted May 27, 2014 hi, ZedEau nanoboot 5.0.2.4 released the log is written increased the USB drivers competent you have tested if it works now usb sorry for the trouble Link to comment Share on other sites More sharing options...
ZedEau Posted May 27, 2014 Share #15 Posted May 27, 2014 Nope, I'm giving up on xpenology I'm using debian 7 and it works fine to me Link to comment Share on other sites More sharing options...
tomcarmen Posted May 29, 2014 Share #16 Posted May 29, 2014 Have you by any chance the opportunity to quickly test So 'buy it. thanks again for your willingness Link to comment Share on other sites More sharing options...
pnca Posted June 2, 2014 Author Share #17 Posted June 2, 2014 Besides USB devices, internal sound device is also not working on nanoboot and gnoboot. :/ good luck~ Link to comment Share on other sites More sharing options...
Schnapps Posted June 2, 2014 Share #18 Posted June 2, 2014 Just ordered the ASRock Q1900-ITX - 72EUR So no luck with Xpenology? Hmm, i will try it too. Link to comment Share on other sites More sharing options...
tomcarmen Posted June 4, 2014 Share #19 Posted June 4, 2014 keep us updated. let us know when you arrive Link to comment Share on other sites More sharing options...
