Hello,
DMS is working just fine, but if I click reboot in DSM, the system reboots but gnoboot stops with an unknown error (21). Same problem applies if I click Shutdown in DSM. When I then press the power button on the front of my case, gnoboot stops with the same error message.
Only solution is to use the main switch on the power supply unit and then switch back on.
Im running on an ASUS PH877-I with Lian Li case.
Any ideas? I wanted to have the DSM shutdown automatically at night, but as I have to manually use the power switch this is impossible.
