carlchan Posted April 25, 2014 Share #1 Posted April 25, 2014 Dear all, i got a problem on video station, it cannot covert the video, but it work on DSM 4.3 ... Error message : "Music or videos don't play or display properly because the given codec is not successfully activated. please check your internet connection." Link to comment Share on other sites More sharing options...
Schnapps Posted April 25, 2014 Share #2 Posted April 25, 2014 Re-Install? Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
snakefox666 Posted May 5, 2014 Share #3 Posted May 5, 2014 Hello all, I have exactly the same problem with photo station since dsm5, any idea ? Thanks Link to comment Share on other sites More sharing options...
fabjan Posted May 5, 2014 Share #4 Posted May 5, 2014 Not sure, but there were a problem if you connect to the synology in https. It worked in http. F. Link to comment Share on other sites More sharing options...
snakefox666 Posted May 6, 2014 Share #5 Posted May 6, 2014 You mean to access the DSM through http://ipofdsm:5001 will solve this issue instead of https://.... ? Link to comment Share on other sites More sharing options...
fabjan Posted May 6, 2014 Share #6 Posted May 6, 2014 yes, just try http://forum.synology.com/enu/viewtopic.php?f=62&t=38838#p161860 F. Link to comment Share on other sites More sharing options...
snakefox666 Posted May 7, 2014 Share #7 Posted May 7, 2014 No success any other idea ? Link to comment Share on other sites More sharing options...
wenlez Posted May 8, 2014 Share #8 Posted May 8, 2014 I have a similar problem, that Video Station can not transcode, so video won't play in the browser. Is this caused by the same problem? Link to comment Share on other sites More sharing options...
msmith146 Posted May 13, 2014 Share #9 Posted May 13, 2014 I had similar problems with dsm 5, so I went back to 4.3. Someone mentioned that this issue with video station not transcoding is most likely due to the serial number. I used a serial number generator for dsm 5 gnoboot and I think that may have been the problem. Not confirmed though, but worth a shot. Sent from my SAMSUNG-SGH-I747 using Tapatalk Link to comment Share on other sites More sharing options...
snakefox666 Posted May 13, 2014 Share #10 Posted May 13, 2014 I don't use a serial number generator for my installation of DM5, maybe can I try to change the serial number ? Link to comment Share on other sites More sharing options...
jokies Posted May 13, 2014 Share #11 Posted May 13, 2014 I once got this problem but when the system is connected to Internet the problem is gone. Link to comment Share on other sites More sharing options...
carlchan Posted May 14, 2014 Author Share #12 Posted May 14, 2014 It seems to be a s/n problem ... i try nenoboot, no those problem ... : > Link to comment Share on other sites More sharing options...
snakefox666 Posted May 14, 2014 Share #13 Posted May 14, 2014 Do you know if nanoboot is working with an HP N40L ? Link to comment Share on other sites More sharing options...
