SmartPhoneLover Posted April 29, 2019 Share #1 Posted April 29, 2019 Hi all, I just installed and successfully set up Mayan EDMS in Docker (Synology NAS). My setup is as follows: -> Mayan (container) · Volumes path/to/docker/dir:/var/lib/mayan · Ports 32773 -> 8000 (TCP) · Variables PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin DEBIAN_FRONTEND: noninteractive PYTHONUNBUFFERED: 1 LC_ALL: C.UTF-8 PROJECT_INSTALL_DIR: /opt/mayan-edms PYTHON_PIP: /opt/mayan-edms/bin/pip MAYAN_DATABASE_PORT: 32772 MAYAN_DATABASE_CONN_MAX_AGE: 60 MAYAN_DATABASE_USER: mayan MAYAN_DATABASE_PASSWORD: my_pass MAYAN_DATABASE_NAME: mayan MAYAN_DATABASE_HOST: 172.17.0.1 MAYAN_DATABASE_ENGINE: django.db.backends.postgresql -> PostgreSQL (container) · Volumes path/to/docker/dir:/var/lib/postgresql/data · Ports 32772 -> 5432 (TCP) · Variables PATH: /usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/lib/postgresql/11/bin GOSU_VERSION: 1.11 LANG: en_US.utf8 PG_MAJOR: 11 PG_VERSION: 11.2-1.pgdg90+1 PGDATA: /var/lib/postgresql/data POSTGRES_PASSWORD: my_pass POSTGRES_DB: mayan POSTGRES_USER: mayan I have checked, and both are writing to the destination 'docker' folders its files. So they are saving any changes as permanent. The problem is that every time I reboot the NAS, so Docker also gets rebooted, Mayan starts downloading all of the resources again (as on first installation). So, the big problem for me is that if I'm not connected to the Internet, Mayan instance is not launched. Why is this happening? Is it an error from the build? Devs decided to make Mayan works by this way? Or I'm just forgeting some needed configuration to keep installation files saved? Please, if someone can help me... Quote Link to comment Share on other sites More sharing options...
SmartPhoneLover Posted April 29, 2019 Author Share #2 Posted April 29, 2019 Here you can see the moment where it starts downloading resources again on each boot. Quote Link to comment Share on other sites More sharing options...
SmartPhoneLover Posted April 29, 2019 Author Share #3 Posted April 29, 2019 Mmm, I just found that on Gitlab. Could the problem I'm facing be related to what is already described on this site? And here seems talking about changing the container tag to a different name, other than 'latest'. That seems Mayan prevents to download files on each boot. Did you try to start the container without Internet Connection to see what happends? Quote Link to comment Share on other sites More sharing options...
SmartPhoneLover Posted April 29, 2019 Author Share #4 Posted April 29, 2019 I created the container again without latest tag, but seems it's still connecting to the Internet. And this is not Docker, but Mayan. Log: https://pastebin.com/HXjP9Gaz Quote Link to comment Share on other sites More sharing options...
SmartPhoneLover Posted April 29, 2019 Author Share #5 Posted April 29, 2019 (edited) Now seems to be working without Internet!!!!!!!! I just had to wai a couple of minutes. After 20 reported container stops (and restarts) Mayan seems to be working, and bypassing HTTP requests. But, fffff. Too many tried until it gets successfully loaded. So, it was not the right solution I was finding out, but now I know that I just need to wait some more time on every boot if no Internet connection is available. Edited April 29, 2019 by SmartPhoneLover Quote Link to comment Share on other sites More sharing options...
