No gigabit ethernet in gnoboot based build. Help needed!
Raghav_K
hello guys,
this is my first post here, and hope you guys could help me.
i'm running the latest dsm 5.0 with gnoboot's latest alpha, on a biostar amd e350 based fusion board setup.
everything works fine, except gigabit ethernet. the ethernet speed is 100mbps and not gigabit/1000mbps.
The motherboard onboard lan is rtl8111f ethernet.
dmesg | grep 'Ethernet driver'
[    5.429584] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[    5.444419] 8139too: 8139too Fast Ethernet driver 0.9.28
[    5.461712] r8168 Gigabit Ethernet driver 8.037.00-NAPI loaded
[    5.716187] Brocade 10G Ethernet driver - version: 3.0.2.2
ethtool eth0
        Supported ports: [ TP ]
       Supported link modes:   10baseT/Half 10baseT/Full
                               100baseT/Half 100baseT/Full
                               1000baseT/Full
       Supports auto-negotiation: Yes
       Advertised link modes:  10baseT/Half 10baseT/Full
                               1000baseT/Full
       Advertised auto-negotiation: Yes
       Speed: 100Mb/s
       Duplex: Full
       Port: Twisted Pair
       PHYAD: 0
       Transceiver: internal
       Auto-negotiation: on
       Supports Wake-on: pumbg
       Wake-on: d
       Current message level: 0x00000033 (51)
       Link detected: yes
i think the newer r8169 driver supports Gigabit ethernet on the RTL8111F chip, but i do not know how to load r8169 instead of r8168.
any suggestions would be much appreciated :smile:
Thanks
I have nearly the same problem:
1000baseT/Half 1000baseT/Full
Speed: Unknown! (65535)
Duplex: Unknown! (255)
Port: Twisted Pair
PHYAD: 1
Supports Wake-on: g
Wake-on: g
Current message level: 0x000000ff (255)
Link detected: no
However I do not understand why it says (unknown) by both speed and duplex :smile:
If your having troubles getting gigabit working.... Try a different cable.
9 times out of ten... Auto detect will down negotiate to 100m if it detects a problem.
Thats exactly what happened... Changed cables yesterday and it got resolved :smile: forgot to update here...
Sent from my GT-I9300 using Tapatalk
