Silver Fang
Help me build a NAS for XPEnology
Hi, (please move this thread if its in wrong forum)
I want a NAS that is powerful to transcode .mkv for one user and can fit one WD RED 4TB.
Synology DiskStation DS218+ is having Intel Celeron J3355, so I know it needs more CPU than that.
Will this motherboard with Intel Celeron J4105 works with XPEnology?
ASRock J4105-ITX
https://www.asrock.com/mb/Intel/J4105-ITX/#Overview
If the motherboard works, what 8GB memory works for XPEnology (I know it must be compatible with the motherboard)?
I dont need much features from the NAS, only to store pictures (jpeg) and .mkv movies (from GoPro and anime, max 2GB per file).
Want to be able to access the NAS from outside of my home on my phone/iPad/laptop.
Thanks in advance.
Share this post
22 answers to this question
  • 1
That board is having problems with 6.2.2 and we haven't figured out why yet.  It works with 6.2.1 okay.
Share this post
That motherboard and CPU will work fine. - It should work with Jun's modloader 1.04b which emulates a DS918 - so Hardware encoding for the CPU will work great.
Technically any ram should work, looks like the motherboard uses SO-DIMM (laptop) RAM.
You can just boot the loader off a USB and have the SATA ports (there are 4 of them) for the HDD's
Edited by Prinz_Protato
Share this post
Will the turbo of the CPU work, from 1.5GHz to 2.5GHz?
Is one 8GB memory stick good enough or is 2x4GB better?
Thinking to use this small case.
What PSU is recommended?
Chieftec Compact Series IX-01B Mini-ITX
Thanks again
Share this post
Thanks again
I don't see why Turbo wouldn't work.
2x4gb is technically better as it'll be dual channel rather than single channel mode
You da real MVP :)
Share this post
2 minutes ago, Silver Fang said:
Will 16GB memory make any difference for what I will use it for?
Its 20$ USD cheaper with 8GB.
Thanks in advance
That board only supports a max of 8GB according to the website
Share this post
Actually it's Intel that says the processor only supports 8GB but it actually works fine up to 32GB.
Share this post
25 minutes ago, mig67 said:
I have the same board with 8GB and it's more than enough, even just 4GB is enough
Oh. I was not aware. I was going off the spec on the Asrock website
Share this post
What case are you using?
The case I was planning requires Pico PSU, dont know If I should go with it or not, I want a small case as possible that fits one 3.5" hdd.
Ok, will only buy 8GB memory.
Edited by Silver Fang
Share this post
12 часа назад, Silver Fang сказал:
Will 85 watt be enough for the board, 8GB memory and a WD Red 4TB?
Read this, with one WD Red 4TB will be plus 3-5 watts.
Share this post
Have now ordered:
Case: Chieftec Compact Series IX-01B Mini-ITX
PSU: Chieftec AC Power Adapter CDP-085ITX 85W
Motherboard: ASRock J4105-ITX - Intel Gemini Lake - Intel Onboard CPU socket - DDR4 RAM - Mini-ITX
Memory: Corsair Vengeance SO-DIMM DDR4 2400MHz 2x4GB (CMSX8GX4M2A2400C16)
Hard drive: WD Red WD40EFRX - 64MB - 5400 RPM - 4TB
Almost small as Synology DS218+ but more powerful and cheaper.
Only fit one 3.5" hdd and power brick is outside the device, but fanless.
Just need to check how to install XPEnology.
Do I need to update BIOS for the motherboard if there is any newer version?
Thanks in advance
Share this post
1 час назад, Silver Fang сказал:
I did nothing with the BIOS settings and set it to what it was originally. But remember that version 6.2.2 does not work on this mb.
Share this post
So version 6.2.1 is to go, where can I find a tutorial to install from beginning with version 6.2.1, all I find is older versions or how to update?
Thanks in advance
Share this post
Do I need to have the USB-stick attached to the NAS all the time or is it only during installation of Xpenology?
If I need it attached all the time, then I must buy a smaller one 🙂
Thanks in advance
Share this post
You need it in all the time when the xpen will boot. The best way buy a smaller one and forgot about it. 😉
Share this post
Answer this question...
