DSM 5.0 4458 on N54L gnoboot FAIL MESSAGE please HELP
phil2perpi
Hi everyone,
I'm actually running DSM 5.0-4418 Update 1 on HP N54L using TRANTOR and all works fine.
As many of you I want to install the last update. So let's go for GNOBOOT.
I made a new usb stick with ALPHA 10.4 as explained in the excellent tuto from CYANLABS : http://cyanlabs.co.uk/news/install-xpen ... thout-esxi
Too bad for me : I never arrive at : DISKSTATION LOGIN, the end of the procedure
instead of this I stop at : [ 7.660731] fixing recursive fault but reboot is needed
?????? I had the same message a few days ago with gnoboot-alpha 10.3 ??????
I switched off my N54L, and on... NO WAY, same error message
COULD SOMEONE PLEASE HELP ME ?
Actually I plugged my old TRANTOR USB Stick and all works fine with DSM 5.0-4418 Update 1
