Captainfingerbang Posted February 26, 2019 Share #1 Posted February 26, 2019 Im having no luck at all getting my 10gbe cards recognized by DSM. i've had the exact card working on the 3615 image but it wont work on either of my 918+ setups. These x540-t2 are supported OOB from synologies page here so im not sure whats up. Shouldn't this card (x540-t2) work OOB without driver ext on ds918+ 1.04b image? Or do i need to install the driver extension? Any help would be seriously appreciated Quote Link to comment Share on other sites More sharing options...
flyride Posted February 26, 2019 Share #2 Posted February 26, 2019 Did this post not explain the situation for you? DS918+ has no slot for 10Gbe card so the Synology support page would not apply. Quote Link to comment Share on other sites More sharing options...
Captainfingerbang Posted February 27, 2019 Author Share #3 Posted February 27, 2019 Thanks flyride. My fault i didnt see your reply Much appreciated. Quote Link to comment Share on other sites More sharing options...
mervincm Posted March 17, 2019 Share #4 Posted March 17, 2019 (edited) I run 918+ image with 10G ethernet card, (recycled HP server NIC) Edited March 17, 2019 by mervincm add 2nd image Quote Link to comment Share on other sites More sharing options...
mervincm Posted March 17, 2019 Share #5 Posted March 17, 2019 (edited) 560SFP+ 82599 chipset. Edited March 17, 2019 by mervincm 1 Quote Link to comment Share on other sites More sharing options...
dhlsam Posted April 27, 2019 Share #6 Posted April 27, 2019 On 3/17/2019 at 8:53 AM, mervincm said: 560SFP+ 82599 chipset. hi, does the 10g ethernet card hp 560sfp+ 82599 working on 1.04b 918+ 6.2.1? any driver extension needed? Quote Link to comment Share on other sites More sharing options...
mervincm Posted April 27, 2019 Share #7 Posted April 27, 2019 Yes the 10g works bare metal and no I didn’t have to add a driver. I am on 1.04b 918+ 5.21 with hardware transcoding working for plex on 390z chipset and i3-8100 cpu I have not yet tried the 6.22 Quote Link to comment Share on other sites More sharing options...
Olegin Posted April 27, 2019 Share #8 Posted April 27, 2019 1 час назад, mervincm сказал: Yes the 10g works bare metal and no I didn’t have to add a driver. I am on 1.04b 918+ 5.21 with hardware transcoding working for plex on 390z chipset and i3-8100 cpu I have not yet tried the 6.22 Try with any fresh hdd and the new flash, if it'll work - get your position to update for your master system. Quote Link to comment Share on other sites More sharing options...
mervincm Posted April 27, 2019 Share #9 Posted April 27, 2019 Yup, I have a lot of spare gear to test with. After being down trying to get the 9600K CPU hw transcoding working, I am enjoying a nice stable working system for a while I am hoping the drivers get updated to work with the 9600K CPU, and that the turbo mode issue is resolved at some point, but till then, the i3-8100 is working remarkably well. Quote Link to comment Share on other sites More sharing options...
nemesis122 Posted April 28, 2019 Share #10 Posted April 28, 2019 (edited) Could you tell me is your Intel 10 GBe Networkadapter wokring with a fresh install from DSM when only the 10Gbe card is connected?? thank you very mucb The reason for this Question is i have Mellanox 3 Networkadapter and for a fresh DSM Install i need to connect both Networkadapters my mellanox and my intel on Board Networkadapter with Loader 1.02b and DSM 15284 DSM6.1 alone with the mellanox Networkadapter the server is not found in the network when the installations done it is working with the mellanox card alone Edited April 28, 2019 by nemesis122 Quote Link to comment Share on other sites More sharing options...
dhlsam Posted April 29, 2019 Share #11 Posted April 29, 2019 On 4/28/2019 at 1:42 AM, mervincm said: Yes the 10g works bare metal and no I didn’t have to add a driver. I am on 1.04b 918+ 5.21 with hardware transcoding working for plex on 390z chipset and i3-8100 cpu I have not yet tried the 6.22 Hi, I bought 560SFP+ 82599 and install 1.04b 918 6.2 DSM_DS918+_23739.pat I don't see 560sfp+ when install completed ,only 2 onboard intel nic I add 4 mac address in grub.cfg file Quote Link to comment Share on other sites More sharing options...
mervincm Posted April 29, 2019 Share #12 Posted April 29, 2019 How can I help you out? I can send you a copy of a log or a config file? Quote Link to comment Share on other sites More sharing options...
mervincm Posted May 1, 2019 Share #13 Posted May 1, 2019 (edited) On 4/27/2019 at 11:42 AM, mervincm said: 5.21 this was an error. I have 6.21-23824U6 my systemboard NIC is disabled, and I only have a single fiber to my dual port NIC I used the 2 synology MAC in the guide Edited May 1, 2019 by mervincm add mac Quote Link to comment Share on other sites More sharing options...
mgrobins Posted May 22, 2019 Share #14 Posted May 22, 2019 I had issues with DSM not recognising my x550 NICs onboard my Supermicro MB. If I'm not wrong the module of that NIC is basee on igb drivers. this change worked for me: Try modifying the grub file as following if it doesn't work: In the gub file change the following line: Code: Select all initrd $img/ramdisk.lzma $img/$extra_initrd to: Code: Select all initrd $img/$extra_initrd $img/ramdisk.lzma Quote Link to comment Share on other sites More sharing options...
TNa681 Posted January 20, 2021 Share #15 Posted January 20, 2021 Hi, ask somebody to confirm if it is possible to add a 10GbE PCIe card to a bare metal installation of 918+, would that really work? Quote Link to comment Share on other sites More sharing options...
flyride Posted January 20, 2021 Share #16 Posted January 20, 2021 As long as the card has driver support, either from the loader or extra.lzma, 10Gbe works fine. 1 Quote Link to comment Share on other sites More sharing options...
Captainfingerbang Posted January 20, 2021 Author Share #17 Posted January 20, 2021 (edited) Hey flyride, It's been a while since I read the spec of 918+ Xpen dsm but quick question about 10gbe. I Have 2 918+ 1.04b baremetal all ssd arrays- both with pcie x1 intel nic to router. Then, I have x540-t2 in both units. Not using on board Realtek nic. I Have the x540-t2's direct connected but showing only 1 network interface in dsm for the x540-t2 cards, it's not showing both. For example I want to link aggregate and bind. I recall reading something about a max lan port limitation for Xpen 918+ but not sure,i forgot. Is this most likely caused by me not using an extra.lzma? And/Or Would this be because I only listed 1 nic in config when setting up the dsm usb drive? To solve this would I need to remake the dsm usb drive but add the extra.lzma? I'm trepidatious to remake usb drives because there's important data on 1,backed up to the other. Edited January 20, 2021 by Captainfingerbang Quote Link to comment Share on other sites More sharing options...
flyride Posted January 21, 2021 Share #18 Posted January 21, 2021 A quick search for "DS918+ network" turned up this post which is exactly your situation. https://xpenology.com/forum/topic/39583-intel-x540-t2-nic-not-obtaining-ip-address-stays-disconnected/?tab=comments#comment-186615 Remember that the onboard (RealTek) NIC uses a port even if you are not using it, unless you disable in the BIOS. Quote Link to comment Share on other sites More sharing options...
mervincm Posted January 22, 2021 Share #19 Posted January 22, 2021 I can confirm on my 918+ xpenology system with 2 port 10 gig E intel card I see both NICs (my motherboard NIC is disabled) 1 Quote Link to comment Share on other sites More sharing options...
