guyp2k Posted February 22, 2019 Share #1 Posted February 22, 2019 Using an old Gigabyte GA-Z77X-UDH5 w/ Core I7, 32G RAM, Intel NICs, and both on-board SATA and SATA card. I am able to install 6.2.1 Update 4, but experiencing some issues. The issues are as follows: 1. Will not reboot and power-off, requires a cold power-off. 2. Not all HDs are showing up, show fine in boot, but not DSM. So my question should I try and install an earlier release, 6.1 and upgrade to 6.2.1, if so what loader and version (3615 or 3617) would be the recommendation. Thanks Quote Link to comment Share on other sites More sharing options...
