Olegin Posted February 17, 2019 Share #1 Posted February 17, 2019 (edited) Test stand: ASRock J4105-ITX, Crucial DDR4 so-DIMM RAM with 2400MHz CL17-CT4G4SFS824A 4GB, flash drive, 2.5 250GB hard drive. Prepared the flash drive as described here, installed the memory, connected the HDD and turned on the power. It worked without the BIOS reconfiguration. Скрытый текст Power consumption 10 watts, the folder /dev/dri is in place, installed the Video station, the codecs was activated. With transcoding 4K here is what I got: Скрытый текст Скрытый текст Скрытый текст Скрытый текст On four streams of transcoding consumption increased to 30 watts, the CPU radiator is noticeably hot, so who plans to use xpen in this mode-think about a good blowing the radiator. Installed VMM, ubuntu and virtual DSM worked fine, but it is better to add up to 8 GB of memory. Edited February 17, 2019 by Olegin 2 Quote Link to comment Share on other sites More sharing options...
JMRR Posted February 17, 2019 Share #2 Posted February 17, 2019 Folowed your tuturial, instaled on askock J5005-itx with 4gb ram(i need more i know), valid sn+mac from one rs model.Migrate dsm from esxi(hdd raid 1 configuration in rdm mode), everithing went smooth./dev/dri is in place, and codecs is activated.This combo is an amazing setup for dsm.The only thing doesent work is reboot or shutdow.I use bios 1.0 i think, its beter to upgrade or doesent mater?Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
Olegin Posted February 17, 2019 Author Share #3 Posted February 17, 2019 @JMRR Try a clean install on another HDD, it seems to me that the problems with the shutdown & reboot is not in 5005, but in 1.04. On 4105 all works fine after clean install. I tried to switch the hdd and flash drive from a working system and also got the problem with shutting down. Quote Link to comment Share on other sites More sharing options...
JMRR Posted February 17, 2019 Share #4 Posted February 17, 2019 I did one clean install on one brand new ssd, and shutdown and reboot didnt work either.The migration was the last think i did, but the problem came from clean install too.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
codedmind Posted February 23, 2019 Share #5 Posted February 23, 2019 Having the same issue in a clean install 1.04 in 918º asrock J4105-ITX Quote Link to comment Share on other sites More sharing options...
ksero Posted February 26, 2019 Share #6 Posted February 26, 2019 With j4105, works well reset and Shutdown, migrated ds3615, but i have a problem to activate transcoding /dev/dri$ cat /usr/syno/etc/codec/activation.conf {"success":false,"msg":"SN format is wrong."} I try with two Serial Numbers, without solution. any idea? Thanks! Quote Link to comment Share on other sites More sharing options...
Calvin Posted March 3, 2019 Share #7 Posted March 3, 2019 I'm using Asrock J4105-ITX, 32GB Kingston DDR4 2400, 4* 480GB SSD. It's run DSM 6.1.7 fine. But have issue on DSM+VMM+Win10. Cannot run/install win10. Anyone have same issue? Quote Link to comment Share on other sites More sharing options...
chemistry Posted March 6, 2019 Share #8 Posted March 6, 2019 On 2/17/2019 at 5:14 PM, JMRR said: Folowed your tuturial, instaled on askock J5005-itx with 4gb ram(i need more i know), valid sn+mac from one rs model. Migrate dsm from esxi(hdd raid 1 configuration in rdm mode), everithing went smooth. /dev/dri is in place, and codecs is activated. This combo is an amazing setup for dsm. The only thing doesent work is reboot or shutdow. I use bios 1.0 i think, its beter to upgrade or doesent mater? Sent from my iPad using Tapatalk For me shutdown and reboots work fine. Only Drives don't spin down for energy saving... Quote Link to comment Share on other sites More sharing options...
Olegin Posted March 7, 2019 Author Share #9 Posted March 7, 2019 12 часа назад, chemistry сказал: Only Drives don't spin down for energy saving... Try this , may be help Quote Link to comment Share on other sites More sharing options...
pmchan Posted March 7, 2019 Share #10 Posted March 7, 2019 (edited) Hi Olegin, thanks to your positive feedback I finally decided to go for the Asrock J4105 instead of a J4205, difference is, I bought the m-ATX model for its 3 pcie 2.0 x1 ports. That's a bit lame and I would have preferred they put at least one x8 or even x4, but this way I was able to add my 2 budget sata cards SI-PEX40064 and a dual nic HP nc360T. Migrated from my previous build, Q1900-itx DS918+ without too much hassles, HW transcoding is working great, shutdown and reboot too and consumption is lower by 8 watts in idle, nice bonus Installed your modified extra.lzma too, thanks again! Regarding HW transcoding, be sure to disable VT-D in Bios or it won't work, just a black screen when you hit play button, I learned it the hard way. Edited March 7, 2019 by pmchan Quote Link to comment Share on other sites More sharing options...
chemistry Posted March 10, 2019 Share #11 Posted March 10, 2019 i have a problem now with my Xpenology... SurveillanceStation does not work properely. When opening different Menu options they load indefinetly. Now i am thinking about reinstalling everything from the scratch. But how do i do this without loosing the data stored? Quote Link to comment Share on other sites More sharing options...
JMRR Posted March 12, 2019 Share #12 Posted March 12, 2019 @Olegin did you configured anything on bios about graphics? On my instalation, codecs are active and /dev/dri as entries, but if i try to encode using vaapi, the output files are always only with sound. root@nas:~# ls -al /dev/dri total 0 drwxrwxrwx 2 root root 80 Feb 26 18:47 . drwxr-xr-x 14 root root 18900 Mar 9 22:57 .. crw-rw-rw- 1 root root 226, 0 Feb 26 18:47 card0 crw-rw-rw- 1 root root 226, 128 Feb 26 18:47 renderD128 Using ffmpeg from repo: /var/packages/ffmpeg/target/bin/ffmpeg -vaapi_device /dev/dri/renderD128 -i /volume1/downloads/twd.ts -vf 'format=nv12,hwupload,scale_vaapi=w=1920:h=1080' -sn -c:v h264_vaapi -qp 20 -bf 2 -c:a aac -tune zerolatency -f matroska /volume1/downloads/test3.mkv Using VideoStation ffmpeg /var/packages/VideoStation/target/bin/ffmpeg -vaapi_device /dev/dri/renderD128 -i /volume1/downloads/twd.ts -vf 'format=nv12,hwupload,scale_vaapi=w=1920:h=1080' -sn -c:v h264_vaapi -qp 20 -bf 2 -c:a aac -tune zerolatency -f matroska /volume1/downloads/test3.mkv Output in any case: Input #0, mpegts, from '/volume1/downloads/twd.ts': Duration: 00:42:00.56, start: 43931.504333, bitrate: 4841 kb/s Program 1 Metadata: service_name : FOX HD service_provider: SID FOX HD Stream #0:0[0x192d]: Video: h264 (Main) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [SAR 1:1 DAR 16:9], 25 fps, 50 tbr, 90k tbn, 50 tbc Stream #0:1[0x192e](por): Audio: mp2 ([4][0][0][0] / 0x0004), 48000 Hz, stereo, s16p, 192 kb/s Stream mapping: Stream #0:0 -> #0:0 (h264 (native) -> h264 (h264_vaapi)) Stream #0:1 -> #0:1 (mp2 (native) -> aac (native)) Output #0, matroska, to '/volume1/downloads/test3.mkv': Metadata: encoder : Lavf58.20.100 Stream #0:0: Video: h264 (h264_vaapi) (High) (H264 / 0x34363248), vaapi_vld, 1920x1080 [SAR 1:1 DAR 16:9], q=-1--1, 25 fps, 1k tbn, 25 tbc Metadata: encoder : Lavc58.35.100 h264_vaapi Stream #0:1(por): Audio: aac (LC) ([255][0][0][0] / 0x00FF), 48000 Hz, stereo, fltp, 128 kb/s Metadata: encoder : Lavc58.35.100 aac frame= 2134 fps=142 q=-0.0 Lsize= 1395kB time=00:01:26.76 bitrate= 131.7kbits/s speed=5.76x video:0kB audio:1353kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 3.088716% I think the device is present but not acessible. Do you have any idea? Ps: i did not upgraded bios on Asrock J5005-itx Quote Link to comment Share on other sites More sharing options...
Olegin Posted March 12, 2019 Author Share #13 Posted March 12, 2019 39 минут назад, JMRR сказал: did you configured anything on bios about graphics? Nothing. 39 минут назад, JMRR сказал: Do you have any idea? May be mistakes in your commands or DSM didn't understand them. Try to encode from Videostation web gui. Quote Link to comment Share on other sites More sharing options...
ksero Posted March 13, 2019 Share #14 Posted March 13, 2019 Discheck a VTD option in bios, and try. 1 Quote Link to comment Share on other sites More sharing options...
JMRR Posted March 13, 2019 Share #15 Posted March 13, 2019 i remember i left active. im going to disable it and try. Thanks. Quote Link to comment Share on other sites More sharing options...
pmchan Posted March 13, 2019 Share #16 Posted March 13, 2019 VT-D has to be disabled on those motherboards or HW transcoding won't work, at least on my J4105m. Quote Link to comment Share on other sites More sharing options...
JMRR Posted March 13, 2019 Share #17 Posted March 13, 2019 Thanks guys, its working.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
bibicu Posted September 3, 2019 Share #18 Posted September 3, 2019 (edited) Can someone be so kind and confirm if HW transcoding is still enabled on J4105/j5005 with DSM 6.2.2, Jun 1.04b and DS918+ ? Just check if there is something in /dev/dri For me, the i915 driver crashes during the boot so I had to use real3x extra.lzma which removes it, but then I don't have hw transcoding. @Olegin does not specify which version of DSM he was testing with, but I suspect it was an earlier version of DSM. Thank you Edited September 3, 2019 by bibicu Quote Link to comment Share on other sites More sharing options...
reworks Posted September 6, 2019 Share #19 Posted September 6, 2019 @ bibicu : Same thing for me, many try and no transcoding. no boot without real3x and no transcoding with 1 Quote Link to comment Share on other sites More sharing options...
bibicu Posted September 6, 2019 Share #20 Posted September 6, 2019 @reworks: after many many hours spent trying stuff, I came to conclusion that HW transcoding only works in 6.2.1 with the original extra.lzma. In 6.2.2 it does not work. We may need to wait for Synology to release a Gemini Lake box to grab a newer i915 driver. @reworks: do you see Health disk information for the disks in STorage manager? I can't see (Access error) it with DS918 Quote Link to comment Share on other sites More sharing options...
reworks Posted September 10, 2019 Share #21 Posted September 10, 2019 Hi on 6.2.1 yes. In 6.2.2 i don't remenber because i downgrage my xpenology. Quote Link to comment Share on other sites More sharing options...
bibicu Posted September 10, 2019 Share #22 Posted September 10, 2019 (edited) @reworks Good to know that you can see Health info in 6.2.1 ! Which loader (1.03b or 1.04b) and model (ds918+ or ds3615x) are you on ? Thank you Edited September 10, 2019 by bibicu Quote Link to comment Share on other sites More sharing options...
reworks Posted September 19, 2019 Share #23 Posted September 19, 2019 Hi 1.04b and model ds918+ Quote Link to comment Share on other sites More sharing options...
toyanucci Posted December 5, 2019 Share #24 Posted December 5, 2019 I ordered some parts to make a build using the Asrock J4105. Just waiting on the motherboard now which comes friday. I've made the usb so just to do the setup and I should be good to go. My question is this...is HW transcoding working with 6.2.2 with the 918+ serial number and mac addresses or should I just stick to 6.2.1? Just checking if there was any update on this. Thanks in advance! Quote Link to comment Share on other sites More sharing options...
darkknigt Posted December 5, 2019 Share #25 Posted December 5, 2019 9 hours ago, toyanucci said: I ordered some parts to make a build using the Asrock J4105. Just waiting on the motherboard now which comes friday. I've made the usb so just to do the setup and I should be good to go. My question is this...is HW transcoding working with 6.2.2 with the 918+ serial number and mac addresses or should I just stick to 6.2.1? Just checking if there was any update on this. Thanks in advance! If you don't use Intel ethernet adapter ( mother board net card is Realtek) and update to 6.2.2 you lost HW Transcoding and SW Transcoding. Quote Link to comment Share on other sites More sharing options...
