usb 3 card
  • 4 weeks later...
Can incompatibilities arise on OS level? I'd just think that a USB pci card functions as a hub
Sent from my GT-I9300 using Tapatalk
I thought in terms of windows os and PCI cards where drivers are needed for the card to function properly. What you are implying is that all PCI usb 3 cards will function correctly?
Sent from my Nexus 4 using Tapatalk
I am using one like THIS in my N54L
Which DSM version are you using?
I was using 4.3 3827 and it worked then, now using DSM 5.0 4458 update 2 and still working :grin:
It also comes with the low profile bracket which you need.
Hi Robjo,
I received my card today and have installed it but it's not being picked up by the system. Did you install the card in a live box or did you install the card pre-DSM installation? I don't have a monitor handy so I haven't looked at the bios - is there anything that requires attention there?
HP N40L 8GB Ram
Bios-Mods bios hack applied
Trantor DSM 4.3.3827 Beta 7 update 2
This USB3 Card with NEC chip
Any advice most welcome.
