public ip sender script
Zatharan
PS: please feel free to tell me what I can improve
Here is my 1st contribution to the forum, it's a quick .net c# script to get your NAS's public ip address and send it to your mail.
The script checks for a change every 30 seconds and send the new public ip address to your mail.
use-case :
you have an open-vpn setup with your NAS but you cant connect to your network if your public ip has changed
Pre-requisites :
Have the mono package installed/running on your NAS: https://synocommunity.com/package/mono
How to :
open the file in a IDE or inside notepad ++, do the necessary highlighted  changes (those are //inside the file)
drop your file inside a folder with the execute permission
look for your mono version : mono  - -version
compile it into a .exe using the " appropriate" command (depends on which package source you installed mono from synocommunity/synology (beta)
run the package using the "mono" command
publicipsender.cs
Edited by Zatharan
