kosovari Posted March 24, 2014 Share #1 Posted March 24, 2014 hello ! Need help from you . Trying to update the version 5.0 via the control panel to / DSM update exactly according to these instructions ============================================================================================================ 1. First check if you're able to download update 3 from the GUI (Control Panel , DSM Update) - Download the update. - 1st . If not able to download , connect / login with putty / telnet ( user: root) - 1b. Remove / autoupd@te.info (rm / autoupd@te.info ) - 1c. Now try to donwload update 3 from the GUI again (Control Panel , DSM Update) 2nd Connect / login with putty / telnet and execute These two commands : CODE : SELECT ALL sed ' s/flashupdateDeb/flashupdateDeb1 / ' / autoupd@te.info > / autoupd@te.info1 mv / autoupd@te.info1 / autoupd@te.info 3rd Install the update from GUI (Control Panel , DSM Update) ============================================================================================================ but I get up then this error message , see below. -------------------------------------------------- ---------------------------------------------------------------------- an error ( 2 ) while accessing the temporary directory occurred during the update ---------------------------------------------------------------------- It is possible to download the update, but the installation does not work after I copied the *sed* and *mv* row and run this in putty. hope you will understand and excuse my bad english. Link to comment Share on other sites More sharing options...
