superma87 Posted February 5, 2022 Share #26 Posted February 5, 2022 FIY just change // Sanity check that this is the 8772 assert(ioread(0x20) == 0x87); assert(ioread(0x21) == 0x72); to // Sanity check that this is the 8613 assert(ioread(0x20) == 0x86); assert(ioread(0x21) == 0x13); to make it working Quote Link to comment Share on other sites More sharing options...
superma87 Posted February 5, 2022 Share #27 Posted February 5, 2022 On 12/11/2020 at 2:12 AM, Misty said: I've adapted the code to integrate into Synology's own fan controlling system. You can find my code here : https://github.com/NyaMisty/scemd_fanspeed_hook injecting this code with DSM 7 cause some strange logs output 2022-02-05T20:11:19+01:00 terranas scemd[10820]: fs_btrfs_metadata_usage_query.c:125 Failed to check the btrfs metadata usage of volume [/volume1]. 2022-02-05T20:11:25+01:00 terranas scemd[10820]: fs_btrfs_metadata_usage_query.c:86 Failed to read result of getting btrfs tree info, err No such file or directory Quote Link to comment Share on other sites More sharing options...
kerncool Posted August 31, 2022 Share #28 Posted August 31, 2022 Thanks to eudean for the tools Works fine on my Terramaster f2-220, but the "Task Scheduler" startup doesn't work, so I write the script file to the startup file. 1. Edit the script file vi /etc/rc 2. Add the script file to the penultimate line of the file (before exit 0) /your_directory/fancontrol Quote Link to comment Share on other sites More sharing options...
ZerOneX Posted January 22 Share #29 Posted January 22 @eudeanyou rock... thank you very much... I put it on my task scheduler and it is working like a charm!!!! Quote Link to comment Share on other sites More sharing options...
