Siddarta Posted March 23, 2014 Share #1 Posted March 23, 2014 Hi all, sorry for the mistakes, I'm Spanish, and I speak much English. this is my first post. I need your help. My problem es here (view the photo) Xpenology I installed 4.3 on HP ProLiant G7 N54L, everything is perfect, but when you spend time windows network does not show me the server, and not what happens, you can help me? sometimes appears and sometimes not, look at the pictures to understand it better, thank you very much. https://www.dropbox.com/sh/iq3x9yb001fmubr/cz-0qxE2LM Link to comment Share on other sites More sharing options...
andywhit Posted March 23, 2014 Share #2 Posted March 23, 2014 Hi, I see the same problem. Sometimes the NAS appears in the Windows Network list, other times it doesn't. If it's not listed then I just enter \\DiskStation into a windows explorer toolbar to see the NAS contents, in your case it would be \\servidor Link to comment Share on other sites More sharing options...
Siddarta Posted March 23, 2014 Author Share #3 Posted March 23, 2014 thank you very much, the problem is that I use the nas for xbmc media center, so as to appear and other times, it does not let me read the database, there was no thought openmediavault alternatively choose, but I really like xpenology, then you can not solve this problem? Link to comment Share on other sites More sharing options...
Siddarta Posted March 24, 2014 Author Share #4 Posted March 24, 2014 I need help, in windows no see the network, is possible that version 4.3 of xpenology, have a error? Link to comment Share on other sites More sharing options...
newbi Posted March 24, 2014 Share #5 Posted March 24, 2014 Try this. Go into File services and if "Enable SMB 2 and large mtu" is ticked, un-tick it and apply then refresh "network" in My Computer. If it's not tick then tick and apply and try it.If none of that works use synology assistant and mount a folder. Link to comment Share on other sites More sharing options...
Siddarta Posted March 24, 2014 Author Share #6 Posted March 24, 2014 very thanks, this afternoon I testing. Link to comment Share on other sites More sharing options...
jurgenautt Posted March 24, 2014 Share #7 Posted March 24, 2014 ya te funciona paco? Link to comment Share on other sites More sharing options...
juanvi Posted March 24, 2014 Share #8 Posted March 24, 2014 Eso, eso, para cuando una seccion en Spanish? Yo tengo pedido un n54l y no se si poner trantor con 4.3 o 5 beta, o ir con gnoboot y 5.0 oficial? Suerte Paco! Link to comment Share on other sites More sharing options...
Siddarta Posted March 25, 2014 Author Share #9 Posted March 25, 2014 still does not work, I've done what you said, but still the same Gracias, que va sigue asi, no se que le pasa, no me muestra la unidad de red del nas, en cambio hago un \\SERVIDOR y me aparece y se ve, lo he estado buscando por la red y nada de nada, teneis alguna idea¿ Link to comment Share on other sites More sharing options...
jurgenautt Posted March 26, 2014 Share #10 Posted March 26, 2014 has probado deshabilitar el antivirus?, a veces entran en conflicto, comprueba el firewall del antivirus y también del windows mira si estás en el mismo grupo de trabajo, comprueba también el tema de los permisos de usuario y de carpetas en el software xpenology ya comentas... Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #11 Posted March 26, 2014 el cortafuegos de windows si, el de avira no, si estoy en el mismo grupo "WORKGROUP" y permisos de synologyc esta todo ok, pero el de windows no he caido en mirarlo como se mira? Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #12 Posted March 26, 2014 el cortafuegos de windows si, el de avira no, si estoy en el mismo grupo "WORKGROUP" y permisos de synologyc esta todo ok, pero el de windows no he caido en mirarlo como se mira? Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #13 Posted March 26, 2014 el cortafuegos de windows si, el de avira no, si estoy en el mismo grupo "WORKGROUP" y permisos de synologyc esta todo ok, pero el de windows no he caido en mirarlo como se mira? Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #14 Posted March 26, 2014 el cortafuegos de windows si, el de avira no, si estoy en el mismo grupo WORKGROUP y permisos de synologyc esta todo ok, pero el de windows no he caido en mirarlo como se mira Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #15 Posted March 26, 2014 el cortafuegos de windows si, el de avira no, si estoy en el mismo grupo WORKGROUP y permisos de synologyc esta todo ok, pero el de windows no he caido en mirarlo como se mira Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #16 Posted March 26, 2014 pues voy a mirar el tema del cortafuegos y por cierto el tema de los permisos en windows donde esta Link to comment Share on other sites More sharing options...
jurgenautt Posted March 26, 2014 Share #17 Posted March 26, 2014 primero haz una prueba ,deshabilita el antivirus y pruebas a ver..., luego comprueba la opción del firewall de windows, yo el avira no lo conozco, uso kaspersky , la versión de avira dispone de firewall?, si es así normalmente el propio antivirus deshabilita las opciones de firewall de windows..., pero en tú caso no lo sé , otra cosa... como tienes dispuesto la configuración de red, en modo dhcp o en manual?, por que aveces también da por culo estas cosas... saludos Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #18 Posted March 26, 2014 pues voy a probar a quitar el cortafuegos del avira, por lo demas creo que esta todo, porque donde miro los privilegios en windows? Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #19 Posted March 26, 2014 pues voy a probar a quitar el cortafuegos del avira, por lo demas creo que esta todo, porque donde miro los privilegios en windows? Link to comment Share on other sites More sharing options...
jurgenautt Posted March 26, 2014 Share #20 Posted March 26, 2014 a que privilegios te refieres?, si es para deshabilitar en windows el firewall ,te vas a panel de control, y en opción de firewall compruebas su estado Link to comment Share on other sites More sharing options...
Siddarta Posted March 26, 2014 Author Share #21 Posted March 26, 2014 he enviado el mensaje unas cuantas veces, no veas, pues he desabilitado el cortafuegos de ambos, vamos a ver lo que ocurre, de momento me lo muestra, pero no me fio ni un pelo, igualmente me he creado un accedo directo, tampoco le voy a dar muchas vueltas, la ip, la he puesto manualmente, ya que tengo bastantes aparatos en casa y me gusta tener controlado cada uno de ello, los privilegios, digo en la red, si hay alguna manera de saber que privilegios tengo un la red de trabajo Link to comment Share on other sites More sharing options...
