N36L network speed
davurleon
I don't know if this has already been answered, I think I have searched wide and far, but maybe not enough, if that is the case I am sorry...
I have a HP Microserver N36L
However, I have Xpenology installed 5.4458 and with Gnoboot. (otherwise no modifications, I started out with the trantor 3810 and upgraded to 5beta and then to 4458)
When I look in my router it says I have 1Gbit speed, so does the Xpenology in it's settings, but I max out at 11-12 Mbytes copy speed in my network (which is somewhat a maxed out 100Mbit connection I guess)
Anyone have a clue as to how I can get 1Gbit speed on my unit? (All of my network is 1Gbit, all switches, router, etc.)
Hi Gnoboot, thanks for answering!
I am only running CIFS, mostly large files. I have 2 NICs, the built in one and some other I bought, however both seem to have an identical chip from broadcom.
About the other 2 things, I a am total newbie to this, I just really like the Synology system, so I really don't know what to do in order to give you the 2 outputs, I have tried to install Shellinabox and get something there, but don't know how to export it so I can send it to you.
Sorry...
I did as you said I should, I hope, does this file help you in any way?
Should I use 10.4 instead of 10.3, will that help maybe?
Once again, thank you so much for helping me!
+ gnoBootCmdParamValue gnoboot_me
+ paramName=gnoboot_me
+ [ -z gnoboot_me ]
+ cat /proc/cmdline
+ [ root == gnoboot_me ]
+ [ ihd_num == gnoboot_me ]
+ [ netif_num == gnoboot_me ]
+ [ syno_hw_version == gnoboot_me ]
+ [ debug == gnoboot_me ]
+ [ vga == gnoboot_me ]
+ [ sn == gnoboot_me ]
+ installVersion=
+ gnoBootIsCmdParam gnoboot_me
+ param=gnoboot_me
+ grep -c gnoboot_me /proc/cmdline
+ found=0
+ [ 0 -eq 1 ]
+ echo 0
+ [ 0 -eq 1 ]
+ gnoBootRegen
+ procpart=/proc/partitions
+ grep -cv # /proc/partitions
+ [ 28 -le 1 ]
+ disksec=32098
+ grep 32098 /proc/partitions
+ cut -c 26-
+ diskpre=
+ [ x == x ]
+ return
+ gnoBootRegenDev
+ [ -e /dev/hpet ]
+ mknod /dev/hpet c 10 228
+ [ -e /dev/rtc0 ]
+ mknod /dev/rtc0 c 254 0
+ [ ppc853x = bromolow ]
+ [ -x /usr/syno/bin/synocfgen ]
+ insmod /lib/modules/synobios.ko
+ /bin/mknod /dev/synobios c 201 0
+ RCMsg Starting /usr/syno/bin/synocfgen /usr/syno/bin/synocfgen
+ echo -n :: Starting /usr/syno/bin/synocfgen
+ shift
+ [ 1 -eq 0 ]
+ [ yes = yes ]
+ MsgBusy
+ [ -n ]
+ echo -en \e[72G[
+ echo -en \e[0;32m BUSY
+ echo -en \e[m]
+ /usr/syno/bin/synocfgen
+ local ret=0
+ [ 0 -eq 0 ]
+ MsgDone
+ [ -n ]
+ echo -en \e[72G[
+ echo -en \e[1;32m OK
+ echo -e \e[m]
+ return 0
+ RetCfg=0
+ echo /usr/syno/bin/synocfgen returns 0
+ /bin/grep+ /usr/bin/cut -f 1 -d
/sbin/lsmod
+ rmmod bromolow_synobios
+ /bin/get_key_value /etc/synoinfo.conf supportraid
+ SupportRAID=yes
+ /bin/get_key_value /etc/synoinfo.conf defaultfs
+ DefFS=ext4
+ /bin/get_key_value /etc/synoinfo.conf support_dual_head
+ DualHead=
+ FSCK=/sbin/e2fsck
+ FsckFlag=/tmp/.fsckfail
+ MkfsFlag=/tmp/.mkfsfail
+ /bin/get_key_value /etc.defaults/synoinfo.conf unique
+ grep comcerto2k
+ [ x != x ]
+ /bin/get_key_value /etc.defaults/synoinfo.conf supportsas
+ SupportSAS=
+ [ = yes ]
+ support_emmc_boot
+ local emmc_boot
+ /bin/get_key_value /etc.defaults/synoinfo.conf support_emmc_boot
+ emmc_boot=
+ [ xyes = x ]
+ return 1
+ [ = yes ]
+ [ yes = yes ]
+ RootDevice=/dev/md0
+ /usr/syno/bin/synodiskport -internal
+ ProcDiskList= sda sdb sdc sdd sdf
+ Ret=0
+ [ 0 != 12 -a x = x sda sdb sdc sdd sdf ]
+ [ ! -d /sys/block/md0 -a yes = yes ]
+ [ 0 != 12 ]
+ CheckPartition
+ /usr/syno/bin/synocheckpartition
+ RetPartition=7
+ echo Partition Version=7
+ ExecFsck=1
+ [ 7 -eq 0 ]
+ [ xyes != xyes ]
+ [ yes != ]
+ CheckRootFs
+ [ -x /sbin/e2fsck -a 1 -eq 1 ]
+ echo /sbin/e2fsck exists, checking /dev/md0...
+ /sbin/e2fsck -pf -C 0 /dev/md0
+ ResFSCK=0
+ echo /sbin/e2fsck returns 0
+ echo Mounting /dev/md0 /tmpRoot
+ /bin/mount /dev/md0 /tmpRoot
+ echo /tmpRoot/lost+found/#*
+ FileList=/tmpRoot/lost+found/#*
+ [ /tmpRoot/lost+found/#* != /tmpRoot/lost+found/#* ]
+ [ yes = ]
+ RCMsg Checking upgrade file /bin/sh /etc/upgrade.sh
+ echo -n :: Checking upgrade file
+ shift
+ [ 2 -eq 0 ]
+ [ yes = yes ]
+ MsgBusy
+ [ -n ]
+ echo -en \e[72G[
+ echo -en \e[m]
+ /bin/sh /etc/upgrade.sh
+ local ret=0
+ [ 0 -eq 0 ]
+ MsgDone
+ [ -n ]
+ echo -en \e[72G[
+ echo -e \e[m]
+ return 0
+ /bin/get_key_value /etc.defaults/synoinfo.conf support_ssd_cache
+ SupportSSDCache=yes
+ [ yes = yes -a -d /sys/block/md0 ]
+ WithInternal=0
+ ls /sys/block/md0/md/
+ grepcut -c 5-
+ md0disks=sda1
sdb1
sdc1
sdd1
sdf1
+ /usr/syno/bin/synodiskport -portcheck sda1
+ PortType=SATA
+ [ SATA = SAS -o SATA = SATA ]
+ WithInternal=1
+ /usr/syno/bin/synodiskport -portcheck sdb1
+ PortType=SATA
+ WithInternal=1
+ /usr/syno/bin/synodiskport -portcheck sdc1
+ PortType=SATA
+ WithInternal=1
+ /usr/syno/bin/synodiskport -portcheck sdd1
+ PortType=SATA
+ WithInternal=1
+ /usr/syno/bin/synodiskport -portcheck sdf1
+ PortType=SATA
+ WithInternal=1
+ [ -n sda1
sdb1
sdc1
sdd1
sdf1 -a 1 -eq 0 ]
+ [ ! -d /tmpRoot/etc ]
+ [ ! -d /tmpRoot/usr/syno/etc ]
+ [ ! -d /tmpRoot/var ]
+ [ -f /tmpRoot/.noroot ]
+ [ ! -x /tmpRoot/sbin/init ]
+ [ -f /tmpRoot/.memtest ]
+ [ -f /.gnoboot/rc.d/post ]
+ source /.gnoboot/rc.d/post
+ gnoBootInitPost
+ gnoBootUpgrade
+ param=gnoboot_me
+ found=0
+ [ 0 -eq 1 ]
+ echo 0
+ [ 0 -eq 0 ]
+ return
+ gnoBootUpdateFiles
+ get_key_value /tmpRoot/etc/VERSION majorversion
+ synomajor=4
+ get_key_value /tmpRoot/etc/VERSION minorversion
+ synominor=3
+ synobuild=3
+ synoversion=4.3-3
+ [ -d /.gnoboot ]
+ gnoMountRoot
+ [ -d /tmpRoot ]
+ grep -c md0 /proc/mounts
+ [ 1 -lt 1 ]
+ [ -d /tmpRoot/.gnoboot ]
+ gnoUpdateFile /.gnoboot/devices-append /tmpRoot/.gnoboot/devices-append
+ mySrc=/.gnoboot/devices-append
+ myDst=/tmpRoot/.gnoboot/devices-append
+ gnoCheckSum /.gnoboot/devices-append
+ myFile=/.gnoboot/devices-append
+ [ -f /.gnoboot/devices-append ]
+ /usr/bin/cksum /.gnoboot/devices-append
+ /usr/bin/cut -d -f1
+ mySum=1712127836
+ echo 1712127836
+ mySrcSum=1712127836
+ gnoCheckSum /tmpRoot/.gnoboot/devices-append
+ myFile=/tmpRoot/.gnoboot/devices-append
+ [ -f /tmpRoot/.gnoboot/devices-append ]
+ /usr/bin/cksum+ /usr/bin/cut -d -f1
+ mySum=1712127836
+ echo 1712127836
+ myDstSum=1712127836
+ [ 1712127836 != 1712127836 ]
+ gnoUpdateFile /.gnoboot/rc.d/xpenology /tmpRoot/usr/syno/cfgen/s03_xpenology
+ mySrc=/.gnoboot/rc.d/xpenology
+ myDst=/tmpRoot/usr/syno/cfgen/s03_xpenology
+ gnoCheckSum /.gnoboot/rc.d/xpenology
+ myFile=/.gnoboot/rc.d/xpenology
+ [ -f /.gnoboot/rc.d/xpenology ]
+ /usr/bin/cksum /.gnoboot/rc.d/xpenology
+ mySum=732510806
+ echo 732510806
+ mySrcSum=732510806
+ gnoCheckSum /tmpRoot/usr/syno/cfgen/s03_xpenology
+ myFile=/tmpRoot/usr/syno/cfgen/s03_xpenology
+ [ -f /tmpRoot/usr/syno/cfgen/s03_xpenology ]
+ mySum=732510806
+ echo 732510806
+ myDstSum=732510806
+ [ 732510806 != 732510806 ]
+ gnoUpdateFile /.gnoboot/modules.conf /tmpRoot/.gnoboot/modules.conf
+ mySrc=/.gnoboot/modules.conf
+ myDst=/tmpRoot/.gnoboot/modules.conf
+ gnoCheckSum /.gnoboot/modules.conf
+ myFile=/.gnoboot/modules.conf
+ [ -f /.gnoboot/modules.conf ]
+ /usr/bin/cksum /.gnoboot/modules.conf
+ mySum=1221940840
+ echo 1221940840
+ mySrcSum=1221940840
+ gnoCheckSum /tmpRoot/.gnoboot/modules.conf
+ myFile=/tmpRoot/.gnoboot/modules.conf
+ [ -f /tmpRoot/.gnoboot/modules.conf ]
+ /usr/bin/cksum /tmpRoot/.gnoboot/modules.conf+ /usr/bin/cut -d -f1
+ mySum=1221940840
+ echo 1221940840
+ myDstSum=1221940840
+ [ 1221940840 != 1221940840 ]
+ gnoUpdateFile /.gnoboot/rc.d/init /tmpRoot/.gnoboot/rc.init
+ mySrc=/.gnoboot/rc.d/init
+ myDst=/tmpRoot/.gnoboot/rc.init
+ gnoCheckSum /.gnoboot/rc.d/init
+ myFile=/.gnoboot/rc.d/init
+ [ -f /.gnoboot/rc.d/init ]
+ /usr/bin/cksum /.gnoboot/rc.d/init
+ mySum=2500139883
+ echo 2500139883
+ mySrcSum=2500139883
+ gnoCheckSum /tmpRoot/.gnoboot/rc.init
+ myFile=/tmpRoot/.gnoboot/rc.init
+ [ -f /tmpRoot/.gnoboot/rc.init ]
+ /usr/bin/cksum /tmpRoot/.gnoboot/rc.init
+ mySum=2500139883
+ echo 2500139883
+ myDstSum=2500139883
+ [ 2500139883 != 2500139883 ]
+ [ -e /.gnoboot/etc/rc.network-4.3-3 ]
+ gnoUpdateFile /etc/rc.network /tmpRoot/etc/rc.network
+ mySrc=/etc/rc.network
+ myDst=/tmpRoot/etc/rc.network
+ gnoCheckSum /etc/rc.network
+ myFile=/etc/rc.network
+ [ -f /etc/rc.network ]
+ /usr/bin/cksum /etc/rc.network
+ mySum=3861479236
+ echo 3861479236
+ mySrcSum=3861479236
+ gnoCheckSum /tmpRoot/etc/rc.network
+ myFile=/tmpRoot/etc/rc.network
+ [ -f /tmpRoot/etc/rc.network ]
+ /usr/bin/cut -d -f1 /tmpRoot/etc/rc.network
+ mySum=3861479236
+ echo 3861479236
+ myDstSum=3861479236
+ [ 3861479236 != 3861479236 ]
+ gnoUpdateFile /etc/rc.network /tmpRoot/etc.defaults/rc.network
+ myDst=/tmpRoot/etc.defaults/rc.network
+ mySum=3861479236
+ echo 3861479236
+ gnoCheckSum /tmpRoot/etc.defaults/rc.network
+ myFile=/tmpRoot/etc.defaults/rc.network
+ [ -f /tmpRoot/etc.defaults/rc.network ]
+ /usr/bin/cksum /tmpRoot/etc.defaults/rc.network/usr/bin/cut -d -f1
+ mySum=3861479236
+ echo 3861479236
+ gnoBootIsCmdParam debug
+ param=debug
+ grep -c debug /proc/cmdline
+ found=1
+ [ 1 -eq 1 ]
+ echo 1
+ [ 1 -eq 1 ]
+ echo ----- dmesg -----
+ dmesg
+ gnoUpdateFile /.gnoboot/debug /tmpRoot/.gnoboot/debug.log
+ mySrc=/.gnoboot/debug
+ myDst=/tmpRoot/.gnoboot/debug.log
+ gnoCheckSum /.gnoboot/debug
+ myFile=/.gnoboot/debug
+ [ -f /.gnoboot/debug ]
+ /usr/bin/cksum /.gnoboot/debug
+ mySum=2672248841
+ echo 2672248841
+ mySrcSum=2672248841
+ gnoCheckSum /tmpRoot/.gnoboot/debug.log
+ myFile=/tmpRoot/.gnoboot/debug.log
+ [ -f /tmpRoot/.gnoboot/debug.log ]
+ echo xxxxxxxxxx
+ myDstSum=xxxxxxxxxx
+ [ 2672248841 != xxxxxxxxxx ]
+ basename /tmpRoot/.gnoboot/debug.log
+ RCMsg Updating debug.log cp -af /.gnoboot/debug /tmpRoot/.gnoboot/debug.log
+ echo -n :: Updating debug.log
+ shift
+ [ 4 -eq 0 ]
+ [ yes = yes ]
+ MsgBusy
+ [ -n ]
+ echo -en \e[72G[
+ echo -en \e[m]
+ cp -af /.gnoboot/debug /tmpRoot/.gnoboot/debug.log
OS-e820: 00000000bffaa600 - 00000000bffe0000 (ACPI NVS)
[ 0.000000] BIOS-e820: 00000000bffe0000 - 00000000c0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000e0000000 - 00000000f0000000 (reserved)
[ 0.000000] BIOS-e820: 00000000ffa00000 - 0000000100000000 (reserved)
[ 0.000000] BIOS-e820: 0000000100000000 - 0000000230000000 (usable)
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] SMBIOS 2.6 present.
[ 0.000000] DMI: HP ProLiant MicroServer, BIOS O41 10/01/2013
[ 0.000000] e820 update range: 0000000000000000 - 0000000000010000 (usable) ==> (reserved)
[ 0.000000] e820 remove range: 00000000000a0000 - 0000000000100000 (usable)
[ 0.000000] No AGP bridge found
[ 0.000000] last_pfn = 0x230000 max_arch_pfn = 0x400000000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-EFFFF uncachable
[ 0.000000] F0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000000 mask FFFF80000000 write-back
[ 0.000000] 1 base 000080000000 mask FFFFC0000000 write-back
[ 0.000000] 2 base 0000C0000000 mask FFFFF0000000 write-back
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] TOM2: 0000000230000000 aka 8960M
[ 0.000000] e820 update range: 00000000d0000000 - 0000000100000000 (usable) ==> (reserved)
[ 0.000000] last_pfn = 0xbff90 max_arch_pfn = 0x400000000
[ 0.000000] found SMP MP-table at [ffff8800000ff780] ff780
[ 0.000000] initial memory mapped : 0 - 20000000
[ 0.000000] Base memory trampoline at [ffff880000099000] 99000 size 20480
[ 0.000000] Using GB pages for direct mapping
[ 0.000000] init_memory_mapping: 0000000000000000-00000000bff90000
[ 0.000000] 0000000000 - 0080000000 page 1G
[ 0.000000] 0080000000 - 00bfe00000 page 2M
[ 0.000000] 00bfe00000 - 00bff90000 page 4k
[ 0.000000] kernel direct mapping tables up to bff90000 @ 1fffd000-20000000
[ 0.000000] init_memory_mapping: 0000000100000000-0000000230000000
[ 0.000000] 0100000000 - 0200000000 page 1G
[ 0.000000] 0200000000 - 0230000000 page 2M
[ 0.000000] kernel direct mapping tables up to 230000000 @ bff8e000-bff90000
[ 0.000000] ACPI: RSDP 00000000000f8f50 00024 (v02 HP )
[ 0.000000] ACPI: XSDT 00000000bffa0100 0007C (v01 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: FACP 00000000bffa0290 000F4 (v03 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: DSDT 00000000bffa0620 06868 (v01 HP ProLiant 00000006 INTL 20051117)
[ 0.000000] ACPI: FACS 00000000bffae000 00040
[ 0.000000] ACPI: APIC 00000000bffa0390 00072 (v01 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: MCFG 00000000bffa0410 0003C (v01 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: SPMI 00000000bffa0450 00041 (v05 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: OEMB 00000000bffae040 00072 (v01 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: HPET 00000000bffab4e0 00038 (v01 HP ProLiant 20131001 HP 00000097)
[ 0.000000] ACPI: EINJ 00000000bffab520 00130 (v01 AMIER AMI_EINJ 20131001 HP 00000097)
[ 0.000000] ACPI: BERT 00000000bffab6b0 00030 (v01 AMIER AMI_BERT 20131001 HP 00000097)
[ 0.000000] ACPI: ERST 00000000bffab6e0 001B0 (v01 AMIER AMI_ERST 20131001 HP 00000097)
[ 0.000000] ACPI: HEST 00000000bffab890 000A8 (v01 AMIER ABC_HEST 20131001 HP 00000097)
[ 0.000000] ACPI: SSDT 00000000bffab940 00386 (v01 HP ProLiant 00000001 AMD 00000001)
[ 0.000000] ACPI: Local APIC address 0xfee00000
[ 0.000000] [ffffea0000000000-ffffea0007bfffff] PMD -> [ffff880227a00000-ffff88022e7fffff] on node 0
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000010 -> 0x00001000
[ 0.000000] DMA32 0x00001000 -> 0x00100000
[ 0.000000] Normal 0x00100000 -> 0x00230000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[3] active PFN ranges
[ 0.000000] 0: 0x00000010 -> 0x0000009e
[ 0.000000] 0: 0x00000100 -> 0x000bff90
[ 0.000000] 0: 0x00100000 -> 0x00230000
[ 0.000000] On node 0 totalpages: 2031390
[ 0.000000] DMA zone: 56 pages used for memmap
[ 0.000000] DMA zone: 5 pages reserved
[ 0.000000] DMA zone: 3921 pages, LIFO batch:0
[ 0.000000] DMA32 zone: 14280 pages used for memmap
[ 0.000000] DMA32 zone: 767944 pages, LIFO batch:31
[ 0.000000] Normal zone: 17024 pages used for memmap
[ 0.000000] Normal zone: 1228160 pages, LIFO batch:31
[ 0.000000] ACPI: PM-Timer IO Port: 0x808
[ 0.000000] ACPI: LAPIC (acpi_id[0x01] lapic_id[0x00] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x02] lapic_id[0x01] enabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x03] lapic_id[0x82] disabled)
[ 0.000000] ACPI: LAPIC (acpi_id[0x04] lapic_id[0x83] disabled)
[ 0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] dfl dfl lint[0x1])
[ 0.000000] ACPI: IOAPIC (id[0x02] address[0xfec00000] gsi_base[0])
[ 0.000000] IOAPIC[0]: apic_id 2, version 33, address 0xfec00000, GSI 0-23
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[ 0.000000] ACPI: IRQ0 used by override.
[ 0.000000] ACPI: IRQ2 used by override.
[ 0.000000] ACPI: IRQ9 used by override.
[ 0.000000] Using ACPI (MADT) for SMP configuration information
[ 0.000000] ACPI: HPET id: 0x8300 base: 0xfed00000
[ 0.000000] SMP: Allowing 4 CPUs, 2 hotplug CPUs
[ 0.000000] nr_irqs_gsi: 40
[ 0.000000] PM: Registered nosave memory: 000000000009e000 - 000000000009f000
[ 0.000000] PM: Registered nosave memory: 000000000009f000 - 00000000000a0000
[ 0.000000] PM: Registered nosave memory: 00000000000a0000 - 00000000000e2000
[ 0.000000] PM: Registered nosave memory: 00000000000e2000 - 0000000000100000
[ 0.000000] PM: Registered nosave memory: 00000000bff90000 - 00000000bff9e000
[ 0.000000] PM: Registered nosave memory: 00000000bff9e000 - 00000000bffa0000
[ 0.000000] PM: Registered nosave memory: 00000000bffa0000 - 00000000bffaa000
[ 0.000000] PM: Registered nosave memory: 00000000bffaa000 - 00000000bffab000
[ 0.000000] PM: Registered nosave memory: 00000000bffab000 - 00000000bffe0000
[ 0.000000] PM: Registered nosave memory: 00000000bffe0000 - 00000000c0000000
[ 0.000000] PM: Registered nosave memory: 00000000c0000000 - 00000000e0000000
[ 0.000000] PM: Registered nosave memory: 00000000e0000000 - 00000000f0000000
[ 0.000000] PM: Registered nosave memory: 00000000f0000000 - 00000000ffa00000
[ 0.000000] PM: Registered nosave memory: 00000000ffa00000 - 0000000100000000
[ 0.000000] Allocating PCI resources starting at c0000000 (gap: c0000000:20000000)
[ 0.000000] Booting paravirtualized kernel on bare hardware
[ 0.000000] setup_percpu: NR_CPUS:16 nr_cpumask_bits:16 nr_cpu_ids:4 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 26 pages/cpu @ffff88022fc00000 s75776 r8192 d22528 u524288
[ 0.000000] pcpu-alloc: s75776 r8192 d22528 u524288 alloc=1*2097152
[ 0.000000] pcpu-alloc: [0] 0 1 2 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 2000025
[ 0.000000] Kernel command line: root=/dev/md0 ihd_num=1 netif_num=4 syno_hw_version=DS3612xs debug vga=0x0307 sn=B3L4N41787
[ 0.000000] Internal HD num: 1
[ 0.000000] Internal netif num: 4
[ 0.000000] Synology Hardware Version: DS3612xs-j
[ 0.000000] Serial Number: B3L4N41787
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Checking aperture...
[ 0.000000] Node 0: aperture @ b4000000 size 32 MB
[ 0.000000] Aperture pointing to e820 RAM. Ignoring.
[ 0.000000] Your BIOS doesn't leave a aperture memory hole
[ 0.000000] Please enable the IOMMU option in the BIOS setup
[ 0.000000] This costs you 64 MB of RAM
[ 0.000000] Mapping aperture over 65536 KB of RAM @ b4000000
[ 0.000000] PM: Registered nosave memory: 00000000b4000000 - 00000000b8000000
[ 0.000000] Memory: 7845444k/9175040k available (3531k kernel code, 1049480k absent, 280116k reserved, 2928k data, 14860k init)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] CONFIG_RCU_FANOUT set to non-default value of 32
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] NR_IRQS:4352 nr_irqs:712 16
[ 0.000000] Extended CMOS year: 2000
[ 0.000000] Console: colour dummy device 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] hpet clockevent registered
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1297.837 MHz processor.
[ 0.001005] Calibrating delay loop (skipped), value calculated using timer frequency.. 2595.67 BogoMIPS (lpj=1297837)
[ 0.001017] pid_max: default: 32768 minimum: 301
[ 0.001100] Mount-cache hash table entries: 256
[ 0.001268] tseg: 0000000000
[ 0.001285] CPU: Physical Processor ID: 0
[ 0.001290] CPU: Processor Core ID: 0
[ 0.001295] mce: CPU supports 6 MCE banks
[ 0.001311] using AMD E400 aware idle routine
[ 0.004424] ACPI: Core revision 20110623
[ 0.009468] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[ 0.020027] CPU0: AMD Athlon II Neo N36L Dual-Core Processor stepping 03
[ 0.020998] Performance Events: AMD PMU driver.
[ 0.020998] ... version: 0
[ 0.020998] ... bit width: 48
[ 0.020998] ... generic registers: 4
[ 0.020998] ... value mask: 0000ffffffffffff
[ 0.020998] ... max period: 00007fffffffffff
[ 0.020998] ... fixed-purpose events: 0
[ 0.020998] ... event mask: 000000000000000f
[ 0.020998] Booting Node 0, Processors #1
[ 0.020998] smpboot cpu 1: start_ip = 99000
[ 0.092005] Brought up 2 CPUs
[ 0.092011] Total of 2 processors activated (5229.21 BogoMIPS).
[ 0.092011] System has AMD C1E enabled
[ 0.092050] Switch to broadcast mode on CPU1
[ 0.092870] Switch to broadcast mode on CPU0
[ 0.110240] PM: Registering ACPI NVS region at bffaa600 (219648 bytes)
[ 0.110417] xor: automatically using best checksumming function: generic_sse
[ 0.115006] generic_sse: 4164.000 MB/sec
[ 0.115011] xor: using function: generic_sse (4164.000 MB/sec)
[ 0.115085] NET: Registered protocol family 16
[ 0.116063] node 0 link 0: io port [1000, ffffff]
[ 0.116063] TOM: 00000000d0000000 aka 3328M
[ 0.116063] Fam 10h mmconf [mem 0xe0000000-0xefffffff]
[ 0.116063] node 0 link 0: mmio [a0000, bffff]
[ 0.116063] node 0 link 0: mmio [d0000000, efffffff] ==> [d0000000, dfffffff]
[ 0.116063] node 0 link 0: mmio [f0000000, fe5fffff]
[ 0.116063] node 0 link 0: mmio [fe600000, fe7fffff]
[ 0.116067] node 0 link 0: mmio [fe800000, ffdfffff]
[ 0.116074] TOM2: 0000000230000000 aka 8960M
[ 0.116080] bus: [00, 1f] on node 0 link 0
[ 0.116086] bus: 00 index 0 [io 0x0000-0xffff]
[ 0.116091] bus: 00 index 1 [mem 0x000a0000-0x000bffff]
[ 0.116097] bus: 00 index 2 [mem 0xd0000000-0xdfffffff]
[ 0.116103] bus: 00 index 3 [mem 0xf0000000-0xffffffff]
[ 0.116109] bus: 00 index 4 [mem 0x230000000-0xfcffffffff]
[ 0.116124] Extended Config Space enabled on 1 nodes
[ 0.116141] ACPI: bus type pci registered
[ 0.117063] PCI: MMCONFIG for domain 0000 [bus 00-ff] at [mem 0xe0000000-0xefffffff] (base 0xe0000000)
[ 0.117070] PCI: MMCONFIG at [mem 0xe0000000-0xefffffff] reserved in E820
[ 0.141526] PCI: Using configuration type 1 for base access
[ 0.149009] bio: create slab at 0
[ 0.166026] raid6: int64x1 1058 MB/s
[ 0.183021] raid6: int64x2 1640 MB/s
[ 0.200017] raid6: int64x4 1617 MB/s
[ 0.217017] raid6: int64x8 1121 MB/s
[ 0.233989] raid6: sse2x1 1644 MB/s
[ 0.250986] raid6: sse2x2 2156 MB/s
[ 0.267972] raid6: sse2x4 2316 MB/s
[ 0.267978] raid6: using algorithm sse2x4 (2316 MB/s)
[ 0.268046] ACPI: Added _OSI(Module Device)
[ 0.268046] ACPI: Added _OSI(Processor Device)
[ 0.268047] ACPI: Added _OSI(3.0 _SCP Extensions)
[ 0.268053] ACPI: Added _OSI(Processor Aggregator Device)
[ 0.269360] ACPI: EC: Look up EC in DSDT
[ 0.270708] ACPI: Executed 2 blocks of module-level executable AML code
[ 0.274247] [Firmware Bug]: ACPI: BIOS _OSI(Linux) query ignored
[ 0.277060] ACPI: OEMN 00000000bffaaeb0 00624 (v01 AMD NAHP 00000001 INTL 20051117)
[ 0.277440] ACPI: Dynamic OEM Table Load:
[ 0.277448] ACPI: OEMN (null) 00624 (v01 AMD NAHP 00000001 INTL 20051117)
[ 0.280167] \_SB_:_OSC evaluation returned wrong type
[ 0.280178] _OSC request data:1 17
[ 0.281829] ACPI: Interpreter enabled
[ 0.281838] ACPI: (supports S0 S4 S5)
[ 0.281865] ACPI: Using IOAPIC for interrupt routing
[ 0.299198] ACPI: No dock devices found.
[ 0.300055] HEST: Table parsing has been initialized.
[ 0.300055] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[ 0.300355] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[ 0.300441] pci_root PNP0A08:00: host bridge window [io 0x0000-0x0cf7]
[ 0.300441] pci_root PNP0A08:00: host bridge window [io 0x0d00-0xffff]
[ 0.300441] pci_root PNP0A08:00: host bridge window [mem 0x000a0000-0x000bffff]
[ 0.300441] pci_root PNP0A08:00: host bridge window [mem 0x000d0000-0x000dffff]
[ 0.300441] pci_root PNP0A08:00: host bridge window [mem 0xc0000000-0xdfffffff]
[ 0.300441] pci_root PNP0A08:00: host bridge window [mem 0xf0000000-0xfebfffff]
[ 0.300441] pci_root PNP0A08:00: ignoring host bridge window [mem 0x000d0000-0x000dffff] (conflicts with Adapter ROM [mem 0x000cf000-0x000d19ff])
[ 0.300441] pci 0000:00:00.0: [1022:9601] type 0 class 0x000600
[ 0.301050] pci 0000:00:01.0: [103c:9602] type 1 class 0x000604
[ 0.301112] pci 0000:00:04.0: [1022:9604] type 1 class 0x000604
[ 0.301171] pci 0000:00:04.0: PME# supported from D0 D3hot D3cold
[ 0.301179] pci 0000:00:04.0: PME# disabled
[ 0.301204] pci 0000:00:06.0: [1022:9606] type 1 class 0x000604
[ 0.301260] pci 0000:00:06.0: PME# supported from D0 D3hot D3cold
[ 0.301267] pci 0000:00:06.0: PME# disabled
[ 0.301347] pci 0000:00:11.0: [1002:4391] type 0 class 0x000106
[ 0.301376] pci 0000:00:11.0: reg 10: [io 0xd000-0xd007]
[ 0.301391] pci 0000:00:11.0: reg 14: [io 0xc000-0xc003]
[ 0.301406] pci 0000:00:11.0: reg 18: [io 0xb000-0xb007]
[ 0.301421] pci 0000:00:11.0: reg 1c: [io 0xa000-0xa003]
[ 0.301435] pci 0000:00:11.0: reg 20: [io 0x9000-0x900f]
[ 0.301450] pci 0000:00:11.0: reg 24: [mem 0xfe5ffc00-0xfe5fffff]
[ 0.301536] pci 0000:00:12.0: [1002:4397] type 0 class 0x000c03
[ 0.301556] pci 0000:00:12.0: reg 10: [mem 0xfe5fe000-0xfe5fefff]
[ 0.301642] pci 0000:00:12.2: [1002:4396] type 0 class 0x000c03
[ 0.301668] pci 0000:00:12.2: reg 10: [mem 0xfe5ff800-0xfe5ff8ff]
[ 0.301766] pci 0000:00:12.2: supports D1 D2
[ 0.301772] pci 0000:00:12.2: PME# supported from D0 D1 D2 D3hot
[ 0.301781] pci 0000:00:12.2: PME# disabled
[ 0.301810] pci 0000:00:13.0: [1002:4397] type 0 class 0x000c03
[ 0.301829] pci 0000:00:13.0: reg 10: [mem 0xfe5fd000-0xfe5fdfff]
[ 0.301916] pci 0000:00:13.2: [1002:4396] type 0 class 0x000c03
[ 0.301942] pci 0000:00:13.2: reg 10: [mem 0xfe5ff400-0xfe5ff4ff]
[ 0.302050] pci 0000:00:13.2: supports D1 D2
[ 0.302056] pci 0000:00:13.2: PME# supported from D0 D1 D2 D3hot
[ 0.302064] pci 0000:00:13.2: PME# disabled
[ 0.302093] pci 0000:00:14.0: [1002:4385] type 0 class 0x000c05
[ 0.302185] pci 0000:00:14.3: [1002:439d] type 0 class 0x000601
[ 0.302278] pci 0000:00:14.4: [1002:4384] type 1 class 0x000604
[ 0.302337] pci 0000:00:16.0: [1002:4397] type 0 class 0x000c03
[ 0.302356] pci 0000:00:16.0: reg 10: [mem 0xfe5fc000-0xfe5fcfff]
[ 0.302443] pci 0000:00:16.2: [1002:4396] type 0 class 0x000c03
[ 0.302469] pci 0000:00:16.2: reg 10: [mem 0xfe5ff000-0xfe5ff0ff]
[ 0.302567] pci 0000:00:16.2: supports D1 D2
[ 0.302573] pci 0000:00:16.2: PME# supported from D0 D1 D2 D3hot
[ 0.302581] pci 0000:00:16.2: PME# disabled
[ 0.302608] pci 0000:00:18.0: [1022:1200] type 0 class 0x000600
[ 0.302641] pci 0000:00:18.1: [1022:1201] type 0 class 0x000600
[ 0.302667] pci 0000:00:18.2: [1022:1202] type 0 class 0x000600
[ 0.302694] pci 0000:00:18.3: [1022:1203] type 0 class 0x000600
[ 0.302725] pci 0000:00:18.4: [1022:1204] type 0 class 0x000600
[ 0.302792] pci 0000:01:05.0: [1002:9712] type 0 class 0x000300
[ 0.302809] pci 0000:01:05.0: reg 10: [mem 0xd0000000-0xdfffffff pref]
[ 0.302820] pci 0000:01:05.0: reg 14: [io 0xe000-0xe0ff]
[ 0.302830] pci 0000:01:05.0: reg 18: [mem 0xfe7f0000-0xfe7fffff]
[ 0.302849] pci 0000:01:05.0: reg 24: [mem 0xfe600000-0xfe6fffff]
[ 0.302879] pci 0000:01:05.0: supports D1 D2
[ 0.302928] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.302937] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.302944] pci 0000:00:01.0: bridge window [mem 0xfe600000-0xfe7fffff]
[ 0.302954] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.303091] pci 0000:02:00.0: [14e4:1677] type 0 class 0x000200
[ 0.303119] pci 0000:02:00.0: reg 10: [mem 0xfe8f0000-0xfe8fffff 64bit]
[ 0.303173] pci 0000:02:00.0: reg 30: [mem 0xfe8e0000-0xfe8effff pref]
[ 0.303242] pci 0000:02:00.0: PME# supported from D3hot
[ 0.303252] pci 0000:02:00.0: PME# disabled
[ 0.303271] pci 0000:02:00.0: disabling ASPM on pre-1.1 PCIe device. You can enable it with 'pcie_aspm=force'
[ 0.303288] pci 0000:00:04.0: PCI bridge to [bus 02-02]
[ 0.303298] pci 0000:00:04.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.303368] pci 0000:03:00.0: [14e4:165b] type 0 class 0x000200
[ 0.303396] pci 0000:03:00.0: reg 10: [mem 0xfe9f0000-0xfe9fffff 64bit]
[ 0.303523] pci 0000:03:00.0: PME# supported from D3hot D3cold
[ 0.303533] pci 0000:03:00.0: PME# disabled
[ 0.305006] pci 0000:00:06.0: PCI bridge to [bus 03-03]
[ 0.305024] pci 0000:00:06.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.305107] pci 0000:00:14.4: PCI bridge to [bus 04-04] (subtractive decode)
[ 0.305122] pci 0000:00:14.4: bridge window [io 0x0000-0x0cf7] (subtractive decode)
[ 0.305131] pci 0000:00:14.4: bridge window [io 0x0d00-0xffff] (subtractive decode)
[ 0.305140] pci 0000:00:14.4: bridge window [mem 0x000a0000-0x000bffff] (subtractive decode)
[ 0.305149] pci 0000:00:14.4: bridge window [mem 0xc0000000-0xdfffffff] (subtractive decode)
[ 0.305157] pci 0000:00:14.4: bridge window [mem 0xf0000000-0xfebfffff] (subtractive decode)
[ 0.305181] pci_bus 0000:00: on NUMA node 0
[ 0.305193] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.305556] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
[ 0.305624] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCE4._PRT]
[ 0.305677] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PCE6._PRT]
[ 0.306025] pci0000:00: Requesting ACPI _OSC control (0x1d)
[ 0.306331] pci0000:00: ACPI _OSC control (0x1d) granted
[ 0.318064] ACPI: PCI Interrupt Link [LNKA] (IRQs 4 7 10 11 14 15) *0
[ 0.318172] ACPI: PCI Interrupt Link [LNKB] (IRQs 4 7 10 11 14 15) *0
[ 0.318274] ACPI: PCI Interrupt Link [LNKC] (IRQs 4 7 10 11 14 15) *0
[ 0.318371] ACPI: PCI Interrupt Link [LNKD] (IRQs 4 7 10 11 14 15) *0
[ 0.319018] ACPI: PCI Interrupt Link [LNKE] (IRQs 4 7 10 11 14 15) *0
[ 0.319082] ACPI: PCI Interrupt Link [LNKF] (IRQs 4 7 10 11 14 15) *0
[ 0.319144] ACPI: PCI Interrupt Link [LNKG] (IRQs 4 7 10 11 14 15) *0
[ 0.319208] ACPI: PCI Interrupt Link [LNKH] (IRQs 4 7 10 11 14 15) *0
[ 0.319255] vgaarb: device added: PCI:0000:01:05.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.319255] vgaarb: loaded
[ 0.319255] vgaarb: bridge control possible 0000:01:05.0
[ 0.319985] SCSI subsystem initialized
[ 0.320018] libata version 3.00 loaded.
[ 0.320018] PCI: Using ACPI for IRQ routing
[ 0.330176] PCI: pci_cache_line_size set to 64 bytes
[ 0.330277] reserve RAM buffer: 000000000009e800 - 000000000009ffff
[ 0.330284] reserve RAM buffer: 00000000bff90000 - 00000000bfffffff
[ 0.330316] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[ 0.330316] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[ 0.332008] Switching to clocksource hpet
[ 0.333113] pnp: PnP ACPI init
[ 0.333129] ACPI: bus type pnp registered
[ 0.333305] pnp 00:00: [bus 00-ff]
[ 0.333312] pnp 00:00: [io 0x0cf8-0x0cff]
[ 0.333319] pnp 00:00: [io 0x0000-0x0cf7 window]
[ 0.333325] pnp 00:00: [io 0x0d00-0xffff window]
[ 0.333332] pnp 00:00: [mem 0x000a0000-0x000bffff window]
[ 0.333339] pnp 00:00: [mem 0x000d0000-0x000dffff window]
[ 0.333345] pnp 00:00: [mem 0xc0000000-0xdfffffff window]
[ 0.333352] pnp 00:00: [mem 0xf0000000-0xfebfffff window]
[ 0.333539] pnp 00:00: Plug and Play ACPI device, IDs PNP0a08 PNP0a03 (active)
[ 0.334109] pnp 00:01: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.334117] pnp 00:01: [mem 0xc0000000-0xcfffffff]
[ 0.334322] system 00:01: [mem 0xc0000000-0xcfffffff] has been reserved
[ 0.334335] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.334438] pnp 00:02: [dma 4]
[ 0.334444] pnp 00:02: [io 0x0000-0x000f]
[ 0.334449] pnp 00:02: [io 0x0081-0x0083]
[ 0.334454] pnp 00:02: [io 0x0087]
[ 0.334459] pnp 00:02: [io 0x0089-0x008b]
[ 0.334464] pnp 00:02: [io 0x008f]
[ 0.334469] pnp 00:02: [io 0x00c0-0x00df]
[ 0.334648] pnp 00:02: Plug and Play ACPI device, IDs PNP0200 (active)
[ 0.334679] pnp 00:03: [io 0x0070-0x0071]
[ 0.334697] pnp 00:03: [irq 8]
[ 0.334888] pnp 00:03: Plug and Play ACPI device, IDs PNP0b00 (active)
[ 0.334979] pnp 00:04: [io 0x0061]
[ 0.335216] pnp 00:04: Plug and Play ACPI device, IDs PNP0800 (active)
[ 0.335247] pnp 00:05: [io 0x00f0-0x00ff]
[ 0.335261] pnp 00:05: [irq 13]
[ 0.335452] pnp 00:05: Plug and Play ACPI device, IDs PNP0c04 (active)
[ 0.335520] pnp 00:06: [mem 0xfed00000-0xfed003ff]
[ 0.335703] pnp 00:06: Plug and Play ACPI device, IDs PNP0103 (active)
[ 0.335859] pnp 00:07: [io 0x0060]
[ 0.335866] pnp 00:07: [io 0x0064]
[ 0.335871] pnp 00:07: [mem 0xfec00000-0xfec00fff]
[ 0.335877] pnp 00:07: [mem 0xfee00000-0xfee00fff]
[ 0.336092] system 00:07: [mem 0xfec00000-0xfec00fff] could not be reserved
[ 0.336101] system 00:07: [mem 0xfee00000-0xfee00fff] has been reserved
[ 0.336109] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.336346] pnp 00:08: [io 0x0010-0x001f]
[ 0.336353] pnp 00:08: [io 0x0022-0x003f]
[ 0.336358] pnp 00:08: [io 0x0062-0x0063]
[ 0.336364] pnp 00:08: [io 0x0065-0x006f]
[ 0.336369] pnp 00:08: [io 0x0072-0x007f]
[ 0.336375] pnp 00:08: [io 0x0080]
[ 0.336380] pnp 00:08: [io 0x0084-0x0086]
[ 0.336385] pnp 00:08: [io 0x0088]
[ 0.336390] pnp 00:08: [io 0x008c-0x008e]
[ 0.336395] pnp 00:08: [io 0x0090-0x009f]
[ 0.336401] pnp 00:08: [io 0x00a2-0x00bf]
[ 0.336406] pnp 00:08: [io 0x00b1]
[ 0.336411] pnp 00:08: [io 0x00e0-0x00ef]
[ 0.336417] pnp 00:08: [io 0x04d0-0x04d1]
[ 0.336422] pnp 00:08: [io 0x040b]
[ 0.336427] pnp 00:08: [io 0x04d6]
[ 0.336432] pnp 00:08: [io 0x0c00-0x0c01]
[ 0.336438] pnp 00:08: [io 0x0c14]
[ 0.336443] pnp 00:08: [io 0x0c50-0x0c51]
[ 0.336448] pnp 00:08: [io 0x0c52]
[ 0.336453] pnp 00:08: [io 0x0c6c]
[ 0.336458] pnp 00:08: [io 0x0c6f]
[ 0.336463] pnp 00:08: [io 0x0cd0-0x0cd1]
[ 0.336470] pnp 00:08: [io 0x0cd2-0x0cd3]
[ 0.336476] pnp 00:08: [io 0x0cd4-0x0cd5]
[ 0.336481] pnp 00:08: [io 0x0cd6-0x0cd7]
[ 0.336487] pnp 00:08: [io 0x0cd8-0x0cdf]
[ 0.336492] pnp 00:08: [io 0x0800-0x089f]
[ 0.336498] pnp 00:08: [io 0x0000-0xffffffffffffffff disabled]
[ 0.336504] pnp 00:08: [io 0x0b00-0x0b1f]
[ 0.336510] pnp 00:08: [io 0x0b20-0x0b3f]
[ 0.336515] pnp 00:08: [io 0x0900-0x090f]
[ 0.336520] pnp 00:08: [io 0x0910-0x091f]
[ 0.336526] pnp 00:08: [io 0xfe00-0xfefe]
[ 0.336531] pnp 00:08: [io 0x0060]
[ 0.336536] pnp 00:08: [io 0x0064]
[ 0.336542] pnp 00:08: [mem 0xffb80000-0xffbfffff]
[ 0.336548] pnp 00:08: [mem 0xfec10000-0xfec1001f]
[ 0.336554] pnp 00:08: [mem 0xfed80000-0xfed80fff]
[ 0.336560] pnp 00:08: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.336821] system 00:08: [io 0x04d0-0x04d1] has been reserved
[ 0.336832] system 00:08: [io 0x040b] has been reserved
[ 0.336839] system 00:08: [io 0x04d6] has been reserved
[ 0.336846] system 00:08: [io 0x0c00-0x0c01] has been reserved
[ 0.336853] system 00:08: [io 0x0c14] has been reserved
[ 0.336859] system 00:08: [io 0x0c50-0x0c51] has been reserved
[ 0.336866] system 00:08: [io 0x0c52] has been reserved
[ 0.336873] system 00:08: [io 0x0c6c] has been reserved
[ 0.336879] system 00:08: [io 0x0c6f] has been reserved
[ 0.336886] system 00:08: [io 0x0cd0-0x0cd1] has been reserved
[ 0.336892] system 00:08: [io 0x0cd2-0x0cd3] has been reserved
[ 0.336899] system 00:08: [io 0x0cd4-0x0cd5] has been reserved
[ 0.336906] system 00:08: [io 0x0cd6-0x0cd7] has been reserved
[ 0.336913] system 00:08: [io 0x0cd8-0x0cdf] has been reserved
[ 0.336920] system 00:08: [io 0x0800-0x089f] has been reserved
[ 0.336927] system 00:08: [io 0x0b00-0x0b1f] has been reserved
[ 0.336934] system 00:08: [io 0x0b20-0x0b3f] has been reserved
[ 0.336940] system 00:08: [io 0x0900-0x090f] has been reserved
[ 0.336947] system 00:08: [io 0x0910-0x091f] has been reserved
[ 0.336955] system 00:08: [io 0xfe00-0xfefe] has been reserved
[ 0.336964] system 00:08: [mem 0xffb80000-0xffbfffff] has been reserved
[ 0.336971] system 00:08: [mem 0xfec10000-0xfec1001f] has been reserved
[ 0.336980] system 00:08: [mem 0xfed80000-0xfed80fff] has been reserved
[ 0.336989] system 00:08: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.337100] pnp 00:09: [mem 0xe0000000-0xefffffff]
[ 0.337358] system 00:09: [mem 0xe0000000-0xefffffff] has been reserved
[ 0.337371] system 00:09: Plug and Play ACPI device, IDs PNP0c02 (active)
[ 0.337555] pnp 00:0a: [mem 0x00000000-0x0009ffff]
[ 0.337563] pnp 00:0a: [mem 0x00000000-0xffffffffffffffff disabled]
[ 0.337569] pnp 00:0a: [mem 0x000e0000-0x000fffff]
[ 0.337575] pnp 00:0a: [mem 0x00100000-0xbfffffff]
[ 0.337581] pnp 00:0a: [mem 0xfec00000-0xffffffff]
[ 0.337616] pnp 00:0a: [Firmware Bug]: [mem 0x00000000-0xffffffffffffffff disabled] covers only part of AMD MMCONFIG area [mem 0xe0000000-0xefffffff]; adding more reservations
[ 0.337861] system 00:0a: [mem 0x00000000-0x0009ffff] could not be reserved
[ 0.337873] system 00:0a: [mem 0x000e0000-0x000fffff] could not be reserved
[ 0.337881] system 00:0a: [mem 0x00100000-0xbfffffff] could not be reserved
[ 0.337888] system 00:0a: [mem 0xfec00000-0xffffffff] could not be reserved
[ 0.337898] system 00:0a: Plug and Play ACPI device, IDs PNP0c01 (active)
[ 0.338075] pnp: PnP ACPI: found 11 devices
[ 0.338081] ACPI: ACPI bus type pnp unregistered
[ 0.352394] PCI: max bus depth: 1 pci_try_num: 2
[ 0.352430] pci 0000:00:01.0: PCI bridge to [bus 01-01]
[ 0.352438] pci 0000:00:01.0: bridge window [io 0xe000-0xefff]
[ 0.352447] pci 0000:00:01.0: bridge window [mem 0xfe600000-0xfe7fffff]
[ 0.352455] pci 0000:00:01.0: bridge window [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.352466] pci 0000:00:04.0: PCI bridge to [bus 02-02]
[ 0.352473] pci 0000:00:04.0: bridge window [mem 0xfe800000-0xfe8fffff]
[ 0.352483] pci 0000:00:06.0: PCI bridge to [bus 03-03]
[ 0.352491] pci 0000:00:06.0: bridge window [mem 0xfe900000-0xfe9fffff]
[ 0.352501] pci 0000:00:14.4: PCI bridge to [bus 04-04]
[ 0.352549] pci 0000:00:04.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 0.352558] pci 0000:00:04.0: setting latency timer to 64
[ 0.352573] pci 0000:00:06.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 0.352581] pci 0000:00:06.0: setting latency timer to 64
[ 0.352594] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7]
[ 0.352600] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff]
[ 0.352607] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.352613] pci_bus 0000:00: resource 7 [mem 0xc0000000-0xdfffffff]
[ 0.352620] pci_bus 0000:00: resource 8 [mem 0xf0000000-0xfebfffff]
[ 0.352627] pci_bus 0000:01: resource 0 [io 0xe000-0xefff]
[ 0.352633] pci_bus 0000:01: resource 1 [mem 0xfe600000-0xfe7fffff]
[ 0.352640] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xdfffffff 64bit pref]
[ 0.352648] pci_bus 0000:02: resource 1 [mem 0xfe800000-0xfe8fffff]
[ 0.352655] pci_bus 0000:03: resource 1 [mem 0xfe900000-0xfe9fffff]
[ 0.352662] pci_bus 0000:04: resource 4 [io 0x0000-0x0cf7]
[ 0.352668] pci_bus 0000:04: resource 5 [io 0x0d00-0xffff]
[ 0.352675] pci_bus 0000:04: resource 6 [mem 0x000a0000-0x000bffff]
[ 0.352682] pci_bus 0000:04: resource 7 [mem 0xc0000000-0xdfffffff]
[ 0.352688] pci_bus 0000:04: resource 8 [mem 0xf0000000-0xfebfffff]
[ 0.352801] NET: Registered protocol family 2
[ 0.352935] IP route cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.354182] TCP established hash table entries: 262144 (order: 10, 4194304 bytes)
[ 0.356161] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[ 0.356702] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.356710] TCP reno registered
[ 0.356718] UDP hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.356810] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes)
[ 0.357049] NET: Registered protocol family 1
[ 0.357283] RPC: Registered named UNIX socket transport module.
[ 0.357302] RPC: Registered udp transport module.
[ 0.357308] RPC: Registered tcp transport module.
[ 0.357313] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.357332] pci 0000:00:01.0: MSI quirk detected; subordinate MSI disabled
[ 0.357389] pci 0000:00:12.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.168124] pci 0000:00:12.0: PCI INT A disabled
[ 1.168171] pci 0000:00:12.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.168225] pci 0000:00:12.2: PCI INT B disabled
[ 1.168239] pci 0000:00:13.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.241148] pci 0000:00:13.0: PCI INT A disabled
[ 1.241179] pci 0000:00:13.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.241237] pci 0000:00:13.2: PCI INT B disabled
[ 1.241260] pci 0000:00:16.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 1.314147] pci 0000:00:16.0: PCI INT A disabled
[ 1.314177] pci 0000:00:16.2: PCI INT B -> GSI 17 (level, low) -> IRQ 17
[ 1.314233] pci 0000:00:16.2: PCI INT B disabled
[ 1.314254] pci 0000:01:05.0: Boot video device
[ 1.314271] PCI: CLS 64 bytes, default 64
[ 1.887483] PCI-DMA: Disabling AGP.
[ 1.887668] PCI-DMA: aperture base @ b4000000 size 65536 KB
[ 1.887674] PCI-DMA: using GART IOMMU.
[ 1.887681] PCI-DMA: Reserving 64MB of IOMMU area in the AGP aperture
[ 1.915080] IBS: LVT offset 1 assigned
[ 1.915110] perf: AMD IBS detected (0x0000001f)
[ 1.951351] VFS: Disk quotas dquot_6.5.2
[ 1.951423] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.951664] Registering the id_resolver key type
[ 1.951899] msgmni has been set to 15451
[ 1.951956] async_tx: api initialized (async)
[ 1.952947] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 1.952958] io scheduler noop registered
[ 1.952963] io scheduler deadline registered
[ 1.952989] io scheduler cfq registered (default)
[ 1.953578] pcieport 0000:00:04.0: setting latency timer to 64
[ 1.953629] pcieport 0000:00:04.0: irq 40 for MSI/MSI-X
[ 1.954864] pcieport 0000:00:06.0: setting latency timer to 64
[ 1.954906] pcieport 0000:00:06.0: irq 41 for MSI/MSI-X
[ 1.964850] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 1.971621] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 1.971634] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 1.975452] vesafb: mode is 1280x1024x8, linelength=1280, pages=11
[ 1.975463] vesafb: scrolling: redraw
[ 1.975470] vesafb: Pseudocolor: size=8:8:8:8, shift=0:0:0:0
[ 1.975781] vesafb: framebuffer at 0xd0000000, mapped to 0xffffc90010100000, using 2560k, total 16384k
[ 2.058662] Console: switching to colour frame buffer device 160x64
[ 2.138486] fb0: VESA VGA frame buffer device
[ 2.139546] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[ 2.140331] ACPI: Power Button [PWRB]
[ 2.140858] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[ 2.141545] ACPI: Power Button [PWRF]
[ 2.145833] APEI: Can not request iomem region <00000000bffc21ea-00000000bffc21ec> for GARs.
[ 2.146664] [Firmware Warn]: GHES: Poll interval is 0 for generic hardware error source: 1, disabled.
[ 2.149298] GHES: APEI firmware first mode is enabled by WHEA _OSC.
[ 2.896062] Refined TSC clocksource calibration: 1297.838 MHz.
[ 2.896570] Switching to clocksource tsc
[ 3.151484] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 3.277393] brd: module loaded
[ 3.285599] Loading iSCSI transport class v2.0-870.
[ 3.319352] rdac: device handler registered
[ 3.327418] ahci 0000:00:11.0: version 3.0
[ 3.327850] ahci 0000:00:11.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[ 3.328536] ahci 0000:00:11.0: irq 42 for MSI/MSI-X
[ 3.329121] ahci 0000:00:11.0: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[ 3.329816] ahci 0000:00:11.0: flags: 64bit ncq sntf ilck pm led clo pmp pio slum part sxs
[ 3.363474] scsi0 : ahci
[ 3.369929] scsi1 : ahci
[ 3.374442] scsi2 : ahci
[ 3.376107] scsi3 : ahci
[ 3.380639] scsi4 : ahci
[ 3.384706] scsi5 : ahci
[ 3.387125] ata1: SATA max UDMA/133 abar m1024@0xfe5ffc00 port 0xfe5ffd00 irq 42
[ 3.387798] ata2: SATA max UDMA/133 abar m1024@0xfe5ffc00 port 0xfe5ffd80 irq 42
[ 3.388481] ata3: SATA max UDMA/133 abar m1024@0xfe5ffc00 port 0xfe5ffe00 irq 42
[ 3.389149] ata4: SATA max UDMA/133 abar m1024@0xfe5ffc00 port 0xfe5ffe80 irq 42
[ 3.389811] ata5: SATA max UDMA/133 abar m1024@0xfe5ffc00 port 0xfe5fff00 irq 42
[ 3.390476] ata6: SATA max UDMA/133 abar m1024@0xfe5ffc00 port 0xfe5fff80 irq 42
[ 3.851131] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 3.856186] ata1.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[ 3.856760] ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 3.881187] ata1.00: configured for UDMA/133
[ 3.905211] scsi 0:0:0:0: Direct-Access WDC WD20EARS-00MVWB0 51.0 PQ: 0 ANSI: 5
[ 3.926553] syno_disk_type_get: disk driver 'ahci'
[ 3.926965] syno_disk_type_get: SATA syno_port_type 1
[ 3.967618] sd_probe: Got SATA dev_prefix (sd), index (0), disk_name (), disk_len (20)
[ 3.989485] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.011591] sd 0:0:0:0: [sda] Write Protect is off
[ 4.032454] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 4.053316] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4.107772] sda: sda1 sda2 sda3 < sda5 >
[ 4.132218] sd 0:0:0:0: [sda] Attached SCSI disk
[ 4.490139] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 4.515837] ata2.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[ 4.537776] ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 4.564857] ata2.00: configured for UDMA/133
[ 4.591179] scsi 1:0:0:0: Direct-Access WDC WD20EARS-00MVWB0 51.0 PQ: 0 ANSI: 5
[ 4.614437] syno_disk_type_get: disk driver 'ahci'
[ 4.614855] syno_disk_type_get: SATA syno_port_type 1
[ 4.659214] sd_probe: Got SATA dev_prefix (sd), index (1), disk_name (), disk_len (20)
[ 4.682706] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 4.708293] sd 1:0:0:0: [sdb] Write Protect is off
[ 4.730893] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[ 4.753521] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 4.805334] sdb: sdb1 sdb2 sdb3 < sdb5 >
[ 4.830901] sd 1:0:0:0: [sdb] Attached SCSI disk
[ 5.166127] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 5.192412] ata3.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[ 5.214387] ata3.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 5.241443] ata3.00: configured for UDMA/133
[ 5.267311] scsi 2:0:0:0: Direct-Access WDC WD20EARS-00MVWB0 51.0 PQ: 0 ANSI: 5
[ 5.289735] syno_disk_type_get: disk driver 'ahci'
[ 5.290162] syno_disk_type_get: SATA syno_port_type 1
[ 5.332252] sd_probe: Got SATA dev_prefix (sd), index (2), disk_name (), disk_len (20)
[ 5.354517] sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 5.378714] sd 2:0:0:0: [sdc] Write Protect is off
[ 5.399950] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[ 5.421176] sd 2:0:0:0: [sdc] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 5.477001] sdc: sdc1 sdc2 sdc3 < sdc5 >
[ 5.501691] sd 2:0:0:0: [sdc] Attached SCSI disk
[ 5.836140] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 5.859848] ata4.00: ATA-8: ST2000DM001-9YN164, CC4H, max UDMA/133
[ 5.881662] ata4.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[ 5.904327] ata4.00: configured for UDMA/133
[ 5.926715] scsi 3:0:0:0: Direct-Access ATA ST2000DM001-9YN164 CC4H PQ: 0 ANSI: 5
[ 5.949327] syno_disk_type_get: disk driver 'ahci'
[ 5.949738] syno_disk_type_get: SATA syno_port_type 1
[ 5.994019] sd_probe: Got SATA dev_prefix (sd), index (3), disk_name (), disk_len (20)
[ 6.017982] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[ 6.041563] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[ 6.065568] sd 3:0:0:0: [sdd] Write Protect is off
[ 6.089105] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[ 6.112874] sd 3:0:0:0: [sdd] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 6.144196] sdd: sdd1 sdd2 sdd3 < sdd5 >
[ 6.171073] sd 3:0:0:0: [sdd] Attached SCSI disk
[ 6.440126] ata5: SATA link down (SStatus 0 SControl 300)
[ 6.925125] ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[ 6.951115] ata6.00: failed to enable AA (error_mask=0x1)
[ 6.976305] ata6.00: ATA-8: VB0250EAVER, HPG0, max UDMA/100
[ 7.001394] ata6.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32)
[ 7.027471] ata6.00: failed to enable AA (error_mask=0x1)
[ 7.052478] ata6.00: configured for UDMA/100
[ 7.078108] scsi 5:0:0:0: Direct-Access ATA VB0250EAVER HPG0 PQ: 0 ANSI: 5
[ 7.104065] syno_disk_type_get: disk driver 'ahci'
[ 7.104483] syno_disk_type_get: SATA syno_port_type 1
[ 7.153780] sd_probe: Got SATA dev_prefix (sd), index (5), disk_name (), disk_len (20)
[ 7.179708] sd 5:0:0:0: [sdf] 488397168 512-byte logical blocks: (250 GB/232 GiB)
[ 7.212211] sd 5:0:0:0: [sdf] Write Protect is off
[ 7.237209] sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[ 7.261911] sd 5:0:0:0: [sdf] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[ 7.289705] i8042: PNP: No PS/2 controller found. Probing ports directly.
[ 7.330849] sdf: sdf1 sdf2 sdf3 < sdf5 >
[ 7.890621] sd 5:0:0:0: [sdf] Attached SCSI disk
[ 8.363487] i8042: No controller found
[ 8.388408] rtc_cmos 00:03: RTC can wake from S4
[ 8.413476] rtc_cmos 00:03: rtc core: registered rtc_cmos as rtc0
[ 8.438029] rtc0: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[ 8.463518] i2c /dev entries driver
[ 8.488288] md: linear personality registered for level -1
[ 8.512661] md: raid0 personality registered for level 0
[ 8.536919] md: raid1 personality registered for level 1
[ 8.561020] md: raid10 personality registered for level 10
[ 8.584939] md: raid6 personality registered for level 6
[ 8.608541] md: raid5 personality registered for level 5
[ 8.631913] md: raid4 personality registered for level 4
[ 8.655290] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 8.678794] cpuidle: using governor ladder
[ 8.702003] cpuidle: using governor menu
[ 8.725319] TCP cubic registered
[ 8.747878] NET: Registered protocol family 17
[ 8.770302] Registering the dns_resolver key type
[ 8.794885] rtc_cmos 00:03: setting system clock to 2014-03-23 15:42:48 UTC (1395589368)
[ 8.824951] Freeing unused kernel memory: 14860k freed
[ 8.854649] Write protecting the kernel read-only data: 6144k
[ 8.881156] Freeing unused kernel memory: 548k freed
[ 8.906073] Freeing unused kernel memory: 268k freed
[ 9.843237] Loading modules backported from Linux version v3.12.8-0-g97f15f1
[ 9.857644] Backport generated by backports.git v3.12.8-1-0-geb41fad
[ 10.024336] tulip: Linux Tulip driver version 1.1.15 (Feb 27, 2007)
[ 10.088239] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
[ 10.126873] dca service started, version 1.12.1
[ 10.166635] e100: Intel® PRO/100 Network Driver, 3.5.24-k2-NAPI
[ 10.182174] e100: Copyright© 1999-2006 Intel Corporation
[ 10.225267] e1000: Intel® PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[ 10.241744] e1000: Copyright © 1999-2006 Intel Corporation.
[ 10.287884] e1000e_new: Intel® PRO/1000 Network Driver - 3.0.4-NAPI
[ 10.305870] e1000e_new: Copyright© 1999 - 2014 Intel Corporation.
[ 10.353460] ioatdma: Intel® QuickData Technology Driver 4.00
[ 10.402446] Intel® Gigabit Ethernet Network Driver - version 5.0.6
[ 10.421657] Copyright © 2007-2013 Intel Corporation.
[ 10.471858] ixgb: Intel® PRO/10GbE Network Driver - version 1.0.135-k2-NAPI
[ 10.492527] ixgb: Copyright © 1999-2008 Intel Corporation.
[ 10.545256] ixgbe: Intel® 10 Gigabit PCI Express Network Driver - version 3.6.7-k
[ 10.588218] ixgbe: Copyright © 1999-2011 Intel Corporation.
[ 10.899917] tg3.c:v3.133d (August 07, 2013)
[ 10.899921]
[ 10.946085] tg3 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
[ 10.969996] tg3 0000:02:00.0: setting latency timer to 64
[ 11.018422] pcieport 0000:00:04.0: eth0: Tigon3 [partno(BCM95751A519) rev 4001] (PCI Express) MAC address 00:07:11:04:42:66
[ 11.043830] pcieport 0000:00:04.0: eth0: attached PHY is 5750 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 11.069592] pcieport 0000:00:04.0: eth0: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 11.095662] pcieport 0000:00:04.0: eth0: dma_rwctrl[76180000] dma_mask[64-bit]
[ 11.122026] tg3 0000:03:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[ 11.148710] tg3 0000:03:00.0: setting latency timer to 64
[ 11.233190] pcieport 0000:00:06.0: eth1: Tigon3 [partno(BCM95723) rev 5784100] (PCI Express) MAC address 3c:4a:92:74:55:66
[ 11.261265] pcieport 0000:00:06.0: eth1: attached PHY is 5784 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[ 11.289708] pcieport 0000:00:06.0: eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[ 11.318510] pcieport 0000:00:06.0: eth1: dma_rwctrl[76180000] dma_mask[64-bit]
[ 11.387177] 8139cp: 8139cp: 10/100 PCI Ethernet driver v1.3 (Mar 22, 2004)
[ 11.456177] 8139too: 8139too Fast Ethernet driver 0.9.28
[ 11.611198] via_rhine: v1.10-LK1.5.0 2010-10-09 Written by Donald Becker
[ 11.808551] sky2: driver version 1.30
[ 11.958708] Atheros® L2 Ethernet Driver - version 2.2.3
[ 11.986972] Copyright © 2007 Atheros Corporation.
[ 12.130843] jme: JMicron JMC2XX ethernet driver version 1.0.8
[ 12.231780] sis900.c: v1.08.10 Apr. 2 2006
[ 12.331303] Brocade 10G Ethernet driver - version: 3.0.2.2
[ 12.395166] bnx2x: Broadcom NetXtreme II 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.70.30-0 (2011/10/25)
[ 12.482567] NET: Registered protocol family 10
[ 12.543402] cnic: Broadcom NetXtreme II CNIC Driver cnic v2.5.7 (July 20, 2011)
[ 12.737109] cxgb4vf: could not create debugfs entry, continuing
[ 12.869980] QLogic/NetXen Network Driver v4.0.77
[ 12.967319] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.0.25
[ 13.063722] enic: Cisco VIC Ethernet NIC Driver, ver 2.1.1.28
[ 13.191437] iscsi: registered transport (tcp)
[ 14.180514] stex: Promise SuperTrak EX Driver version: 4.6.0000.4
[ 14.381036] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 14.392190] sd 1:0:0:0: Attached scsi generic sg1 type 0
[ 14.404236] sd 2:0:0:0: Attached scsi generic sg2 type 0
[ 14.415813] sd 3:0:0:0: Attached scsi generic sg3 type 0
[ 14.426820] sd 5:0:0:0: Attached scsi generic sg4 type 0
[ 14.504611] Fusion MPT base driver 3.04.20
[ 14.515008] Copyright © 1999-2008 LSI Corporation
[ 14.568165] Fusion MPT SPI Host driver 3.04.20
[ 14.599302] Fusion MPT SAS Host driver 3.04.20
[ 14.632328] mpt2sas version 13.100.00.00 loaded
[ 14.666767] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[ 14.713302] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[ 14.751051] megasas: 00.00.06.12-rc1 Wed. Oct. 5 17:00:00 PDT 2011
[ 14.791501] Adaptec aacraid driver 1.1-7[28000]-ms
[ 14.835174] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[ 15.031952] mv61xx: module license 'Proprietary' taints kernel.
[ 15.049744] Disabling lock debugging due to kernel taint
[ 15.100951] 3ware Storage Controller device driver for Linux v1.26.02.003.
[ 15.151572] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[ 15.225920] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[ 15.304402] RocketRAID 3xxx/4xxx Controller driver v1.6 (090910)
[ 15.440236] md: Autodetecting RAID arrays.
[ 15.504422] md: invalid raid superblock magic on sda5
[ 15.528601] md: sda5 does not have a valid v0.90 superblock, not importing!
[ 15.611996] md: invalid raid superblock magic on sdb5
[ 15.636711] md: sdb5 does not have a valid v0.90 superblock, not importing!
[ 15.722584] md: invalid raid superblock magic on sdc5
[ 15.748238] md: sdc5 does not have a valid v0.90 superblock, not importing!
[ 15.812723] md: invalid raid superblock magic on sdd5
[ 15.839206] md: sdd5 does not have a valid v0.90 superblock, not importing!
[ 15.902988] md: invalid raid superblock magic on sdf5
[ 15.929917] md: sdf5 does not have a valid v0.90 superblock, not importing!
[ 15.956638] md: Scanned 15 and added 10 devices.
[ 15.983536] md: autorun ...
[ 16.010469] md: considering sda1 ...
[ 16.037623] md: adding sda1 ...
[ 16.064496] md: sda2 has different UUID to sda1
[ 16.091499] md: adding sdb1 ...
[ 16.118524] md: sdb2 has different UUID to sda1
[ 16.145447] md: adding sdc1 ...
[ 16.171793] md: sdc2 has different UUID to sda1
[ 16.198084] md: adding sdd1 ...
[ 16.224340] md: sdd2 has different UUID to sda1
[ 16.250567] md: adding sdf1 ...
[ 16.276425] md: sdf2 has different UUID to sda1
[ 16.302157] md: created md0
[ 16.327468] md: bind
[ 16.352386] md: bind
[ 16.376820] md: bind
[ 16.400568] md: bind
[ 16.423619] md: bind
[ 16.446654] md: running:
[ 16.469756] bio: create slab at 1
[ 16.492371] md/raid1:md0: active with 5 out of 12 mirrors
[ 16.514595] md0: detected capacity change from 0 to 2549940224
[ 16.536756] md: considering sda2 ...
[ 16.558343] md: adding sda2 ...
[ 16.579436] md: adding sdb2 ...
[ 16.599887] md: adding sdc2 ...
[ 16.619688] md: adding sdd2 ...
[ 16.639364] md: adding sdf2 ...
[ 16.659722] md: created md1
[ 16.679566] md: bind
[ 16.699388] md: bind
[ 16.719296] md: bind
[ 16.738695] md: bind
[ 16.757269] md: bind
[ 16.775464] md: running:
[ 16.793959] md/raid1:md1: active with 5 out of 12 mirrors
[ 16.811760] md1: detected capacity change from 0 to 2147418112
[ 16.829428] md: ... autorun DONE.
[ 16.846555] md1: unknown partition table
[ 16.917797] synobios: load, major number 201
[ 16.934052] Brand: Synology
[ 16.949795] Model: DS-3612xs
[ 16.965047] set group disks wakeup number to 4, spinup time deno 7
[ 17.031683] synobios: unload
[ 17.143584] md0: unknown partition table
[ 18.185634] EXT4-fs (md0): barriers disabled
[ 18.212030] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
  • 1 month later...
Hello davurleon
Did you had a chance to find a solution for your issue with network speed ?
I'm in the exact same situation with Nanoboot on ESXI with DSM 5.0.
I've tried many things including changing from e1000 eto vmxnet3 in Esxi with no success...
Thanks to share if you've solved it :smile:
whats the result of running
dmesg | grep "eth"
eg should look something like
MicroDS> dmesg | grep "eth"
[    3.963415] jme: JMicron JMC2XX ethernet driver version 1.0.8
[    5.683880] e1000e 0000:02:00.0: eth0: (PCI Express:2.5GT/s:Width x1) 00:1b:21:c2:82:72
[    5.683973] e1000e 0000:02:00.0: eth0: Intel(R) PRO/1000 Network Connection
[    5.684039] e1000e 0000:02:00.0: eth0: MAC: 3, PHY: 8, PBA No: E46981-006
[    5.747672] pcieport 0000:00:06.0: eth1: Tigon3 [partno(BCM95723) rev 5784100] (PCI Express) MAC address 3c:d9:2b:02:0c:ca
[    5.747769] pcieport 0000:00:06.0: eth1: attached PHY is 5784 (10/100/1000Base-T Ethernet) (WireSpeed[1], EEE[0])
[    5.747823] pcieport 0000:00:06.0: eth1: RXcsums[1] LinkChgREG[0] MIirq[0] ASF[0] TSOcap[1]
[    5.747874] pcieport 0000:00:06.0: eth1: dma_rwctrl[76180000] dma_mask[64-bit]
[   12.026424] usbcore: registered new interface driver ethub
[   13.135052] ADDRCONF(NETDEV_UP): eth0: link is not ready
[   13.967390] ADDRCONF(NETDEV_UP): eth1: link is not ready
[   15.395072] e1000e: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: Rx/Tx <<<<<<<<<<<<<<<<<<<<<<<<<<<<<[   15.398447] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   16.327801] pcieport 0000:00:06.0: eth1: Link is up at 1000 Mbps, full duplex <<<<<<<<<<<<<<<<<<<<<<<<<<[   16.327801] pcieport 0000:00:06.0: eth1: Flow control is off for TX and off for RX
[   16.332294] ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[   25.874082] eth0: no IPv6 routers present
Make note, mine has an extra Intel CT Single port card installed.......eth0....but eth1 (onboard broadcom Tigon3) should show connection @ 1000 Mbps
Thanks
I think I've found the issue ...
On Esxi I do have :
~ # dmesg | grep vmnic
2014-05-22T16:15:52.013Z cpu0:33268)<6>tg3 : vmnic0: Link is up at 1000 Mbps, full duplex
2014-05-22T16:15:52.013Z cpu0:33268)<6>tg3 : vmnic0: Flow control is on for TX and on for RX
and
~ # ethtool -a vmnic0
Pause parameters for vmnic0:
Autonegotiate:	on
RX:		on
TX:		on
but on diskstation I do have :
[    2.339313] e1000 0000:02:00.0: eth0: (PCI:66MHz:32-bit) 00:0c:29:30:6d:ff
[    2.339321] e1000 0000:02:00.0: eth0: Intel(R) PRO/1000 Network Connection
[   11.247262] e1000: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: None  <-------------------- Issue
[   11.250943] ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
So the Flow control is Off on the VM ...
I will have to check how to change this and check the difference.
Thanks for the idea :smile:
DiskStation> ethtool -A eth0 rx on
and
DiskStation> ethtool -A eth0 tx on
looks to change the settings (at least for the RX)
result in dmesg is :
[ 1082.867745] e1000: eth0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Will check how to test speed and maybe enable the TX as well.
Cheers
