blackwinds Posted December 31, 2018 Share #1 Posted December 31, 2018 I setup a Dell T20 with DS3615xs of Jun's loader. I did check the hardware compatibility list. Then I bought a Kinivo BTD-400 Bluetooth dongle because it is in the list. When I connect it, it doesn't work. The blue light is up. I did check dmesg and /var/log/messages. I found the firmware is missing. It seems to me the DS3615XS doesn't support it at all. Never mind, I download the firmware and put it in /lib/firmware/brcm folder. Then I found there is maybe a bug for this BT support because when I direct plug the dongle in, the DSM expects BCM20702A0-0a5c-21e8.hcd. But when I reboot, it asks for "BCM920702 Bluetooth 4.0-0a5c-21e8.hcd". It is so upset. Do they really have QE? Anyway, I put both name in that folder. Then check the log again, it seems like the firmware is loaded successfully. However, the kernel suddently killed it. 2018-12-30T03:06:34-08:00 DiskStation [ 1916.840592] init: bluetoothd main process (26477) killed by KILL signal 2018-12-30T03:07:30-08:00 DiskStation bluetoothd[8747]: Failed to open RFKILL control device 2018-12-30T03:07:31-08:00 DiskStation bluetoothd[8747]: Unknown command complete for opcode 19 There are no further information provided. I don't know what can I do now. Can anybody give some clue? I did check the bluetoothd service, it is disabled. I enabled it manually but it still the same. It doesn't work. There is nothing showing up from control panel -> wireless -> bluetooth. I checked hdiconfig -a, it looks good. thanks Quote Link to comment Share on other sites More sharing options...
blackwinds Posted December 31, 2018 Author Share #2 Posted December 31, 2018 admin@DiskStation:~$ dmesg | grep -i blue [ 16.954370] Bluetooth: Core ver 2.19 [ 16.954385] Bluetooth: HCI device and connection manager initialized [ 16.954392] Bluetooth: HCI socket layer initialized [ 16.954393] Bluetooth: L2CAP socket layer initialized [ 16.954397] Bluetooth: SCO socket layer initialized [ 16.956755] Bluetooth: RFCOMM socket layer initialized [ 16.956760] Bluetooth: RFCOMM ver 1.11 [ 16.957633] Bluetooth: HIDP (Human Interface Emulation) ver 1.2 [ 16.957637] Bluetooth: HIDP socket layer initialized [ 16.977731] Bluetooth: hci0: BCM: patching hci_ver=06 hci_rev=153a lmp_ver=06 lmp_subver=220e [ 17.582244] Bluetooth: hci0: BCM: firmware hci_ver=06 hci_rev=153a lmp_ver=06 lmp_subver=220e Quote Link to comment Share on other sites More sharing options...
blackwinds Posted December 31, 2018 Author Share #3 Posted December 31, 2018 admin@DiskStation:~$ hciconfig -a hci0: Type: BR/EDR Bus: USB BD Address: 5C:F3:70:92:D5:8F ACL MTU: 1021:8 SCO MTU: 64:1 UP RUNNING PSCAN RX bytes:37487 acl:0 sco:0 events:612 errors:0 TX bytes:36935 acl:0 sco:0 commands:609 errors:0 Features: 0xbf 0xfe 0xcf 0xfe 0xdb 0xff 0x7b 0x87 Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3 Link policy: RSWITCH SNIFF Link mode: SLAVE ACCEPT Name: 'DiskStation-0' Class: 0x6c0100 Service Classes: Rendering, Capturing, Audio, Telephony Device Class: Computer, Uncategorized HCI Version: 4.0 (0x6) Revision: 0x153a LMP Version: 4.0 (0x6) Subversion: 0x220e Manufacturer: Broadcom Corporation (15) Quote Link to comment Share on other sites More sharing options...
blackwinds Posted December 31, 2018 Author Share #4 Posted December 31, 2018 sudo cat /var/log/messages | grep -i blue ... 2018-12-31T02:40:37-08:00 DiskStation [84869.599934] init: bluetoothd main process (23812) killed by KILL signal 2018-12-31T02:41:38-08:00 DiskStation bluetoothd[8765]: Failed to open RFKILL control device 2018-12-31T02:41:39-08:00 DiskStation bluetoothd[8765]: Unknown command complete for opcode 19 Quote Link to comment Share on other sites More sharing options...
blackwinds Posted December 31, 2018 Author Share #5 Posted December 31, 2018 sudo cat /var/log/upstart/bluetoothd.log ... 2018-12-31T02:40:32-0800 btacd stoped. 2018-12-31T02:41:38-0800 Mon Dec 31 02:41:38 PST 2018 2018-12-31T02:41:38-0800 start bluetoothd 2018-12-31T02:41:38-0800 going to start btacd 2018-12-31T02:41:38-0800 btacd started. Quote Link to comment Share on other sites More sharing options...
