Sickgear issue
siri_uk
Hi guys
I'm running xpenology on a hp gen 8, loader 1.03b. Over the last week or so I've been having issues with Sickgear. I'm using sabtosickbeard that has been working perfectly it snatches ok, send to sabnzb, there then seems to be script error so Sickgear does not rename and move the file. The error I get is:-
[3f7a7e26590e4bf8b252a5bd3629988e] Direct Unpack - Unpacked 1 files/folders in 3 seconds
Script
Exit(1) AttributeError: 'module' object has no attribute 'Session' (Mo R4re)
Loading config from /usr/local/sickbeard-custom/var/SickBeard/autoProcessTV/autoProcessTV.cfg Opening URL: https://localhost:21220/home/postprocess/processEpisode Traceback (most recent call last): File "/usr/local/sickbeard-custom/var/SickBeard/autoProcessTV/sabToSickBeard.py", line 30, in autoProcessTV.processEpisode(sys.argv[1], sys.argv[2], sys.argv[7]) File "/volume1/@appstore/sickbeard-custom/var/SickBeard/autoProcessTV/autoProcessTV.py", line 138, in processEpisode sess = requests.Session() AttributeError: 'module' object has no attribute 'Session'
