Xpenology 5.4458 and DS audio
davurleon
Hi!
Sorry if this i a noob question, but I used DS audio on my android a lot when I was running DSM 4.3 on my N36L and it worked perfectly streaming my music. However, today I updated to gnoboot/5.4458 which feels like a great update, it it smoother and prettier, but suddenly DS audio always says that "network is not available now" and I have no idea what could be causing the problem, anyone out there knows???
This problom is easy to be solved.
You should find the file(menu_alpha.lst in gnoboot-alpha10.3-vfat.img).
And you should change it as follows.
------- menu_alpha.lst----------
timeout 5
default 0
fallback 1
title gnoboot-alpha
root (hd0,0)
kernel /zImage sn=B3JN00001 <= changed!!
title main menu
configfile (hd0,0)/boot/grub/menu.lst
DS audio wil be working!!
Edited by Guest
And you should change it as followw.
timeout 5
default 0
fallback 1
title gnoboot-alpha
root (hd0,0)
title main menu
YOU ARE A GOD. Thank you very much for this fix. it worked like a charm.
:grin::grin::grin::grin::grin::grin::grin::grin:
timeout 5
default 0
fallback 1
title gnoboot-alpha
root (hd0,0)
title main menu
it's don't work for me! Can you help me please?
I correctly change this file, and reboot my DSM (5.0 gnoboot-alpha 10.4), but after that, no change.
(I'm French)
  • 1 month later...
  • 3 weeks later...
You need to connect to your NAS with a SSH tool like "putty". Login with the user "root" and your password.
Once logged in you type
cd volumeUSB1/usbshare/boot/grub/
"volumeUSB1" could differ from your configuration. I use a USB-Stickt to boot with gnoboot.
Next:
vi menu_alpha.lst
This opens the file "menu_alpha.lst" with the vi editor. Within the editor you put the cursor where you want to edit, then press "i", wow you are in "edit-mode". Make your changes and afterwards press "Esc" to quit "edit-mode". After this type ":wq" which will write the changes to the file and quit the editor. Done! Not sure if you need to reboot after the changes, I did...
BTW @quantum: You are my personal hero of the week! Could you share some light on the issue why "sn=B3JN00001" is needed?
Greetings!
  • 1 month later...
timeout 5
default 0
fallback 1
title gnoboot-alpha
root (hd0,0)
title main menu
Unable to edit menu_alpha.lst as it is read only file! How do we get around of this
