Serial connection (bare metal)
Vileserver
Hi, I'm trying to connect to my bare metal XPenology box (Intel C236 board) via the serial port.  I'm hooking it up to my PC's COM1.  I am using a null modem cable, which is correct, right?  I am connecting with PuTTY using the recommended settings.  But when I reboot I only get garbage showing up in the console:
Using Jun's loader, version 1.03b.  Everything comes up fine, I'm just wondering why the serial output isn't working.  Has anyone managed to get it running in a similar setup?
9 answers to this question
for more Explanation...
i can't install sucessful Xpenology on several boxes…
Install starts , but after first reboot i can't connect neither through "find.sonology.com" nor Synology-Assistant..
so i want to find the error via Serail console..
Output starts, but there are a lot of Messages so wuick i can't follow..
so i wanted to log in und check some states (Array, lan etc.) but he asks me for an Login Name and a password
admin /
root /
admin / admin
root / root
doesn't work !!..
remember!..
i didn't reach the first Login screen to create a username and a password
thanks
admin /
root /
admin / admin
root / root
doesn't work !!..
remember!..
thanks
Did you ever find out what this initial password is? I used to know it a while back and now I've forgotten!
