Joe Bethersonton Posted October 19, 2018 #1 Posted October 19, 2018 I was given a Dell OptiPlex 7010 USFF. (i3-3220 (Ivy Bridge), 4GB memory, Intel NIC) It runs baremetal 3617xs with 6.1.4 perfectly. I'm trying to install 6.2, but I can't get it working. The user flyride shared a spreadsheet with configurations that should work. I use the 1.03b bootloader, and disabled the uefi option, so I only boot in legacy mode. The loader boots, and Synology Assistant can find the NAS, but I get the classic "Failed to install the file. The file is probably corrupted. (13)" error. With the ds3615xs loader I have tried the following combinations of SN and MAC: SN and MAC provided with the loader Generated SN and generated MAC SN and MAC from a real Synology device. SN from a real Synology device, and the OptiPlex's own MAC. I have tried with both 6.2.23739 and 6.2.23824. Every time I get that 13-error. Any tips on how to fix this? I am currently considering buying new hardware for a build, but I want to get some experience with XPEnology first. If I can't get this working I might end up buying another Synology device, although I would prefer some more powerful hardware. Quote
michel30 Posted October 21, 2018 #2 Posted October 21, 2018 (edited) did you have the latest bios on your dell computer? I used the 1.03b loader and I installed DSM 6.2-23739 update 2 my dell is Optiplex 790 And try a different usb stick Edited October 21, 2018 by michel30 Quote
Dfds Posted October 21, 2018 #3 Posted October 21, 2018 @Joe Bethersonton Did you set the USB's vid & pid? Quote
Joe Bethersonton Posted October 21, 2018 Author #4 Posted October 21, 2018 4 hours ago, Dfds said: @Joe Bethersonton Did you set the USB's vid & pid? Yes. Quote
Joe Bethersonton Posted October 21, 2018 Author #5 Posted October 21, 2018 5 hours ago, michel30 said: did you have the latest bios on your dell computer? I used the 1.03b loader and I installed DSM 6.2-23739 update 2 my dell is Optiplex 790 And try a different usb stick I am not sure to be honest. I can try and download another one. I will try and see if I can find another brand USB stick. I have five identical ones that I switch between. Quote
kazuni Posted October 21, 2018 #6 Posted October 21, 2018 I have the same machine. three things. 1) make sure your USB stick's VID and PID is correct 2) make sure your boot device is set to AHCI 3) use UEFI on 1.04, BIOS on 1.03a/b Quote
Joe Bethersonton Posted October 21, 2018 Author #7 Posted October 21, 2018 I looks like my BIOS settings was correct all along. I upgraded the BIOS to the latest version, and tried another USB stick. Now it works! I installed 6.2.23739 and afterwards upgraded to 6.2.1.23824 without any problems. (Using 1.03b ds3615xs) Quote
TomHC Posted May 24, 2019 #8 Posted May 24, 2019 Hi all, I just successfully updated ds3615xs to 6.2.2-24922 on Optiplex 7010 SFF with i5-3470. Nice, cheap and quite powerfull HW! Quote
TNa681 Posted August 20, 2019 #9 Posted August 20, 2019 @TomHC great "thumbs up" which loader did you use...1.03b ds3615xs? Quote
TomHC Posted August 20, 2019 #10 Posted August 20, 2019 1 hour ago, TNa681 said: @TomHC great "thumbs up" which loader did you use...1.03b ds3615xs? Yes, that one. 1 Quote
TNa681 Posted August 28, 2019 #11 Posted August 28, 2019 (edited) Does anybody know a step by step guide how to upgrade? I am on 1.02.a & DSM 6.1 and want to upgrade to 1.03b and 6.2. Figured I have to create a new boot stick with 1.03b at first, and boot up the system with it...can I than just click the update button in DSM and the procedure runs by it's own? Edited August 28, 2019 by TNa681 Quote
TomHC Posted September 13, 2019 #12 Posted September 13, 2019 On 8/28/2019 at 9:43 PM, TNa681 said: Does anybody know a step by step guide how to upgrade? I am on 1.02.a & DSM 6.1 and want to upgrade to 1.03b and 6.2. Figured I have to create a new boot stick with 1.03b at first, and boot up the system with it...can I than just click the update button in DSM and the procedure runs by it's own? Just plug new USB stick and follow on-screen instructions. It may propose you migration to new hardware. I did it with ds3615xs to ds918+ in a same way. Quote
TNa681 Posted September 13, 2019 #13 Posted September 13, 2019 (edited) Hey @TomHC thanks a lot for your reply! To be honest, since I am planning to use my NAS as a TV recorder by using a USB DVB-C TVButler I changed my plan. As I read somewhere that it wouldn’t be compatible anymore with DSM 6.2, I decided to skip to update having the hope it works with 6.1. Edited September 13, 2019 by TNa681 Quote
