melliemvdg Posted October 17, 2018 #1 Posted October 17, 2018 Hello everybody. I have build an i3 7100 MSI b250M PRO - VD Corsair DDR4 2133mhz I've i install dsm 6.2 and i choose new installation and select the downloaded firmware, i have the error (13). In the Netherlands (Het bestand is mogelijk beschadigd). Some times it works. Then i have the screen (installing DSM) and then Starting DiskStation counting down from 10 minuten to 0. The Bare Metal reboots automatically and then i have the error (connection lost). Please help me Quote
bearcat Posted October 17, 2018 #2 Posted October 17, 2018 @melliemvdg: you should have read the posted Warning! and thread to save yourself some problems. I'm assuming you downloaded and installed (from Synology) the "Latest & Greatest" DSM 6.2.1.xx, that most likely do NOT support your NIC. You should either install from a local copy, (.PAT file) the DSM 6.2-23739, and stop updating after Upd.2 or you can play it "safe" and install DSM 6.1.x from a local copy (.PAT file), using Juns 1.02b loader. Re: "Error 13": 1 Did you modify your grub.cfg with the corect vid/pid etc? 2 Was your harddrives empty and cleaned for any filesystems? Quote
melliemvdg Posted October 17, 2018 Author #3 Posted October 17, 2018 3 hours ago, bearcat said: @melliemvdg: you should have read the posted Warning! and thread to save yourself some problems. I'm assuming you downloaded and installed (from Synology) the "Latest & Greatest" DSM 6.2.1.xx, that most likely do NOT support your NIC. You should either install from a local copy, (.PAT file) the DSM 6.2-23739, and stop updating after Upd.2 or you can play it "safe" and install DSM 6.1.x from a local copy (.PAT file), using Juns 1.02b loader. Re: "Error 13": 1 Did you modify your grub.cfg with the corect vid/pid etc? 2 Was your harddrives empty and cleaned for any filesystems? Thankyou for your answer! i try to install dsm 6.2 path download it from the synology download page. If i choose that file then i have the error (13). ”the file is damaged” also. the hdd is format to ntfs. I didn’t modify the grub. After searching on the internet i found it how to do. I try it tomorrow! Quote
