Hi there, I´m new here and I want to build a Xpenology System with a Athlon 5350 and Asrock AM1H-ITX Board. I have seen there are a few People with this Combo and it seems to work. I tryed to install DSM versions 6.1, 6.1.5 and 6.2 with Jun´s or Quicknick´s Bootloaders. But everytime i get the error 21 after ~14% of Installation. You may know how to solve this? Maybe something´s wrong in my bios?
Thank´s a lot for helping!
Bye
Thomas
No i did not Change them, but I also don´t know how because in my usb-stick there are just 4 files: extra.lzma, info, rd and zlmage
The pid/vid should be changed in the grub.cfg file, but I do not have this ...
same problem here, i don't see any grub.cfg just extra.lzma, info, rd and zlmage
@Biaggi051 and @dedligamer
You "might" need to do some reading over here.
Short version, the file you MUST edit, is part of the bootloader file, (synoboot.img)
and you have to do the edit before writing it to your USB stick.
Thank you @bearcat, in my german instalation guide that i have was Nothing written About the pid/vid and Sercial Code Change. So i did that but it seems that I now have another Problem. The Installation of DSM was 100% ok, but afterwards the new "Diskstation" could not be found. Maybe a Problem with the MAC adress? I did´nt Change that in the grub because I don´t know what my MAC adress is before creating the USB stick. Afterwards I can see it in my Fritz.box ...
I think I´m near to the solution, so Maybe someone can give me the last Input ...
Thanks alot!
@Biaggi051 you may find your original MAC adress in the BIOS of your mainboard, and use that in the grub.cfg.
There is some reference, in German, to the NIC I think is used on your mainboard: Realtek RTL8111GR, you might check it out (and search the forum).
  • 1 year later...
  • 1 year later...
