dutchnas Posted October 2, 2018 #1 Posted October 2, 2018 Currenly I'm running Xpenology with DSM 6.2. I've enabled WOL within DSM on the NIC, but when sending the magic packet nothing happens. How can I get WOL working? Quote
0 canuckbrian Posted October 4, 2018 #2 Posted October 4, 2018 Is your NIC an onboard device or a discrete card? If it's onboard check your BIOS settings, some systems have WOL settings in the BIOS. If it's a discrete card sometimes they have a boot up firmware you can enter to configure various options, see if there is anything in there about WOL. Is your NIC even capable of doing WOL? Quote
0 dutchnas Posted October 4, 2018 Author #3 Posted October 4, 2018 6 hours ago, canuckbrian said: Is your NIC an onboard device or a discrete card? If it's onboard check your BIOS settings, some systems have WOL settings in the BIOS. If it's a discrete card sometimes they have a boot up firmware you can enter to configure various options, see if there is anything in there about WOL. Is your NIC even capable of doing WOL? It is an onboard NIC from an HP N40L, with DSM 5.2 it was working fine and now with DSM 6.2 it won't work anymore. Quote
0 Hostilian Posted October 4, 2018 #4 Posted October 4, 2018 Yep, you need to ensure your NIC is configured in the BIOS to support WOL. You also need to use the MAC Address in your Grub.cfg (not the vanilla MAC of your NIC) and also make sure it's configured in the DSM to support WOL (under hardware and power). Not sure what your previous configuration was for DSM5.2 but your new one uses the GRUB.cfg MAC address(es).. Try using those.. #H Quote
0 dh22r Posted October 6, 2018 #5 Posted October 6, 2018 On 10/4/2018 at 9:05 AM, Hostilian said: Yep, you need to ensure your NIC is configured in the BIOS to support WOL. You also need to use the MAC Address in your Grub.cfg (not the vanilla MAC of your NIC) and also make sure it's configured in the DSM to support WOL (under hardware and power). Not sure what your previous configuration was for DSM5.2 but your new one uses the GRUB.cfg MAC address(es).. Try using those.. #H in my grub.cfg, i'd set the MAC address the same as the NIC's MAC address. should i be doing something different? thanks. dh22r Quote
0 Hostilian Posted October 6, 2018 #6 Posted October 6, 2018 Yes.. Needs to be different.. You can find serial/mac generators after a simple Gooooooogle search.. Quote
dutchnas
5 answers to this question
