Servman Posted September 28, 2018 #1 Posted September 28, 2018 Hi All, Hope some one can help. I'm using a Dell Optiplex 380 with DSM 6.1 as i'm not able to upgrade to DSM 6.2 as no HDD Drive support as yet. i have a Astrotek AT-CPASA-1 IDE-SATA PCI 2xSATA 1xeSATA 1xIDE card with a 1tb HHD attached but Xpenology is not able to see the HDD. i'm sure it is a drive issue, but i hoping some one will be able to help with where i'm able to get the drivers from, but i do still have the cd that it come with and now to get it working with Xpenology? Regards Quote
IG-88 Posted September 29, 2018 #2 Posted September 29, 2018 if you would be more specific about the hardware you are using it might be easier to help Dell Optiplex 380 - whats the cpu? if older then 4th gen (hasswell) then 916+ and 918+ image will never work wahts the chips on that (old and exotic) controller my guess would be via or jmicron and those are not working with dsm 6.1 as i documented here the dell seems to have a pcie slot so you could get a sata controller thats supported by the normal ahci driver, that way the missing disk will be detected search the forum for that kind of controller Quote
Servman Posted September 29, 2018 Author #3 Posted September 29, 2018 Hi @IG-88, Sorry for the lack of info The Dell is running the duo core 2 CPU with 8 gig of ram. How would I find out what chip the RAID card is using? I know the card works with windows and ubuntu 16.04? Regards And think you for your help. Quote
