Jose Posted September 25, 2018 #1 Posted September 25, 2018 (edited) I am trying to build some modules for 6.2 for ds3615/7 but although they work before the installation of .pat file they cause the system to error out after it. (System works fine if the modules are removed from the extra.lzma). The modules i was working at the moment are virtio virtio_scsi virtio_net virtio_pci ixgbevf, the error seems to come when the module/driver is actually assigned as if no device actually tries to use them they seem to work fine. Any tips or anything I should know such as special settings in the .config make file? Source I am using: "https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/22259branch/broadwell-source/linux-3.10.x.txz/download" for kernel "https://sourceforge.net/projects/dsgpl/files/DSM%206.2%20Tool%20Chains/Intel%20x86%20Linux%203.10.102%20%28Broadwell%29/broadwell-gcc493_glibc220_linaro_x86_64-GPL.txz/download" for toolchain adding the modules to 1.3b jun synoboot.img ==================== start udevd ==================== ===== trigger device plug event ===== [ 10.326411] general protection fault: 0000 [#1] SMP [ 10.327006] Modules linked in: broadwell_synobios(PO) igbvf(F) ixgbevf(F) virtio_net(F) virtio_pci(F) virtio_mmio(F) evdev(F) button(F) ax88179_178a(F) usbnet tg3(F) r8169(F) cnic(F) bnx2(F) vmxnet3(F) pcnet32(F) e1000(F) sfc(F) netxen_nic(F) qlge(F) qlcnic(F) qla3xxx(F) pch_gbe(F) ptp_pch(F) sky2(F) skge(F) jme(F) ipg(F) uio(F) alx(F) atl1c(F) atl1e(F) atl1(F) libphy(F) mii(F) exfat(O) btrfs synoacl_vfs(PO) zlib_deflate hfsplus md4 hmac bnx2x(O) libcrc32c mdio mlx5_core(O) mlx4_en(O) mlx4_core(O) mlx_compat(O) compat(O) qede(O) qed(O) atlantic(O) r8168(OF) tn40xx(O) i40e(O) ixgbe(O) be2net(O) igb(O) i2c_algo_bit(F) e1000e(O) dca(F) vxlan fuse vfat fat crc32c_intel aesni_intel glue_helper lrw gf128mul ablk_helper arc4 cryptd ecryptfs sha256_generic sha1_generic ecb aes_x86_64 authenc des_generic ansi_cprng cts md5 cbc cpufreq_conservative cpufreq_powersave cpufreq_performance cpufreq_ondemand mperf processor thermal_sys cpufreq_stats freq_table dm_snapshot crc_itu_t crc_ccitt quota_v2 quota_tree psnap p8022 llc sit tunnel4 ip_tunnel ipv6 zram(C) sg etxhci_hcd virtio_scsi(F) virtio_ring(F) virtio(F) mpt3sas(O) mpt2sas(O) megaraid_sas(F) mptctl(F) mptsas(F) mptspi(F) mptscsih(F) mptbase(F) scsi_transport_spi(F) megaraid(F) megaraid_mbox(F) megaraid_mm(F) vmw_pvscsi(F) BusLogic(F) usb_storage xhci_hcd uhci_hcd ohci_hcd(F) ehci_pci(F) ehci_hcd(F) usbcore usb_common mv14xx(O) uuuut(OF) [last unloaded: broadwell_synobios] [ 10.329268] CPU: 1 PID: 7521 Comm: synonet Tainted: PF C O 3.10.105 #23739 [ 10.329268] Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS ?-20180531_142017-buildhw-08.phx2.fedoraproject.org-1.fc28 04/01/2014 [ 10.329268] task: ffff8800311e6800 ti: ffff880037990000 task.ti: ffff880037990000 [ 10.329268] RIP: 0010:[<ffffffff813fd495>] [<ffffffff813fd495>] ethtool_get_settings+0x55/0x220 [ 10.329268] RSP: 0018:ffff880037993c88 EFLAGS: 00010246 [ 10.329268] RAX: 0000000000000000 RBX: 00007ffe3eb65a10 RCX: 0000000000000000 [ 10.329268] RDX: a5a5a5a55a5a5a5a RSI: ffff880037993cc8 RDI: ffff88003b096000 [ 10.329268] RBP: ffff880037993cc8 R08: ffffffffa0de45c0 R09: 0000000000000004 [ 10.329268] R10: 0000000000000107 R11: 0000000000000246 R12: 00007ffe3eb65a10 [ 10.329268] R13: 0000000000000000 R14: ffff88003b096000 R15: ffff88003b096000 [ 10.329268] FS: 00007f7689313b00(0000) GS:ffff88003fc80000(0000) knlGS:0000000000000000 [ 10.329268] CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 [ 10.329268] CR2: 00007f768930f000 CR3: 00000000378c7000 CR4: 00000000001406e0 [ 10.329268] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 [ 10.329268] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 [ 10.329268] Stack: [ 10.329268] 0000000000000026 ffff88003d39c7c0 ffff88003fc90300 ffff880037993cd8 [ 10.329268] ffff8800311e6800 0000000000000000 0000000000000046 0000000000010300 [ 10.329268] 0000000000000000 0000000000000000 0000000000000000 0000000000000000 [ 10.329268] Call Trace: [ 10.329268] [<ffffffff813fe36b>] ? dev_ethtool+0x62b/0x1d50 [ 10.329268] [<ffffffff812e1604>] ? pty_write+0x54/0x60 [ 10.329268] [<ffffffff812da00c>] ? do_output_char+0x16c/0x1e0 [ 10.329268] [<ffffffff8140d3eb>] ? dev_ioctl+0x19b/0x5f0 [ 10.329268] [<ffffffff813e1b1d>] ? sock_do_ioctl+0x3d/0x50 [ 10.329268] [<ffffffff813e1f28>] ? sock_ioctl+0x1d8/0x2a0 [ 10.329268] [<ffffffff8110fcda>] ? do_vfs_ioctl+0x4aa/0x990 [ 10.329268] [<ffffffff813e19d0>] ? sock_alloc_file+0xa0/0x130 [ 10.329268] [<ffffffff81110240>] ? SyS_ioctl+0x80/0xa0 [ 10.329268] [<ffffffff814bcc32>] ? system_call_fastpath+0x16/0x1b [ 10.329268] Code: 8b 90 70 01 00 00 48 85 d2 0f 84 17 01 00 00 48 8d 6c 24 40 45 31 ed b9 09 00 00 00 4c 89 e8 48 89 ef 48 89 ee f3 48 ab 4c 89 f7 <ff> d2 85 c0 0f 88 e0 00 00 00 48 8d 5c 24 14 4c 89 e8 48 c7 44 [ 10.329268] RIP [<ffffffff813fd495>] ethtool_get_settings+0x55/0x220 [ 10.329268] RSP <ffff880037993c88> [ 10.362731] ---[ end trace 0cea1b1eda5c49dd ]--- [ 10.554997] init: system-profile-tuning main process (7661) terminated with status 255 [ 10.675073] usbcore: registered new interface driver usblp Edited September 25, 2018 by Jose added error msg Quote
xuplus Posted September 24, 2019 #2 Posted September 24, 2019 can you share the driveres for igbvf virtio_net virtio_pci virtio_mmio Quote
Dvalin21 Posted February 8, 2020 #3 Posted February 8, 2020 I think im having a similar problem but dont have a clue on how to go about it. I have a HP Proliant ML10 only thing that is really different is the cpu which is Xeon E3-1270. Im able to use Jun loader 2b, and 3b with no problem. Now the problem that I have is that when trying to install the .pat file for 6.2.1 or 6.2.2, it goes through the process, but it never boots back up. The drivers work great in the loader, but apparently there is a lot not working in the .pat files. If you have fixed this issue for yourself, could you send me how you took care of this issue? Thanks. Quote
flyride Posted February 8, 2020 #4 Posted February 8, 2020 https://xpenology.com/forum/forum/91-additional-compiled-modules/ Quote
