make an clean installation Help Needed
Hey I need som e help
I just created and reset on my HP Proviant Gen 8 with DSM 6.1.7 Update 2
now the Dam says they can see that have have moved my harddrive from an old nas
so I only have the option to migrate
when I try to migrate with the 6.1.7 pat  it says the files is broken
i also tried to update my bootloader but I get no cfg file on my usb pen
please help me .9
2 minutes ago, Flarup said:
no I did it with win32diskimager
You can create the USB stick with win32diskimager but in order to edit the cfg file you must mount it in osfmount.
the img file is about 50MB and osfmount should show 3 partitons (15MB. 30MB, 4MB)
as you already have writen a usb flash drive there is also the option to use linux to mount the 1st partiton of the drive to modify the grub.cfg (vid/pid)
you really should read
https://xpenology.com/forum/forum/36-tutorials-and-guides/
and
https://xpenology.com/forum/forum/83-faq-start-here/
also if you want a clean install you can remove all partitions from disks, that way then installer can only offer a fresh install, boot a live or recovery linux to do this, this can also be used to mount an mod the usb flqsh drive as mentioned above
Edited by IG-88
i have now made a new boot loader, the problem is that I I use a Mac with VMware and it won't work for some reason I just used my dads pc and wept now I got the cfg file
If you had mentioned in your original post that you were using a Mac you could have saved yourself a lot of hassle.
Sorry i thought that VMware was like windows
i already tried with Mac but there I didn’t get the cfg file either
