6.2 on P5NE-SLI possible? 5.2 working well
Hi everyone and thank you for the help you could give me.
Currently my NAS is working like a charm:
    DSM 5.2 (XPEnoboot 5.2-5644.5 DS3615xs / DSM_5.2-5644 Update-5)
    Motherbord : ASUS P5NE-SLI Chipset NVidia nforce 650i
    CPU : Core 2 Quad Q9400
    8 Go RAM
    2 x Silicone Image 3114 PCI --> 4 SATA (Working very good)
    Onboard SATA, LAN working good too
    Intel Gigabit Ethernet Card PCI-E Working fine too
    4x2To on RAID 10 on Sil3114
    4x3To on RaID0 on the second Sil3114
What I've already tried:
- Tuto youtube of BOOBYTRAP on how to install DSM 6.2 / 6.1 / Migrating 5.2 to 6.1 ...  (Thank You So Much For Such Wonderful Tuto !)
- Already tried to copile additional drivers with BASH Ubuntu for Windows (Boobytrap again...)
- Tried this on 3617xs / 3615xs 6.2 / 6.1 Juns loaders versions
- The best I could get is the LAN working but none of disk recognised to be plugged-in in order to continue installation.
- Tried to unplug all disks, to plug only one disk on SATA0 MB port, MapSATAports as 444, none of these worked.
BTW I already installed DSM 6.1 with no problem on my ASUS ROG Laptop G75 to test the install procedure.
As Xpenoboot 5.2 is working good, is there any mean to get Xpenoboot drivers in order de make a extra.lzma file for my configuration?
Many Thanks for your contribution to my problem.
Bikester
In the mean time I continued to read the forum and extract from my NAS the list of "KERNEL MODULES" from Linux Lite Live USB stick which I booted on to.
Here is the list. Can you please tel me which modules are mandatory for DSM 6.2 to run fine ? Thank you.
Computer
Kernel Modules
Loaded Modules
appledisplayApple Cinema Display driver
ip6t_REJECTXtables: packet "rejection" target for IPv6
nf_reject_ipv6
nf_log_ipv6Netfilter IPv6 packet logging
xt_hlXtables: Hoplimit/TTL field match
ip6t_rtXtables: IPv6 Routing Header match
nf_conntrack_ipv6
nf_defrag_ipv6
ipt_REJECTXtables: packet "rejection" target for IPv4
snd_hda_codec_realtekRealtek HD-audio codec
nf_reject_ipv4
snd_hda_codec_genericGeneric HD-audio codec parser
nf_log_ipv4Netfilter IPv4 packet logging
nf_log_common
xt_LOGXtables: IPv4/IPv6 packet logging
snd_hda_codec_hdmiHDMI HD-audio codec
snd_hda_intelIntel HDA driver
snd_hda_codecHDA codec core
snd_hda_coreHD-audio bus
snd_hwdepHardware dependent layer
xt_limitXtables: rate-limit match
snd_pcmMidlevel PCM code for ALSA.
xt_tcpudpXtables: TCP, UDP and UDP-Lite match
snd_seq_midiAdvanced Linux Sound Architecture sequencer MIDI synth.
snd_seq_midi_eventMIDI byte <-> sequencer event coder
snd_rawmidiMidlevel RawMidi code for ALSA.
xt_addrtypeXtables: address type match
snd_seqAdvanced Linux Sound Architecture sequencer.
input_ledsInput -> LEDs Bridge
snd_seq_deviceALSA sequencer device management
snd_timerALSA timer interface
coretempIntel Core temperature monitor
kvm_intel
kvm
irqbypassIRQ bypass manager utility module
sndAdvanced Linux Sound Architecture driver for soundcards.
nf_conntrack_ipv4
nf_defrag_ipv4
soundcoreCore sound module
xt_conntrackXtables: connection tracking state match
asus_atk0110
mac_hid
shpchpStandard Hot Plug PCI Controller Driver
ip6table_filterip6tables filter table
ip6_tablesIPv6 packet filter
sch_fq_codel
nf_conntrack_netbios_nsNetBIOS name service broadcast connection tracking helper
nf_conntrack_broadcast
nf_nat_ftpftp NAT helper
nf_nat
nf_conntrack_ftpftp connection tracking helper
nf_conntrack
libcrc32cCRC32c (Castagnoli) calculations
parport_pcPC-style parallel port driver
ppdev
lp
iptable_filteriptables filter table
parport
ip_tablesIPv4 packet filter
x_tables{ip,ip6,arp,eb}_tables backend module
autofs4
overlayOverlay filesystem
nls_utf8
isofs
dm_mirrordevice-mapper mirror target
dm_region_hashdevice-mapper region hash
dm_logdevice-mapper dirty region log
uas
usb_storageUSB Mass Storage driver for Linux
hid_genericHID generic driver
usbhidUSB HID core driver
hid
radeonATI Radeon
i2c_algo_bitI2C-Bus bit-banging algorithm
pata_acpiSCSI low-level driver for ATA in ACPI mode
firewire_ohciDriver for PCI OHCI IEEE1394 controllers
firewire_coreCore IEEE1394 transaction logic
crc_itu_tCRC ITU-T V.41 calculations
ttmTTM memory manager subsystem (for DRM device)
sata_sillow-level driver for Silicon Image SATA controller
forcedethReverse Engineered nForce ethernet driver
ahciAHCI SATA low-level driver
drm_kms_helperDRM KMS helper
libahciCommon AHCI SATA low-level routines
syscopyareaGeneric copyarea (sys-to-sys)
sysfillrectGeneric fill rectangle (sys-to-sys)
sata_nvlow-level driver for NVIDIA nForce SATA controller
sysimgblt1-bit/8-bit to 1-32 bit color expansion (sys-to-sys)
fb_sys_fopsGeneric file read (fb in system RAM)
e1000eIntel(R) PRO/1000 Network Driver
i2c_nforce2nForce2/3/4/5xx SMBus driver
drmDRM shared core routines
ptpPTP clocks support
pata_amdlow-level driver for AMD and Nvidia PATA IDE
pps_coreLinuxPPS support (RFC 2783) - ver. 5.3.6
floppy
Regards,
Bikester
