Syno 12 bays maximum: problem
Hello everyone.
I have the project to make a server with 24 bays
I see that the loaders are made with 12 bays maxi.
I see that there are FS2017 or FS3017 that are in 24 bays.
Is there a solution ?
Thank you all
Emmanuel
9 answers to this question
oh sorry
i have a new problem with this
i run it on a HP DL180-g6
12 bay in front, 2 rear, 6 sata on motherboard and i plugged a netapp 4246 with 24 bay
total 44 ports
i use this config
usb: 0x700000000000
esata: 0x0
internal: 0xfffffffffff
i edit the /etc/synoinfo.conf and the /etc.defaults/synoinfo.conf.
i restart and synology assistant tell me "can be migrated"
I tried several times, but still the same result.
Would anyone have an idea or an answer
my version
DSM: 6.2.1 (23824)
loader: 1.03b
Il y a 15 heures, Polanskiman a dit :
Did you find a solution to your issue @colem? If yes please share with the community. Thanks.
I did not do anything more.
I tried again and it works, but I'm afraid it will start again.
have a read of this older thread on drive limits, addressing and the possible fixes. You will always be faced with having to reedit the synoinfo.conf after a boot loader upgrade or change
https://xpenology.com/forum/topic/8057-physical-drive-limits-of-an-emulated-synology-machine/page/2/
The failure of the migration is because it does not recognize the numbers hexadicemal correctly:
That is, the Internalportcfg command line was when I edited it without the 0x in front and therefore always asked me to migrate ... I would have to put it in quotes and with the 0x in front (Internalportcfg = "0x7FFF" for 15 discs)
And another thing that you have to edit the synoinfo.conf file in the folder "etc.defaults" and tb in the folder "etc"
Answer this question...
