Hi guys
Im using xpenology 6.2-23739 update 2 with jun loader 1.03b, I had java 8 installed, there was an upgrade so I have done that, but when I start an ssh login throught putty, I get the following. Does anyone know how I can clean this up, I am now running java 8 update 181
Using username "root".
Using keyboard-interactive authentication.
Password:
Spoiler
         Send automatic password (Using keyboard-interactive authentication)
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/logging.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.SuSE.10.properties.src: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/charsets.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/resources.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/trusted.libraries: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/blacklist: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/java.security: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/java.policy: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/blacklisted.certs: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy/limited: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy/limited/local_policy.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy/limited/US_export_policy.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy/unlimited: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy/unlimited/local_policy.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/policy/unlimited/US_export_policy.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/security/cacerts: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/classlist: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.Turbo.properties.src: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/jvm.hprof.txt: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/calendars.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/management-agent.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.RedHat.6.bfc: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.Turbo.bfc: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.RedHat.6.properties.src: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/psfont.properties.ja: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/flavormap.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libdt_socket.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libverify.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/server: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/server/Xusage.txt: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/server/libjvm.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/server/libjsig.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libnet.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libawt_headless.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libnpt.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libt2k.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/client: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/client/Xusage.txt: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/client/libjvm.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/client/libjsig.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libnio.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libkcms.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/jvm.cfg: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjsoundalsa.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libhprof.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libmanagement.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libj2gss.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libinstrument.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjsdt.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libunpack.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjaas_unix.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libdcpr.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libfontmanager.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjava_crw_demo.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libawt.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/minimal: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/minimal/libjvm.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/minimal/Xusage.txt: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/minimal/libjsig.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjsound.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libzip.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libbci.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/jli: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/jli/libjli.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/liblcms.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjdwp.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjawt.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libmlib_image.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjava.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libsctp.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libsunec.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjsig.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libj2pkcs11.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libj2pcsc.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/i386/libjpeg.so: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/jce.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/oblique-fonts: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/oblique-fonts/fonts.dir: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/oblique-fonts/LucidaSansOblique.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/oblique-fonts/LucidaTypewriterOblique.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/oblique-fonts/LucidaSansDemiOblique.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/oblique-fonts/LucidaTypewriterBoldOblique.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/management: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/management/jmxremote.password.template: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/management/snmp.acl.template: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/management/jmxremote.access: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/management/management.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.RedHat.5.bfc: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/tzdb.dat: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.SuSE.11.bfc: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/hijrah-config-umalqura.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/jsse.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/psfontj2d.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/cmm: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/cmm/PYCC.pf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/cmm/sRGB.pf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/cmm/LINEAR_RGB.pf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/cmm/CIEXYZ.pf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/cmm/GRAY.pf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.properties.src: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/sunec.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/sunjce_provider.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/localedata.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/nashorn.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/jaccess.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/cldrdata.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/zipfs.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/meta-index: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/dnsns.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/ext/sunpkcs11.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.RedHat.5.properties.src: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/rt.jar: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/content-types.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/net.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/applet: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaSansRegular.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaBrightDemiBold.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaBrightRegular.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaBrightItalic.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaBrightDemiItalic.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaTypewriterRegular.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaTypewriterBold.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/LucidaSansDemiBold.ttf: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fonts/fonts.dir: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/currency.data: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.SuSE.10.bfc: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/meta-index: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/jexec: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/sound.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.SuSE.11.properties.src: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/motif_MoveDrop32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/motif_CopyDrop32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/motif_LinkDrop32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/invalid32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/images/cursors/cursors.properties: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/lib/fontconfig.bfc: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/tnameserv: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/orbd: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/servertool: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/jjs: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/rmid: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/unpack200: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/rmiregistry: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/keytool: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/java: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/policytool: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/bin/pack200: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/release: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/COPYRIGHT: No such file or directory
-ash: /var/packages/java8/target/ejdk1.8.0_171/linux_i586/jre/THIRDPARTYLICENSEREADME.txt: No such file or directory
Edited by Polanskiman
added code and spoiler tags
