Tutorial: Install DSM 6.2 on ESXi 6.7
Download:
1. synoboot vmdk
https://mega.nz/#!fdBWBJYB!P3MbGY2v_X_udUhaSgVBQZ74KNRf7vtjMCO39u1I91Y
2. juns loader for DSM 6.2
https://mega.nz/#F!ZlkHQTTb!keje3RK017OjTp3vuWb-Cw
3. synology DSM.pat for synology 3615xs
https://www.synology.com
https://archive.synology.com/download/DSM/release/
4. open vm tools spk
http://spk.4sag.ru/?fulllist=true
5. XPEnology Tool for Windows x64
PREPARATIONS
unzip synoboot.vmdk from DS3615xs 6.0.2 Jun's Mod V1.01 (synoboot.vmdk works with 3615 and 3617 loaders)
unzip synoboot.img from synoboot_3615
mount synoboot.img partition 0 with osf mount
Make sure to uncheck Read-only drive
Go to the mounted drive, Grub folder and edit grub.cfg with notepad++
If you want change default SN and mac1
comment boot option lines you dont need in esxi
#menuentry "DS3615xs 6.2 Baremetal $VERSION" --class os {
#        set img=
#        savedefault
#        loadlinux 3615 usb
#        loadinitrd
#        showtips
#menuentry "DS3615xs 6.2 Baremetal $VERSION Reinstall" --class os {
#        set img=
#        loadlinux 3615 usb mfg
#        loadinitrd
#        showtips
#menuentry "DS3615xs 6.2 Baremetal AMD $VERSION" --class os {
#        set img=
#        set zImage=bzImage
#        savedefault
#        loadinitrd
#        showtips
menuentry "DS3615xs 6.2 VMWare/ESXI $VERSION" --class os {
        set img=
        savedefault
        loadlinux 3615 sata
        loadinitrd
        showtips
save file, dismount all and exit.
ESXi part:
Upload synoboot.vmdk and synoboot.img to esxi (in one folder)
Create new VM
name the xpenology vm as you want and select Linux and Other 3.x Linux x64
select your storage and you should see customize settings
now remove default disk
remove scsi controller
remove cd/dvd drive
and if you are using 3617 loader you need to remove USB controller or change type to USB 3.0
now set cpu at 2
set memory 2GB
change Network Adapter Type to E1000e
set network adapter 1 mac addres you have in the grub.cfg for example 00:11:32:2C:A7:85
now add existing hard disk and point to the synoboot.vmdk uploaded before.
Make sure its on SATA 0:0
now add another sata device
and add vm disks to it (sata 1:0, 1:1 etc)
and now, the vm is done
and finish
now start your VM and wait to see
after few minutes open in new tab browser find.synology.com
click connect
accept EULA
Set UP
and manual install
point to DSM 3615xs.pat file downloaded earlier
after you confirm instalation you should see instalation progress
after 10 minutes reboot
enter username, password and server name for dsm
skip configure quickconnect
dont share location with synology (find.synology.com will not find virtual dsm)
now DSM is ready :)
This type of VM should work with dsm 6.2, 6.2.1, 6.2.2 and 3615xs/3617xs loaders
DSM 6.2.3 is showing synoboot drive as eSata in dsm
BIG thanks to @flyride and @Balrog for the fix
Quote
VMXNET3 working only with  CPU IOMMU disabled (VMware CPU option)
Hello all,
For everyone that is interested in using 10GB VMXNET3 network adapter - must be in addition to an Intel E1000E because you will not be able to install/update
For example, my setup consists of one E1000E - used for normal access of Synology services and 2 VMXNET3 NIC's used for iSCSI/NFS access to my ESXi hosts. I have a 2 port 10GB physical NIC on the ESXi.
You can use perfectly fine VMXNET3, even with DirectPath I/O checked, as long as you DON'T enable CPU IOMMU - this took a while to figure out and I hope this will help someone in a similar scenario
Please post this information where is best suited.
reported by @boghea
Spoiler
Changelog
v1. Initial
v2. screenshots in english, added vnic E1000e, added info to remove usb 2 for 3617, minor misspeling corrections
v.3 added info about dsm 6.2.3
Edited by luchuma
screenshots in english, added vnic E1000e, added info to remove usb 2 for 3617, minor misspeling corrections, broken link fix
  • Like 4
  • Thanks 8
First of all I cant mount synoboot.img with osf, It say that no partitions found, I could read it only with poweriso, ok i change mac on virtual machine match it in grub.cfg but I cant find it with find.synology.com or synology assistant, what I could do wrong?
Vm machine in bios mode?
What hardware do you have?
Give some screens of vm and grub.cfg
Synoboot vmdk Has to be sata 0.0
Maybe files where corrupted while transfer or download.
Wysłane z mojego SM-G930F przy użyciu Tapatalka
On 8/29/2018 at 12:11 PM, luchuma said:
DSM 6.2-23739 Update 2 - works fine
DSM 6.2.1-23824 - DSM_DS3615xs_23824.pat is not working yet so be carefull
DSM 6.2.1-23824 - DSM_DS3615xs_23824.pat is working on VM
change vm network settings vm adapter to e1000e (default is vmxnet3)
Nice finding. :-)
i hope there will be some time an update for the vmxnet3 driver as it has much advantages over the pure intel driver.
Folowed this tuturial to update my installation from dsm 6.1 on ESXi 6.7, and almost everything went well.
The only problem i want to share is that my disks are RDM, and on esxi RDM cannot be maped to sata controler.
Just added scsi controler, add RDM disks to scsi and set in vm bios boot  to sata controler, otherwise dsm wont boot(predefined boot will be scsi).
9 minutes ago, doughnet said:
after i install the PAT file it reboots and says that it has to recover and due to the drives have been moved ... i have 2 drives added on SATA 1 under 1:0 & 1:1
Your 1st drive, Synoboot.vmdk, should be attached to SATA 0.  If you attach it to SATA 1, DSM will try to wipe it during install.
Thank you.  synoboot.vmdk is attached to SATA 0:0
I have 2 seperate drives attached to SATA1:0 & SATA 1:1
What type of drives are attached to SATA 1?   What is the Compatibility and Disk Mode set to?  Does the install work if you just attach one of the drives?
Edited by berwhale
Thank you again for your help.
Both SATA1 drives are setup as:
TYPE: Thick provisioned, lazily zeroed
DISK MODE: DEPENDENT
What's the reason to attach 2 drives rather than one bigger one?  Are they on different data stores?
Just a short confirmation, that this tutorial works with ESXI 6.5 as well, incl. a RDM mapped harddisk.
However, I had to set the bootorder in BIOS manually as described in this thread.
Can't upgrade ESXI to 6.7, DL360p Gen8 supports up to ESXI Release 6.5.0 Update 2 ...
I'm getting so confused with all the different downloads.
Could somebody post links to files needed please.
I downloaded:
dsm.6.2.synoboot_ds3617xs.1.03b (contains only synoboot.img)
dsm.6.2.synoboot_ds3615xs.1.03b (contains only synoboot.img)
Edited both these files with the SN and a MAC, commented out the Baremetal. Nothing else.
DS3615xs 6.0.2 Jun's Mod V1.01 (contains a bunch)
Can't find one for DS3617
Image files from Synology
https://archive.synology.com/download/DSM/beta/6.2/23648/
DSM_DS3615xs_23648.pat
DSM_DS3617xs_23648.pat
I created a new VM, deleted the HDD, the SCSI controller, added a new SATA controller (to have 1:0)
Added the existing synoboot.img to 0:0
Added 2 new HDD to 1:0 and 1:1
Added the MAC as manual
vreated the VM. Boot. Found it and tried to install the .pat. No go for either 3615 or 3617.
Help 😋
  • Polanskiman changed the title to Tutorial: Install DSM 6.2 on ESXi 6.7
  • Polanskiman pinned this topic
