swizzls_mtlow 1 Posted August 14, 2018 Share Posted August 14, 2018 Hi, I have recently updated DSM on my HP N36/40L microserver. Prior to the upgrade to DSM 6.2 I had a working 2 port USB3 PCI-E card. However I have just gone to plug my external HDD into the card and it spins up but does not register in DSM. The disk is fine, I have checked on my Windows PC and also it is visible (and usable) when plugged into one of the USB2 ports built into the server. Not sure where to go with this but would be good to get USB3 working to speed up backups. The card is a TS-PDC3. Thanks in advance Quote Link to post Share on other sites
tork24 0 Posted November 1, 2018 Share Posted November 1, 2018 Hello Do you manage to solve the problem? I have exactly the same problem and I don't know how to solve it. Thanks Quote Link to post Share on other sites
Josh 2 Posted November 1, 2018 Share Posted November 1, 2018 I can not help with your card but i have this card working under DSM 6.2/1.03b (3615) on my N54L: https://www.delock.de/produkte/1112_USB-3-0/89243/merkmale.html?setLanguage=en Regards Quote Link to post Share on other sites
swizzls_mtlow 1 Posted November 13, 2018 Author Share Posted November 13, 2018 @tork24 not solved this yet but have only been doing incremental backups so has been less of an issue @Josh Thanks for the headsup on your card. Did you have to configure any special settings or does it just work out of the box? Thanks Quote Link to post Share on other sites
Josh 2 Posted November 18, 2018 Share Posted November 18, 2018 @swizzls_mtlow It works out of the box, no config or settings. It also works with 6.2.1. Quote Link to post Share on other sites
d0n 2 Posted December 11, 2018 Share Posted December 11, 2018 (edited) I got the Delock too, but it does not work with DSM 6.2 1.03b (3615) N54L 0000:03:00.0 Class 0c03: Device 1912:0015 (rev 02) Edited December 11, 2018 by d0n Quote Link to post Share on other sites
d0n 2 Posted December 12, 2018 Share Posted December 12, 2018 Lspci output : 0000:03:00.0 Class 0c03: Device 1912:0015 (rev 02) (prog-if 30) Flags: fast devsel, IRQ 16 Memory at fe9fe000 (64-bit, non-prefetchable) Capabilities: [50] Power Management version 3 Capabilities: [70] MSI: Enable- Count=1/8 Maskable- 64bit+ Capabilities: [90] MSI-X: Enable- Count=8 Masked- Capabilities: [a0] Express Endpoint, MSI 00 Capabilities: [100] Advanced Error Reporting Capabilities: [150] Latency Tolerance Reporting Quote Link to post Share on other sites
d0n 2 Posted December 12, 2018 Share Posted December 12, 2018 On 11/1/2018 at 12:16 PM, Josh said: I can not help with your card but i have this card working under DSM 6.2/1.03b (3615) on my N54L: https://www.delock.de/produkte/1112_USB-3-0/89243/merkmale.html?setLanguage=en Regards Are you sure it is the 89243 card? Quote Link to post Share on other sites
swizzls_mtlow 1 Posted December 17, 2018 Author Share Posted December 17, 2018 As an update because I had inadvertantly upgraded to 6.2 and didnt feel like trying to downgrade to get my card to work, I purchased a Dell U3N2-D pci-e USB3 card which seems to work ok. There was another thread on here discussing compatible cards. Just need to sort out the not fully powering off issue now! 1 Quote Link to post Share on other sites
d0n 2 Posted December 22, 2018 Share Posted December 22, 2018 I got me an Card with uPD720200 instead of uPD720202 and USB 3 works again I will have a look whats about n54l powering off here Quote Link to post Share on other sites
sszpila 1 Posted February 9, 2019 Share Posted February 9, 2019 (edited) Hi. I managed to get my uPD720202 work again. I flashed newest firmware (2.0.2.6) for this card and everything works. Firmware downloaded from Station Drivers https://www.station-drivers.com/index.php?option=com_remository&Itemid=353&func=fileinfo&id=1348&lang=en Flasher is for windows only, so I must boot microserver from USB with Windows PE Edited February 9, 2019 by sszpila 1 Quote Link to post Share on other sites
Stefano 1 Posted March 6, 2019 Share Posted March 6, 2019 (edited) On 2/9/2019 at 12:16 PM, sszpila said: Hi. I managed to get my uPD720202 work again. I flashed newest firmware (2.0.2.6) for this card and everything works. Firmware downloaded from Station Drivers https://www.station-drivers.com/index.php?option=com_remository&Itemid=353&func=fileinfo&id=1348&lang=en Flasher is for windows only, so I must boot microserver from USB with Windows PE Hi sszpila, i would like to thank you for the tip!!! it worked perfectly for my Startech PEXUSB3S25 Renesas/NEC uPD720202 that is just arrived today. p.s. I have an HP N40L with 1.0.3b loader with latest DSM 6.2.1 U6 update Edited March 6, 2019 by Stefano Quote Link to post Share on other sites
TomX 1 Posted February 26, 2020 Share Posted February 26, 2020 On 2/9/2019 at 12:16 PM, sszpila said: Hi. I managed to get my uPD720202 work again. I flashed newest firmware (2.0.2.6) for this card and everything works. Firmware downloaded from Station Drivers https://www.station-drivers.com/index.php?option=com_remository&Itemid=353&func=fileinfo&id=1348&lang=en Flasher is for windows only, so I must boot microserver from USB with Windows PE Hello sszpila, Thank you for the hint, I bought this USB 3 PCIe card https://www.amazon.fr/gp/product/B0094H9NK8/ref=ppx_yo_dt_b_asin_title_o03_s00?ie=UTF8&psc=1 and I made the firmware update like you wrote and now all is good with my HP N54L 1.03b loader DSM 6.2.2-24922 Update 4 Regards, TomX Quote Link to post Share on other sites
