Clemens65 0 Posted August 12, 2018 Share Posted August 12, 2018 Hi there, is there a known working replacement für the named adapters? There is a bunch of low priced adapters available in the sub 50Euro segment, did anyone give it a try? https://geizhals.de/?cat=hdadko&xf=13269_2~13272_PCIE100~13286_M2SATA Want to use this as SSD Cache (read/write) with 2 x Kingston SSDNow 240GB I'm using all 8 SATA-Ports of my Supermicro X11SAE-F, still one m.2 slot in spare which i intend to use für virtual machines as separate volume. Any suggestions are very much aprreciated. Best regards Clemens Quote Link to post Share on other sites
Clemens65 0 Posted August 18, 2018 Author Share Posted August 18, 2018 No idea? I just learned a little bit about M2D18, that it only works with NVMe-Disks. So the package would be M2D18 plus 2 x Samsung SSD 970 PRO 512GB. Samsung Pro due to TBW of 600TB, as Synology kicks out SSDs, when TBW is reached (due to SMART-Data). So if anyone could point to another m.2 Adapter, which is supported, thanks in advance. Quote Link to post Share on other sites
