astrorion Posted June 21, 2018 #1 Posted June 21, 2018 I have done up 2 bare metal NAS, DS3615xs and DS3617xs. I wish to copies all my Music from DS3615xs to DS3617xs. I am not able to mount either way from both NAS. An error message " Failed to connect remote folder." Strange is both DS3615xs and DS3617xs are able to mount my SYNOLOGY NAS DS413 and vice a versa back. Anyone can help on this? Thanks Quote
0 Olegin Posted June 21, 2018 #2 Posted June 21, 2018 1. Activate NFS in both NAS 2. Give access to the folder in source NAS by NFS 3. In terminal mount it to the target folder sudo mount 192.168.X.X:/volume1/source_folder /volume1/target_folder -o udp,soft Quote
0 astrorion Posted June 21, 2018 Author #3 Posted June 21, 2018 2 hours ago, Olegin said: 1. Activate NFS in both NAS 2. Give access to the folder in source NAS by NFS 3. In terminal mount it to the target folder sudo mount 192.168.X.X:/volume1/source_folder /volume1/target_folder -o udp,soft I assume the terminal mount is using linux, but I am using windows. How do I mount with windwows? Quote
0 Olegin Posted June 21, 2018 #4 Posted June 21, 2018 (edited) 10 минут назад, astrorion сказал: How do I mount with windwows? Install putty and connect by telnet or ssh in it. P.S. In windows you can use samba, find your NAS (\\your_NAS_ip) and map network drive Edited June 21, 2018 by Olegin Quote
0 astrorion Posted June 21, 2018 Author #5 Posted June 21, 2018 Thanks for the help, I uses telnet and able to work. Quote
astrorion
4 answers to this question
