How to get correct system Info in DSM (CPU, RAM, Serial)
Dear All!
I was install DSM on my Server buy use ISO file XPEnology, it work oK, but i can't change serial of DSM and CPU infomation is incorrect (It's show default CPU).
Pls tell me how to fix it?
2 answers to this question
Answered countless times. There is no need to change the serial number and the CPU information is hardcoded so you wont be able to change it. It's simply a cosmetic issue. Your CPU's actual specs are actually being used by DSM.
