Im looking for a nas setup as cheap as possible i dont need a case or drives (got those coverd).
What i need is motherboard, cpu and ram which can run xpenology with plex (i need 2 transcoded streams)
Bonus woud be to run proxmox.
If possible i'd like to get this stuff from ebay (best case woud be ebay germany).
thx 4 reading.
-Sammy
Edit:
Putting a steam libary on it shoudent be a problem right? i have a ssd here i coud use as a cache but is that even posible?
Edited by speatzle_
  • 3 weeks later...
for the transcoded hardware i can not help. But putting a steam libary on it yes it is possible, you can set network directory as a drive in windows. But i think you will be not happy with the loading times ;)
I expect ApolloLake to work fine with the new 6.2 since 918 uses the same arhitecture.
GA-J3355N-D2P
GA-J3455N-D3H
Asrock 3355B-ITX
Asrock J3455B-ITX
Asrock J3455-ITX
Asrock J4205-ITX
Le 15/06/2018 à 02:25, x01015918 a dit :
GA-J3355N-D2P
GA-J3455N-D3H
Asrock 3355B-ITX
Asrock J3455B-ITX
Asrock J3455-ITX
Asrock J4205-ITX
HI,
Network chipset natively recognized ?
il y a une heure, x01015918 a dit :
everything works with the current  6.2 alpha image, network, hw transcoding, etc
I just buy an Asrock J3455-ITX on Amazon
My i7-8700k will be recycled for an gamer pc
depends on the nic, in most cases its a cheap realtek and jun provided r8168/r8169 drivers, so its likely to work
no, thats not the entirely correct, may be your nic did work but jun's extra.lzma does not contain "all" network drivers we used before on 6.0 and 6.1
there are intel drivers present (e1000, e1000e, igb, ixgbe) but my Intel Gigabit CT Desktop Adapter did came up on 1st booting 1.03a2, but after installing dsm and rebooting i lost the connection and had to use a different hardware to finish the installation - so my experience was a little flawed
also there are firmware files missing for bnx2 driver (like with loader 1.02x the mips *.fw files are missing)
we would need more effort in documenting what hardware is ootb working with 1.03a2 (cpu amd drivers) and also start a driver list/package like we have for 6.0/6.1
its still to early to say "everything works", i would not rush people into using that early version, there might even be hidden bugs that come up on first dsm update (we had this last year, when after updating dsm support for all additional drivers from extra.lzma where lost on some systems)
Le 23/06/2018 à 20:35, x01015918 a dit :
Il y a 21 heures, IG-88 a dit :
Hi
The network on asrock j3455 itx is not really recognized ...... chipset is Realtek RTL8111GR ........ (install ok, but after reboot , i have migrate only and network is very slow)
4 hours ago, stefauresi said:
Hi
jun driver is 8.0.44, the latest realtek is offering is 8.0.45 so its pretty close to latest
when i'm doing a extra.lzma we can try the latest from realtek and also the build in driver from the kernel, in the meantime you can try a different/better cable
not sure why the realtek chips give so diffrent performance, i have a pcie card with realtek for testing and that one is working good, 112MB/s with large files
I tried DSM6.2 DS918+
The HW Transcoding does not ok on my J3455 , S/N & Mac ok , activation.conf ok
But transcoding does not start, without error message (in SSH)
With Plex it's the same, black screen , if i try transcode with VideoStation i get  1-1-1-1 in counter
I do not understand.
Edited by stefauresi
  • 3 weeks later...
On 6/27/2018 at 12:25 PM, stefauresi said:
for plex you need to force the transcoding by disabling the direct play in player options.
