mpuff Posted May 27, 2018 #1 Posted May 27, 2018 (edited) Hello community, is there a way to downgrade from 6.2 to 6.1 i have tried the update to 6.2, and now my box is bricked, i doesnt get an ip address, so i cant connect per ssh to the system. i copy now my data from the disks with an bootet ubuntu. i have Jun's loader 1.02b thank you. Edited May 27, 2018 by mpuff
1 sbv3000 Posted May 28, 2018 #2 Posted May 28, 2018 try the clean drive process in this thread, adjusted for your virtual disks
0 LolleQ Posted May 27, 2018 #3 Posted May 27, 2018 7 hours ago, mpuff said: is there a way to downgrade from 6.2 to 6.1 i have tried the update to 6.2, and now my box is bricked, i doesnt get an ip address, so i cant connect per ssh to the system. i copy now my data from the disks with an bootet ubuntu. i have Jun's loader 1.02b Have you tried "reinstall" option in grub boot menu?
0 luuray Posted May 28, 2018 #4 Posted May 28, 2018 7 hours ago, LolleQ said: Have you tried "reinstall" option in grub boot menu? use reinstall option in my ESXi box is not working...so sad
0 mpuff Posted May 28, 2018 Author #5 Posted May 28, 2018 (edited) i wil try it today Edited May 28, 2018 by mpuff
0 mpuff Posted May 29, 2018 Author #6 Posted May 29, 2018 i have tried the secound option from the administrator, but when i create a new usb stick with juns loader 1.02b, an copy the grub.cfg on it, the stick boots, but i doesnt get an ip from the fritzbox and the synology assistant doesnt find a new syno i have a microgen server 8 from hp.
0 LolleQ Posted May 29, 2018 #7 Posted May 29, 2018 1 minute ago, mpuff said: i have tried the secound option from the administrator, but when i create a new usb stick with juns loader 1.02b, an copy the grub.cfg on it, the stick boots, but i doesnt get an ip from the fritzbox and the synology assistant doesnt find a new syno i have a microgen server 8 from hp. Try other MAC/SN combination.
0 mpuff Posted May 29, 2018 Author #8 Posted May 29, 2018 have changed the SN, but also not. I have also installed the extra.lzma for ds3615 v4.8
0 mpuff Posted May 29, 2018 Author #9 Posted May 29, 2018 when i boot without the disks, it works, but the next problem is, the controller in the microserver is not hotplug
0 LolleQ Posted May 29, 2018 #10 Posted May 29, 2018 6 minutes ago, mpuff said: when i boot without the disks, it works, but the next problem is, the controller in the microserver is not hotplug Choose "reinstall" with all drives connected, then try to find NAS with Synology Assistant. Worked for me, but not with 6.2 installed. Perhaps it is not a bad idea to prepare quite new USB stick with 1.02b Jun's loader... With different MAC and SN.
0 mpuff Posted May 29, 2018 Author #11 Posted May 29, 2018 ok, i have plugged in the disks when the boot was ok, now i installed the 6.1 and i have installed it, all data are there 1
0 Dfds Posted May 31, 2018 #12 Posted May 31, 2018 The question(s) in this topic have been answered and/or the topic author has resolved their issue. This topic is now closed. If you have other questions, please open a new topic.
mpuff
Hello community,
thank you.
Edited by mpuff11 answers to this question
