xfwhwh Posted February 26, 2014 Share #1 Posted February 26, 2014 I want to install DSM on my HP N54L through Hyper V,and the system is windwos server 2012 R2. I follow the guide with viewtopic.php?f=2&t=551&start=30. It all OK before step 28, and I install the .pat file and got the Error 22, after I shut it down and replace the VHD with the original VHD file. The system can reboot but can not enter the DSM The last lines that show and stop on the VM display are like: =============== killall:getty: no process killed 0 0 0 0 0 0 0 --:--:-- 0:00:01 --:--:-- 0 0 0 0 0 0 0 0 --:--:-- 0:12:19 --:--:-- 0 =============== it should look like: =============== DiskStation Login:_ =============== How can I solve this problem? Thank you ! Link to comment Share on other sites More sharing options...
xfwhwh Posted March 1, 2014 Author Share #2 Posted March 1, 2014 I have solved this problem, I re-install with DSM 4.2 3211AIO version, and now it works fine on my N54L, but the VPN function is not working, sigh.. Link to comment Share on other sites More sharing options...
