Anyone have any ideas on how to bring a volume back to life after a crash during drive expansion?
I'm using 5.2 on Hyper-V. I was adding a new hard drive, it got to about 10% then I lost power to the Hyper-V host.
When my machine came back up it said it'd crashed. I didn't panic so much, it started an integrity check that took just over 24 hours. Once it completed it didn't come back to life.
I took the extra disk out, tried again, nothing.
When I reboot, I get:
"The system has detected one or more crashed storage spaces. Please check the following expansion units and hard disks are connected properly and functioning normally: [Disk 5, Disk 8, Disk 10, Disk 11].
When I got into Storage Manager I get:
"Unable to use this volume. The data in the volume may be crashed. Please try to back up the data before removing the volume."
I literally have no idea where to start. When I use my own account to SSH into the box it drops off immediately. I enabled my admin account and can now get into the box via Putty. My folder structure still exits in Volume1/@eaDir, but it literally is just the folder structure.
Any help would be massively appreciated. If there's any log files I need to provide, just say so!
elmuziko
Afternoon all,
Edit: SUDO apparently isn't installed.
Edited by elmuzikoLink to comment
1 answer to this question
