How to configure more than 5 network cards ?
manzo
Greetings,
I am working on a lab iscsi storage box, the project need to put out
a MASSIVE throughput using MPIO, so i am equipping the box with 8x1Gb network cards,
one is an intel 4 ports server nic, it is recognized and configured fine,
no modules issues, the other 4 nics are standard Realtek Pcie Gb nics,
Rtl8168 chipset, same as above, cards recognized so no driver issues.
So far everything is working well, but i found a very annoying issue:
Apparently Xpenology cant see more than 5 network cards,
it enable the 4 intel ports and one of the Rtl, but after that,
no more are displayed under the DSM network configuration tab.
I tryed to modify the grub.conf and increase the number of nics,
xpenology create the ifcfg-ethx under /etc/sysconfig/network-scripts
but they wont appear in the Dsm configurator, nor am i able to bring em online
thru the command line.
Any help ?
