JanHoedt Posted February 7, 2014 Share #1 Posted February 7, 2014 Hi, I added a dual nic to my HP NL40, it worked fine but after reboot everything is gone. I fully configured the system with DSM 5.0 beta. All data is on it. The console session just gives a blinking cursor. I previously installed on HP NL 40 with network card inserted and that worked, adding it causes issues apparently. Please advise. Should I make a new usb stick and boot it from there? Can I then recover my data? J. Link to comment Share on other sites More sharing options...
stanza Posted February 7, 2014 Share #2 Posted February 7, 2014 can you not log in and run ifconfig to see what IP address it has? probably changed eth0 to eth1 (from adding the card in) in which case you might have to swap cables between ports and reconfigure mac addresses to the correct ones. . Link to comment Share on other sites More sharing options...
XPEH Posted February 7, 2014 Share #3 Posted February 7, 2014 The console session just gives a blinking cursor. Check in the BIOS if your USB drive is still first and only boot device. Link to comment Share on other sites More sharing options...
