Connecting UPS leads to crash (n54l+DSM 4.3+ESXi 5.5)
jms667
Hello all,
My system :
- HP n54l with 8Go RAM
- ESXi 5.5
- DSM 4.3 3810 (synoboot_trantor_3810_esxi_v1.1)
- UPS eaton (working fine on a 410j)
Plugging the UPS leads XPEnology to crash (crashdump ...).
When I plug a USBkey on the same USB port it's OK (detected and browsable inside filestation for example).
When I Plug and map the same UPS to a Linux VM running in the same box, it's OK.
Jan 24 15:28:42 gateway2 kernel: [27249.832184] usb 2-2.1: new low-speed USB device number 5 using uhci_hcd
Jan 24 15:28:46 gateway2 kernel: [27253.818623] usb 2-2.1: New USB device found, idVendor=0463, idProduct=ffff
Jan 24 15:28:46 gateway2 kernel: [27253.818628] usb 2-2.1: New USB device strings: Mfr=1, Product=2, SerialNumber=4
Jan 24 15:28:46 gateway2 kernel: [27253.818631] usb 2-2.1: Product: Protection Station
Jan 24 15:28:46 gateway2 kernel: [27253.818633] usb 2-2.1: Manufacturer: EATON
Jan 24 15:28:46 gateway2 kernel: [27253.818634] usb 2-2.1: SerialNumber: AN2E49008
Jan 24 15:28:48 gateway2 kernel: [27256.015055] generic-usb 0003:0463:FFFF.0004: hiddev0,hidraw2: USB HID v10.10 Device [EATON Protection Station] on usb-0000:02:02.0-2.1/input0
Help would be appreciate.
Thanks.
