damdam Posted January 22, 2014 Share #1 Posted January 22, 2014 Hi there, I'm running the latest stable XPenology build with DSM 4.3 update 4 on a HP D54L (mod Biod, 8Gb, 4x3Tb SHR). So far so good. In fact, no. Not so good. NFS is perfect. Booting from the USB key is fine. My UPS is well connected with USB. But I can't plug any hard-drive with USB. At startup : won't boot (after all the bios messages, the cursor blinf on a black screen and that's it) Wihle running : Freeze. Any ideas ? Note that I have a Highpoint RocketU 1022A (USB 3.0) plugged in the PCI-Express port but it isn't powered at this time so I never plugged any drive on it and the issus is USB 2.0. Thanks a lot !!! Link to comment Share on other sites More sharing options...
mcdull Posted January 23, 2014 Share #2 Posted January 23, 2014 re-format your HDD and try again. My 4TB is behaving the same before. And ... ex-fat seems to be the root cause. Link to comment Share on other sites More sharing options...
