SHR - Re-use Disk?
Turbine-7
Not knowing much about SHR, I created a SHR single disk volume with a 250GB disk. I later added 2 x 4TB disks thinking I could create a second SHR volume, but realised that wasn't possible. So I added one disk into the volume, then when done removed the original 250GB disk and repaired the volume so that it's now healthy again. What will happen if I put this disk back into the server as it contains SHR info. Will it just allow me to create a new volume on it, or will I have to format it somehow before re-introducing it?
Thinking more about it, I guess I could remove both 4TB disks, put in the 250GB and delete the volume, then power back on with all 3 disks leaving everything intact?
