[HELP] New Hard Drive "not detected"
Akhlan
Hello,
I currently runs XPEnology DSM 4.3 update 4 and it works perfectly but I'm left more than 300GB on my 8TB (Raid 5). So I bought two 3TB disks but when I plug them, they are well seen in the BIOS, but not in DSM interface, impossible to add in my volume, checkbox remains gray> <
How can add my HDD?
thank you
Akhlan
of course Trantor...
Hardware
- ASRock FM2A85X-ITX
- G.Skill RipJaws X Series 8 Go (2x 4Go) DDR3 2133 MHz CL9
- AMD A10-6700 (3.7 GHz)
- 4 x WD Red Desktop 3 To SATA 6Gb/s working fine
- 2 x WD Red Desktop 3 To SATA 6Gb/s not detected
Software
- XPEnology DS3612xs DSM 4.3 build 3810++ (Update 4)
Screenshot:
http://awesomescreenshot.com/04b27c6w9c
Rgds
Akhlan
I've already try on another port...
fdisk: device has more than 2^32 sectors, can't use all of them
Disk /dev/sda: 2199.0 GB, 2199023255040 bytes
255 heads, 63 sectors/track, 267349 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
  Device Boot      Start         End      Blocks  Id System
/dev/sda1               1      267350  2147483647+ ee EFI GPT
Disk /dev/sdb: 2199.0 GB, 2199023255040 bytes
/dev/sdb1               1      267350  2147483647+ ee EFI GPT
Disk /dev/sdc: 2199.0 GB, 2199023255040 bytes
/dev/sdc1               1      267350  2147483647+ ee EFI GPT
Disk /dev/sdd: 2199.0 GB, 2199023255040 bytes
/dev/sdd1               1      267350  2147483647+ ee EFI GPT
Disk /dev/sdu: 4004 MB, 4004511744 bytes
255 heads, 63 sectors/track, 486 cylinders
/dev/sdu1   *           1           2       16033+ 83 Linux
dmesg | egrep "(s|h)d[a-z]"
[    2.451483] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.451501] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.451612] sd 0:0:0:0: [sda] Write Protect is off
[    2.451650] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.451670] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.452151] sd 1:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.452193] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    2.452277] sd 1:0:0:0: [sdb] Write Protect is off
[    2.452316] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.452336] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.452919] sd 2:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.452962] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[    2.453049] sd 2:0:0:0: [sdc] Write Protect is off
[    2.453087] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    2.453106] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.453527] sd 3:0:0:0: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.453569] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[    2.453651] sd 3:0:0:0: [sdd] Write Protect is off
[    2.453688] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    2.453707] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.501314]  sdd: sdd1 sdd2 sdd5
[    2.501775] sd 3:0:0:0: [sdd] Attached SCSI disk
[    2.509138]  sda: sda1 sda2 sda5
[    2.509521] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.513520]  sdb: sdb1 sdb2 sdb5
[    2.513919] sd 1:0:0:0: [sdb] Attached SCSI disk
[    2.514334]  sdc: sdc1 sdc2 sdc5
[    2.514728] sd 2:0:0:0: [sdc] Attached SCSI disk
[    2.587963] md: invalid raid superblock magic on sda5
[    2.588010] md: sda5 does not have a valid v0.90 superblock, not importing!
[    2.659534] md: invalid raid superblock magic on sdb5
[    2.659573] md: sdb5 does not have a valid v0.90 superblock, not importing!
[    2.738257] md: invalid raid superblock magic on sdc5
[    2.738297] md: sdc5 does not have a valid v0.90 superblock, not importing!
[    2.815661] md: invalid raid superblock magic on sdd5
[    2.815710] md: sdd5 does not have a valid v0.90 superblock, not importing!
[    2.815828] md: considering sda1 ...
[    2.815869] md:  adding sda1 ...
[    2.815906] md: sda2 has different UUID to sda1
[    2.815944] md:  adding sdb1 ...
[    2.815980] md: sdb2 has different UUID to sda1
[    2.816033] md:  adding sdc1 ...
[    2.816070] md: sdc2 has different UUID to sda1
[    2.816107] md:  adding sdd1 ...
[    2.816144] md: sdd2 has different UUID to sda1
[    2.816223] md: bind
[    2.816270] md: bind
[    2.816309] md: bind
[    2.816348] md: bind
[    2.816388] md: running:
[    2.816966] md: considering sda2 ...
[    2.817012] md:  adding sda2 ...
[    2.817049] md:  adding sdb2 ...
[    2.817087] md:  adding sdc2 ...
[    2.817124] md:  adding sdd2 ...
[    2.817312] md: bind
[    2.817353] md: bind
[    2.817392] md: bind
[    2.817432] md: bind
[    2.817471] md: running:
[    9.246637] md: bind
[    9.254378] md: bind
[    9.263091] md: bind
[    9.263248] md: bind
[    9.263889] md/raid:md2: device sda5 operational as raid disk 0
[    9.263928] md/raid:md2: device sdd5 operational as raid disk 3
[    9.263965] md/raid:md2: device sdc5 operational as raid disk 2
[    9.264023] md/raid:md2: device sdb5 operational as raid disk 1
[    9.264360]  disk 0, o:1, dev:sda5
[    9.264361]  disk 1, o:1, dev:sdb5
[    9.264362]  disk 2, o:1, dev:sdc5
[    9.264363]  disk 3, o:1, dev:sdd5
[   16.365410] sd 4:0:0:0: [sdu] 7821312 512-byte logical blocks: (4.00 GB/3.72 GiB)
[   16.365928] sd 4:0:0:0: [sdu] Write Protect is off
[   16.365968] sd 4:0:0:0: [sdu] Mode Sense: 43 00 00 00
[   16.366558] sd 4:0:0:0: [sdu] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   16.369821]  sdu: sdu1
[   16.371840] sd 4:0:0:0: [sdu] Attached SCSI removable disk
[   18.052141] EXT4-fs (sdu1): mounted filesystem without journal. Opts: nodelalloc,synoacl,data=ordered,oldalloc
I wanted launch a "hwinfo --storage-ctrl | grep -i model" but "hwinfo" isn't know by sustem...
Stupid Question ^^ : My hard drive is new, it should have been formatted before connecting?
I have re check... HDD enable in BIOS and AHCPI activated
[    2.408116] sd 0:0:0:0: [sda] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.408162] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    2.408243] sd 0:0:0:0: [sda] Write Protect is off
[    2.408280] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.408298] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.408877] sd 1:0:0:0: [sdb] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.408918] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[    2.408995] sd 1:0:0:0: [sdb] Write Protect is off
[    2.409036] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    2.409055] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.409537] sd 2:0:0:0: [sdc] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.409580] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[    2.409659] sd 2:0:0:0: [sdc] Write Protect is off
[    2.409697] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    2.409716] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.410195] sd 3:0:0:0: [sdd] 5860533168 512-byte logical blocks: (3.00 TB/2.72 TiB)
[    2.410236] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[    2.410318] sd 3:0:0:0: [sdd] Write Protect is off
[    2.410355] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    2.410373] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.463508]  sdd: sdd1 sdd2 sdd5
[    2.463916] sd 3:0:0:0: [sdd] Attached SCSI disk
[    2.464056]  sda: sda1 sda2 sda5
[    2.464342] sd 0:0:0:0: [sda] Attached SCSI disk
[    2.468719]  sdb: sdb1 sdb2 sdb5
[    2.469094] sd 1:0:0:0: [sdb] Attached SCSI disk
[    2.470119]  sdc: sdc1 sdc2 sdc5
[    2.470474] sd 2:0:0:0: [sdc] Attached SCSI disk
[    2.543024] md: invalid raid superblock magic on sda5
[    2.543064] md: sda5 does not have a valid v0.90 superblock, not importing!
[    2.614739] md: invalid raid superblock magic on sdb5
[    2.614779] md: sdb5 does not have a valid v0.90 superblock, not importing!
[    2.693862] md: invalid raid superblock magic on sdc5
[    2.693902] md: sdc5 does not have a valid v0.90 superblock, not importing!
[    2.777935] md: invalid raid superblock magic on sdd5
[    2.777975] md: sdd5 does not have a valid v0.90 superblock, not importing!
[    2.778101] md: considering sda1 ...
[    2.778142] md:  adding sda1 ...
[    2.778178] md: sda2 has different UUID to sda1
[    2.778216] md:  adding sdb1 ...
[    2.778253] md: sdb2 has different UUID to sda1
[    2.778290] md:  adding sdc1 ...
[    2.778326] md: sdc2 has different UUID to sda1
[    2.778364] md:  adding sdd1 ...
[    2.778400] md: sdd2 has different UUID to sda1
[    2.778479] md: bind
[    2.778525] md: bind
[    2.778565] md: bind
[    2.778608] md: bind
[    2.778649] md: running:
[    2.779264] md: considering sda2 ...
[    2.779304] md:  adding sda2 ...
[    2.779341] md:  adding sdb2 ...
[    2.779378] md:  adding sdc2 ...
[    2.779416] md:  adding sdd2 ...
[    2.779612] md: bind
[    2.779652] md: bind
[    2.779691] md: bind
[    2.779731] md: bind
[    2.779770] md: running:
[    9.300439] md: bind
[    9.300599] md: bind
[    9.300726] md: bind
[    9.300927] md: bind
[    9.301495] md/raid:md2: device sda5 operational as raid disk 0
[    9.301533] md/raid:md2: device sdd5 operational as raid disk 3
[    9.301569] md/raid:md2: device sdc5 operational as raid disk 2
[    9.301606] md/raid:md2: device sdb5 operational as raid disk 1
[    9.301925]  disk 0, o:1, dev:sda5
[    9.301926]  disk 1, o:1, dev:sdb5
[    9.301927]  disk 2, o:1, dev:sdc5
[    9.301928]  disk 3, o:1, dev:sdd5
[   15.733364] sd 4:0:0:0: [sdu] 7821312 512-byte logical blocks: (4.00 GB/3.72 GiB)
[   15.733889] sd 4:0:0:0: [sdu] Write Protect is off
[   15.733927] sd 4:0:0:0: [sdu] Mode Sense: 43 00 00 00
[   15.734511] sd 4:0:0:0: [sdu] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[   15.737249]  sdu: sdu1
[   15.739386] sd 4:0:0:0: [sdu] Attached SCSI removable disk
[   17.958080] EXT4-fs (sdu1): mounted filesystem without journal. Opts: nodelalloc,synoacl,data=ordered,oldalloc
what does it say up higher in dmesg?
eg 1st few seconds worth after all the pci stuff and before the network card drivers load
should show something like
[    0.290279] pci 0000:00:1d.2: PCI INT C -> GSI 18 (level, low) -> IRQ 18
[    0.290356] pci 0000:00:1d.2: PCI INT C disabled
[    0.290422] pci 0000:00:1d.7: PCI INT A -> GSI 23 (level, low) -> IRQ 23
[    0.290502] pci 0000:00:1d.7: PCI INT A disabled
[    0.290576] PCI: CLS 32 bytes, default 64
[    0.290634] Trying to unpack rootfs image as initramfs...
[    0.290826] rootfs image is not initramfs (no cpio magic); looks like an initrd
[    0.296531] Freeing initrd memory: 6212k freed
[    0.299427] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    0.299499] Placing 64MB software IO TLB between ffff8800bb69e000 - ffff8800bf69e000
[    0.299583] software IO TLB at phys 0xbb69e000 - 0xbf69e000
[    0.301253] VFS: Disk quotas dquot_6.5.2
[    0.301341] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.301561] Registering the id_resolver key type
[    0.301712] msgmni has been set to 7897
[    0.301797] async_tx: api initialized (async)
[    0.301903] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[    0.301987] io scheduler noop registered
[    0.302063] io scheduler cfq registered (default)
[    0.302225] pcieport 0000:00:1c.0: setting latency timer to 64
[    0.302267] pcieport 0000:00:1c.0: irq 40 for MSI/MSI-X
[    0.302410] pcieport 0000:00:1c.2: setting latency timer to 64
[    0.302443] pcieport 0000:00:1c.2: irq 41 for MSI/MSI-X
[    0.302589] pcieport 0000:00:1c.5: setting latency timer to 64
[    0.302621] pcieport 0000:00:1c.5: irq 42 for MSI/MSI-X
[    0.320694] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    0.335667] brd: module loaded
[    0.335836] Loading iSCSI transport class v2.0-870.
[    0.336267] rdac: device handler registered
[    0.336517] Adaptec aacraid driver 1.2-1[30200]custom
[    0.336649] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[    0.336901] megasas: 00.00.06.12-rc1 Wed. Oct. 5 17:00:00 PDT 2011
[    0.337051] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[    0.337148] 3ware Storage Controller device driver for Linux v1.26.02.003.
[    0.337249] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[    0.337368] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[    0.337489] ipr: IBM Power RAID SCSI Device Driver version: 2.5.2 (April 27, 2011)
[    0.337611] RocketRAID 3xxx/4xxx Controller driver v1.6 (090910)
[    0.337709] stex: Promise SuperTrak EX Driver version: 4.6.0000.4
[    0.337855] VMware PVSCSI driver - version 1.0.1.0-k
[    0.338078] ahci 0000:00:1f.2: version 3.0
[    0.338093] ahci 0000:00:1f.2: PCI INT B -> GSI 19 (level, low) -> IRQ 19
[    0.338206] ahci 0000:00:1f.2: irq 43 for MSI/MSI-X
[    0.338255] ahci: SSS flag set, parallel bus scan disabled
[    0.338347] ahci 0000:00:1f.2: AHCI 0001.0200 32 slots 6 ports 3 Gbps 0x3f impl SATA mode
[    0.338434] ahci 0000:00:1f.2: flags: 64bit ncq sntf stag pm led clo pmp pio slum part ccc ems sxs
[    0.338523] ahci 0000:00:1f.2: setting latency timer to 64
[    0.348858] scsi0 : ahci
[    0.349053] scsi1 : ahci
[    0.349213] scsi2 : ahci
[    0.349370] scsi3 : ahci
[    0.349527] scsi4 : ahci
[    0.349681] scsi5 : ahci
[    0.349934] ata1: SATA max UDMA/133 abar m2048@0xfe97b000 port 0xfe97b100 irq 43
[    0.350027] ata2: SATA max UDMA/133 abar m2048@0xfe97b000 port 0xfe97b180 irq 43
[    0.350111] ata3: SATA max UDMA/133 abar m2048@0xfe97b000 port 0xfe97b200 irq 43
[    0.350195] ata4: SATA max UDMA/133 abar m2048@0xfe97b000 port 0xfe97b280 irq 43
[    0.350279] ata5: SATA max UDMA/133 abar m2048@0xfe97b000 port 0xfe97b300 irq 43
[    0.350363] ata6: SATA max UDMA/133 abar m2048@0xfe97b000 port 0xfe97b380 irq 43
[    0.350445] Enable Synology sata fast booting
[    1.300191] Refined TSC clocksource calibration: 2494.030 MHz.
[    1.300266] Switching to clocksource tsc
[    2.180467] sata_sil24 0000:02:00.0: version 1.1
[    2.180482] sata_sil24 0000:02:00.0: PCI INT A -> GSI 18 (level, low) -> IRQ 18
[    2.180607] sata_sil24 0000:02:00.0: setting latency timer to 64
[    2.180831] scsi6 : sata_sil24
[    2.180970] ata7: SATA max UDMA/100 host m128@0xfeaffc00 port 0xfeafc000 irq 18
[    2.181061] Enable Synology sata fast booting
[    2.640043] ata1: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    2.647475] ata1.00: ATA-8: WDC WD20EADS-32S2B0, 01.00A01, max UDMA/133
[    2.647541] ata1.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[    2.650677] ata1.00: configured for UDMA/133
[    2.653787] scsi 0:0:0:0: Direct-Access     WDC      WD20EADS-32S2B0          01.0 PQ: 0 ANSI: 5
[    2.654044] sd 0:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    2.654190] sd 0:0:0:0: [sda] Write Protect is off
[    2.656425] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    2.656448] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    2.687543]  sda: sda1 sda2 sda3 < sda5 sda6 >
[    2.687972] sd 0:0:0:0: [sda] Attached SCSI disk
[    3.114042] ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    3.164321] ata2.00: ATA-8: WDC WD20EADS-00R6B0, 01.00A01, max UDMA/133
[    3.164387] ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[    3.169490] ata2.00: configured for UDMA/133
[    3.174257] scsi 1:0:0:0: Direct-Access     WDC      WD20EADS-00R6B0          01.0 PQ: 0 ANSI: 5
[    3.174504] sd 1:0:0:0: [sdb] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    3.174653] sd 1:0:0:0: [sdb] Write Protect is off
[    3.174715] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    3.174736] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.229296]  sdb: sdb1 sdb2 sdb3 < sdb5 sdb6 >
[    3.229712] sd 1:0:0:0: [sdb] Attached SCSI disk
[    3.634042] ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    3.647129] ata3.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[    3.647195] ata3.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[    3.651074] ata3.00: configured for UDMA/133
[    3.654845] scsi 2:0:0:0: Direct-Access     WDC      WD20EARS-00MVWB0         51.0 PQ: 0 ANSI: 5
[    3.655089] sd 2:0:0:0: [sdc] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    3.655236] sd 2:0:0:0: [sdc] Write Protect is off
[    3.655297] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    3.655319] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    3.702646]  sdc: sdc1 sdc2 sdc3 < sdc5 sdc6 >
[    3.703060] sd 2:0:0:0: [sdc] Attached SCSI disk
[    4.115018] ata4: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    4.134911] ata4.00: ATA-8: WDC WD20EARS-00MVWB0, 51.0AB51, max UDMA/133
[    4.134977] ata4.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 31/32), AA
[    4.138829] ata4.00: configured for UDMA/133
[    4.142568] scsi 3:0:0:0: Direct-Access     WDC      WD20EARS-00MVWB0         51.0 PQ: 0 ANSI: 5
[    4.142810] sd 3:0:0:0: [sdd] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
[    4.142958] sd 3:0:0:0: [sdd] Write Protect is off
[    4.143022] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[    4.143044] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.193085]  sdd: sdd1 sdd2 sdd3 < sdd5 sdd6 >
[    4.193495] sd 3:0:0:0: [sdd] Attached SCSI disk
Connect all your drives and but with ubuntu livecd to see if all disks are detected.
On your screenshot SATA IDE Combined Mode is Enabled.
According to the mainboard manual:
This item is for SATA3_5, SATA3_6, SATA3_7 and eSATA3 ports. Use this
item to enable or disable SATA IDE combined mode. The default value is
[Disabled].
If you want to build RAID on SATA3_5, SATA3_6, SATA3_7 and
eSATA3 ports, please disable this item
Disable this option and retry.
  • 1 year later...
  • 7 months later...
