Drivers requests
Re: Drivers requests
Postby Aspery » 20 Nov 2013 02:08
Hi Trantor!
Thanks for the 4.3 release.
If possible, please add driver for Adaptec 5805z raid controller.
Driver can be found here
http://www.adaptec.com/en-us/support/ra ... sas-5805z/
Thanks!
Aspery
Postby stelle007 » 20 Nov 2013 19:57
Hi, Thanks for the great work.
XPEnology DS3612xs DSM 4.3 build 3810++ (repack v1.0) works great, but it's not picking up my LSI RAID cards 9211, this worked in XPEnology DS3612xs DSM 4.2 build 3211++ (repack v1.2). Can these drivers be added please?
Also as I understand it, in the DSM 4.2 build 3211++, it picks up the mpt2sas drivers to late in the boot process, so it have to repair the system partition on the drives attached to LSI RAID cards 9211 every reboot. Is it possible to fixed this?
Again thank you.
stelle007
Postby cadre » 20 Nov 2013 23:43
Hi Trantor, can't thank you everyone enough for all of your hard work.
I would love to be able to use my Intel SS4200-e NAS appliance with this, everything works just fine except the PATA port (which i really need to boot from) to keep my four sata ports available for data.
It uses an Intel 945GZ chipset with the ICH7-R controller..
I tested this with Ubuntu 12.04 64bit iso and was able to install and boot off of the pata port as long as the "pata_legacy" module is available and loaded at boot.
If I could get that pata_legacy.ko module included, that would be awesome. Thanks again.
cadre
Postby Schmill » 21 Nov 2013 17:39
Hi not sure if this is the correct place or not, but would it be possible to integrate the power button handler for the HP Microservers as discussed in this thread: Power off from the buttom(sic). Although what is discussed there works, the implementation uses a complete rebuild of busybox, renamed as the kind contributor that did it didn't want to risk messing anything else up in the busybox pack. If it was integrated then this shouldn't be an issue? - Thanks again :)
N54L
Baremetal install of XPEnology DS3615xs DSM 5.2-5967 Update 1 using XPEnoboot_DS3615xs_5.2-5644.5
Schmill
Postby fyngd » 22 Nov 2013 00:30
SIS190/SIS191 Network Driver
Driver download link: http://download.sis.com/download/
fyngd
Postby puwoo » 22 Nov 2013 21:05
thanks for your support.
DSM 4.3 build 3810++ (repack v1.0) is not working with ARECA arc-1220 SATA II RAID Card.
it was supported, but not working
system automatically going power off..
please, add driver, ARECA arc-1220....
puwoo
Postby Alligator » 25 Nov 2013 08:27
Hi Trantor!
Thanks for the DSM 4.3 build 3810++ (repack v1.0) release.
can anyone add Dlink DGE-528T ?
drivers link:
http://ftp.dlink.ru/pub/Adapter/DGE-528T/Drivers/DGE-528T_linux.rar
Alligator
Postby Angel » 27 Nov 2013 12:17
Keep up the good work!
It would be great if you could add TBSDTV DVB-S and DVB-T Drivers
http://www.tbsdtv.com/download/document ... 130927.zip
Then we could use DVBlink or TVHeadEnd and make an excellent PVR/Streaming server.
Thank you.
Angel
Postby Trantor » 27 Nov 2013 17:50
tangal98 wrote:If possible, please add driver for ITE 8212F raid controller.
Download page isn't working on the website. I send a email for support.
Aspery wrote:If possible, please add driver for Adaptec 5805z raid controller.
stelle007 wrote:LSI RAID cards 9211. Can these drivers be added please?
I done something wrong with aacraid and mpt2sas drivers. Will be fixed soon.
puwoo wrote:DSM 4.3 build 3810++ (repack v1.0) is not working with ARECA arc-1220 SATA II RAID Card.
Strange because arcmsr driver is built-in the kernel
Danyz wrote:
sbh wrote:one major issue, when you log in to the server via web browser it write on the center low area of the screen XPEnology 4.3 with a ugly font, the synology sign is much better ha ha ha :)
Why not make a topic with some poll for XPEnology logo ?
User avatar
Trantor
Postby 2cam » 27 Nov 2013 18:54
stelle007 wrote:Hi, Thanks for the great work.
Again thank you.
I have the same dream :)
Thank you for your great job.
regards
2cam
PreviousNext
x
