UNSC-117 Posted November 16, 2015 Share #1 Posted November 16, 2015 (edited) Can we go over the 12 HD Capacity? Edited November 28, 2015 by Guest Link to comment Share on other sites More sharing options...
brantje Posted November 16, 2015 Share #2 Posted November 16, 2015 Yes, i've seen a config with 24 drives =). Link to comment Share on other sites More sharing options...
sbv3000 Posted November 17, 2015 Share #3 Posted November 17, 2015 search this forum for how to edit the synoinfo.conf files to allow more than 12 drives I've built 16 and 24 drive units and it works fine provided you get the conf correct for your hardware Link to comment Share on other sites More sharing options...
UNSC-117 Posted November 18, 2015 Author Share #4 Posted November 18, 2015 search this forum for how to edit the synoinfo.conf files to allow more than 12 drivesI've built 16 and 24 drive units and it works fine provided you get the conf correct for your hardware Searched, nothing found could you please guide me to where it is? Link to comment Share on other sites More sharing options...
brantje Posted November 18, 2015 Share #5 Posted November 18, 2015 Yes, i've seen a config with 24 drives =). Click on the '24' Link to comment Share on other sites More sharing options...
UNSC-117 Posted November 19, 2015 Author Share #6 Posted November 19, 2015 /etc.default/synoinfo.conf where is this file??? Link to comment Share on other sites More sharing options...
sbv3000 Posted November 19, 2015 Share #7 Posted November 19, 2015 enable telnet and ssh, use winscp or similar to login as root/your admin password then look in the root folder. you will need to change the settings for max disks, esataportcfg, usbportcfg and internalportcfg to match the hex settings that your system needs Link to comment Share on other sites More sharing options...
