[SOLVED]failed to upgrade the Cloud Station DB
Daiki
on DSM 4.2 (3202) with ESXI, i can't get Cloud Station to work.
always get the red message on enable "Failed to upgrade Cloud Station Database. Please try again or delete database"
I deleted the @CloudStation folder - so the database - no luck
of course also tried uninstall and reinstall, same result
would anyone have the same problem or got it running?
That folder doesn't look loke a database mate. You deleted a folder.
If you don't have any knowledge of databases, try to install webmin on your DSM and try to drop/delete the database from that nice web gui.
We wish you the best luck!
