How noise is the HP Micro gen8 with XPEnology?
nemesis122
Mine is louder than the pc; the fan is 6-9% (esxi, bare metal is 18-26%) but it has an annoying coil noise. I returned the first unit for this reason (celeron) and got one with a xeon in replacement (paid the difference) and it was ok for about 2 weeks, then it started. The only solution is to replace the system fan, very expensive from hp or look for another compatible one (50-75% cheaper)
This is the second and last product I will ever buy from hp; the only reason I bought the gen 8 was that the price/performance ratio was hard to beat with a custom build from components.
