boosterbosch Posted August 20, 2015 Share #1 Posted August 20, 2015 Just seen that DSM 5.2-5592 Update 3 has been released by Synology. Release Notes: Version : 5.2-5592 Update 3 (2015/08/20) Fixed Issues Optimized fan settings for DS715 and DS215+. Enhanced compatibility with hard drives. Improved the compatibility with UPS devices. Fixed an issue where the NTP (Network Time Protocol) service became temporarily unavailable after manual calibration. Anyone know if we can just update to this with the latest version of xpenoboot? Quote Link to comment Share on other sites More sharing options...
yhlovemm Posted August 20, 2015 Share #2 Posted August 20, 2015 all disk will be unmounted and can NOT be mount Quote Link to comment Share on other sites More sharing options...
Eprom Posted August 20, 2015 Share #3 Posted August 20, 2015 Boot with install/upgrade option Quote Link to comment Share on other sites More sharing options...
lobic Posted August 20, 2015 Share #4 Posted August 20, 2015 all disk will be unmounted and can NOT be mount after second reboot everything seems to be OK (verified on 3 xpenos: N54l, ESXi and QNAP TS-469PRO) Quote Link to comment Share on other sites More sharing options...
sstyle Posted August 20, 2015 Share #5 Posted August 20, 2015 So, should I use an install/upgrade mode or not? Quote Link to comment Share on other sites More sharing options...
boosterbosch Posted August 20, 2015 Author Share #6 Posted August 20, 2015 all disk will be unmounted and can NOT be mount restart one more time and it will re-mount all drives Quote Link to comment Share on other sites More sharing options...
woopwoop Posted August 20, 2015 Share #7 Posted August 20, 2015 Have installed update 3 today virtualized on kvm and had no disk after the restart from the Update. After next reboot everything is working fine again. just reboot at minimum twice and everything should work as expected edit: experienced off behavior: update 3 disabled my rsync. i had to reenable it. but again aft er that it seems like it is fully functioning Quote Link to comment Share on other sites More sharing options...
Jman420 Posted August 20, 2015 Share #8 Posted August 20, 2015 Although I haven't had a chance to do any testing on Update 3 (will be migrating my test & live servers tonight), I have briefly spoken with Vortex who has said that the unmounted volumes is normal on the first reboot. As for certain services needing to be manually re-enabled, I would guess that is related to the unmounted volumes (ie. Web Station disables itself because it cant find the 'web' folder; rsync disables itself because there are no volumes to sync). Quote Link to comment Share on other sites More sharing options...
R0GGER Posted August 20, 2015 Share #9 Posted August 20, 2015 Before I update... Safe or unsafe? Quote Link to comment Share on other sites More sharing options...
yhlovemm Posted August 21, 2015 Share #10 Posted August 21, 2015 all disk will be unmounted and can NOT be mount after second reboot everything seems to be OK (verified on 3 xpenos: N54l, ESXi and QNAP TS-469PRO) all disk will be unmounted and can NOT be mount restart one more time and it will re-mount all drives It work! after restart twice, everything come back!! Quote Link to comment Share on other sites More sharing options...
yhlovemm Posted August 21, 2015 Share #11 Posted August 21, 2015 after second reboot everything seems to be OK (verified on 3 xpenos: N54l, ESXi and QNAP TS-469PRO) restart one more time and it will re-mount all drives It work! after restart twice, everything come back!! Quote Link to comment Share on other sites More sharing options...
YoungHo Posted August 21, 2015 Share #12 Posted August 21, 2015 manual download ! http://download.synology.com/download/c ... ck/5592-3/ update after (will rebooting) 1. 2nd rebooting ( all unmounted drives) 2. homes enable (disabled) 3. once run media index (Audio Station and Video Station not works) Quote Link to comment Share on other sites More sharing options...
htc2010 Posted August 21, 2015 Share #13 Posted August 21, 2015 Yes, I can confirm that update 3 works. Just reboot into upgrade/migrate mode, run the updater from control panel. I let the system download it directly and update it and reboot the first time. Confirmed, first reboot, volumes are missing. Reboot again and volumes come back. Per YoungHo, gotta re-enable user home service as well as re-run the media indexing function. So far, these services need to be manually restarted, even after the 2nd reboot: 1. User Home Service 2. Media Indexing 3. Log Center 4. Backup Service I have a bare-metal install with no apps other than default so I'm not sure what else might be effected. Can anyone confirm any other system services/apps that needed a manual stop/start to get back going after update 3 installation? Add your comments here! Quote Link to comment Share on other sites More sharing options...
jestosebno Posted August 21, 2015 Share #14 Posted August 21, 2015 UPS connect/disconnect still present. Quote Link to comment Share on other sites More sharing options...
fly Posted August 21, 2015 Share #15 Posted August 21, 2015 hi guys, i rebooted several times with no luck, my update went automatically yesterday en since then cant do anything with nas. because no hdd is found and all services is down. if i log and try to change things like restoring settings or pointing hdd get a error ( The operation failed. plz log in to dsm and retry ) i reboot more then 10 times already with upgrade funtion and also debug mode stil the same. also i dont see ip adres in system health wiget or uptime. System internal service [synobackupd, hotplugd, synostoraged] failed to start. Please contact Synology support for assistance. anyone any idea how to set all back to normal regards Quote Link to comment Share on other sites More sharing options...
derwoodbones Posted August 24, 2015 Share #16 Posted August 24, 2015 No problems everything working fine on bare metal after second reboot, And rebooting several times just to be sure. ( I Did not choose Install/Upgrade ) I simply downloaded and installed through control panel. Dell Optiplex 760 Quote Link to comment Share on other sites More sharing options...
Knuspertaler Posted August 24, 2015 Share #17 Posted August 24, 2015 I did not choose Install/Upgrade, too ! - after second reboot Update 3 works fine on G7 with vmware ! BUT: Surveillance Station (7.1) with FOSCAM 9805W and other disconnects/connect every 30 sec. - the camera interface of the Foscam looks nice all time. Its not possible to use it ! Same on the 213j works fine !? Quote Link to comment Share on other sites More sharing options...
Schnapps Posted August 24, 2015 Share #18 Posted August 24, 2015 Upgraded. Volume dismounted after 1st start after upgrade. 2nd restart fixed volume. Found some packages in stopped mode and started it. No issues in general. Running a VM under Hyper-V Quote Link to comment Share on other sites More sharing options...
pickgrand Posted August 26, 2015 Share #19 Posted August 26, 2015 I am new to XPEnology. It been running great. However I didn't realize auto update was on and now I get the following with update 3: System internal service [synobackupd, hotplugd, synostoraged] failed to start. Please contact Synology support for assistance. Any ideas of what to try? Really hope I didn't loose everything. any help is appreciated Quote Link to comment Share on other sites More sharing options...
pickgrand Posted August 26, 2015 Share #20 Posted August 26, 2015 I have rebooted multiple times and nothing seems to work. Quote Link to comment Share on other sites More sharing options...
Schnapps Posted August 27, 2015 Share #21 Posted August 27, 2015 Try to reinstall it without losing data. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
spikexp31 Posted August 30, 2015 Share #22 Posted August 30, 2015 Update 3 downloaded directly and installed without using install\upgrade mode. Successfull on G7 with Vmware ESXI 6.0 All Volumes there after 2 restarts. Perfect Quote Link to comment Share on other sites More sharing options...
nemesis122 Posted August 31, 2015 Share #23 Posted August 31, 2015 done over the webconsole without any issue. Quote Link to comment Share on other sites More sharing options...
andywhit Posted September 5, 2015 Share #24 Posted September 5, 2015 Successfully applied update 3 to my HP N54L DSM 5.2 5299 Update 2 instance today. Had to reboot twice and then reapply my Media Server and Video Station folder settings + reindex. All good now. Quote Link to comment Share on other sites More sharing options...
brantje Posted September 5, 2015 Share #25 Posted September 5, 2015 Update 3 downloaded directly and installed without using install\upgrade mode. Successfull on Bare metal Needed to reboot twice. Perfect Quote Link to comment Share on other sites More sharing options...
